Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • solverstack/chameleon
  • lvilleve/chameleon-toto
  • jcletort/chameleon
  • thibault/chameleon
  • tcojean/chameleon
  • sylvand/chameleon
  • viroulea/chameleon
  • x-ltac/chameleon
  • agullo/chameleon
  • glucas/chameleon
  • pswartva/chameleon
  • aguermou1/chameleon
  • eyrauddu/chameleon
  • mverite/chameleon
  • alisito/chameleon
  • furmento/chameleon
  • fpruvost/chameleon
  • ahourcau/chameleon
  • bnicolas/chameleon
  • pesterie/chameleon
  • mmarcos/chameleon
21 results
Show changes
Commits on Source (301)
with 327 additions and 146 deletions
......@@ -26,32 +26,11 @@ if [[ "$SYSTEM" == "linux" ]]; then
fi
export STARPU_DIR=/home/gitlab/install/starpu${STARPU_VARIANT}
# add additional env. var. depending on the starpu variant
case $STARPU_VARIANT in
-hip )
export CMAKE_PREFIX_PATH=$STARPU_DIR:/opt/rocm
export LD_LIBRARY_PATH=/opt/rocm/lib
-hipcuda )
export CMAKE_PREFIX_PATH=$STARPU_DIR:$HIPCUDA_DIR
export LD_LIBRARY_PATH=$HIPCUDA_DIR/lib
export HIP_PLATFORM=nvidia
export HIP_PATH=$HIPCUDA_DIR
esac
# for build: better to rely on pkg-config than to guess libraries with the env. var.
export PKG_CONFIG_PATH=$PARSEC_DIR/lib/pkgconfig:$PKG_CONFIG_PATH
export PKG_CONFIG_PATH=$STARPU_DIR/lib/pkgconfig:$PKG_CONFIG_PATH
export PKG_CONFIG_PATH=$SIMGRID_DIR/lib/pkgconfig:$PKG_CONFIG_PATH
# for ctest: we need this at runtime
export LD_LIBRARY_PATH=$PARSEC_DIR/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=$QUARK_DIR/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=$STARPU_DIR/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=$SIMGRID_DIR/lib:$LD_LIBRARY_PATH
elif [[ "$SYSTEM" == "windows" ]]; then
stages:
- docker
- pre
- build
- test
- coverage
- analyze
- validate
- deploy
# git config --global ahev been added to get around the issue related in
# https://github.com/actions/checkout/issues/760 for github
# Does not seem to be fixed for gitlab-runner yet
before_script:
- git config --global --add safe.directory $CI_PROJECT_DIR
- git config --global --add safe.directory $CI_PROJECT_DIR/cmake_modules/morse_cmake
- git config --global --add safe.directory $CI_PROJECT_DIR/coreblas/hmat-oss
- git config --global --add safe.directory $CI_PROJECT_DIR/hqr
- git config --global --add safe.directory $CI_PROJECT_DIR/testing/test_fembem
- git submodule update --init --recursive
include:
- .gitlab/preliminary.yml
- .gitlab/common.yml
- .gitlab/docker.yml
- .gitlab/build.yml
- .gitlab/test_starpu.yml
- .gitlab/test_starpu_plafrim.yml
- .gitlab/test_starpu_simgrid.yml
- .gitlab/test_parsec.yml
- .gitlab/test_quark.yml
......@@ -32,7 +23,6 @@ include:
- .gitlab/coverage.yml
- .gitlab/coverity.yml
- .gitlab/sonarqube.yml
- .gitlab/validate.yml
- .gitlab/bench_plafrim.yml
- .gitlab/pages.yml
- .gitlab/release.yml
# @file Dockerfile
# @copyright 2024-2025 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# Univ. Bordeaux. All rights reserved.
# @version 1.3.0
# @author Florent Pruvost
# @date 2024-12-03
# This docker image is used to test the package during gitlab-ci pipelines.
# It should be stored in the gitlab's project container registry:
# https://gitlab.inria.fr/solverstack/chameleon/container_registry
FROM registry.gitlab.inria.fr/solverstack/docker/analysis
USER root
# Chameleon dependencies: cpu kernels
RUN apt-get -y upgrade --no-install-recommends \
libblas-dev \
liblapack-dev \
liblapacke-dev
RUN update-alternatives --set libblas.so-x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/blas/libblas.so
RUN update-alternatives --set libblas.so.3-x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/blas/libblas.so.3
RUN update-alternatives --set liblapack.so-x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/lapack/liblapack.so
RUN update-alternatives --set liblapack.so.3-x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3
# Starpu dependencies
autoconf \
automake \
libtool-bin \
libfxt-dev \
libhwloc-dev \
libopenmpi-dev \
libsimgrid-dev
RUN apt-get autoremove -y
RUN apt-get autoclean -y
RUN apt-get purge -y
RUN update-ca-certificates
# Install PARSEC
RUN git clone https://bitbucket.org/mfaverge/parsec.git && \
cd parsec && \
git checkout mymaster && \
git checkout 6022a61dc96c25f11dd2aeabff2a5b3d7bce867d && \
git submodule update && \
cmake -B build -DCMAKE_BUILD_TYPE=Debug -DBUILD_SHARED_LIBS=ON -DPARSEC_GPU_WITH_CUDA=OFF -DPARSEC_DIST_WITH_MPI=OFF && \
cmake --build build -j5 && \
cmake --install build && \
cd .. && \
rm parsec/ -rf
# Install QUARK
RUN git clone https://github.com/ecrc/quark && \
cd quark/ && \
git checkout db4aef9a66a00487d849cf8591927dcebe18ef2f && \
sed -i -e "s#prefix=.*#prefix=/usr#g" make.inc && \
sed -i -e "s#CFLAGS=.*#CFLAGS= -g -O2 -DADD_ -fPIC#g" make.inc && \
make && \
make install && \
cd .. && \
rm quark/ -rf
# Install StarPU
RUN wget https://files.inria.fr/starpu/starpu-1.4.7/starpu-1.4.7.tar.gz > /dev/null 2>&1 && \
tar xzf starpu-1.4.7.tar.gz && \
cd starpu-1.4.7/ && \
./configure --prefix=/home/gitlab/install/starpu --enable-debug --disable-build-doc --with-fxt --disable-simgrid && \
make -j5 install
# Install StarPU with Simgrid
RUN cd starpu-1.4.7/ && \
./configure --prefix=/home/gitlab/install/starpu-simgrid --enable-debug --disable-build-doc --with-fxt --enable-simgrid && \
make -j5 install && \
cd ../ && \
rm starpu-1.4.7/ -rf && \
rm starpu-1.4.7.tar.gz
USER gitlab
# Set some default environment variables
ENV LIBRARY_PATH=/usr/local/lib
ENV LD_LIBRARY_PATH=/usr/local/lib
ENV PKG_CONFIG_PATH=/home/gitlab/install/starpu/lib/pkgconfig
# @file Dockerfile-pages
# @version 1.3.0
# @date 2024-12-03
FROM registry.gitlab.inria.fr/solverstack/chameleon
USER root
# Chameleon tools/pages.sh script additional dependencies
emacs \
emacs-goodies-el \
elpa-htmlize \
python3-click \
python3-elasticsearch \
python3-pandas \
r-cran-ggplot2 \
r-cran-plyr \
r-cran-reshape2
USER gitlab
......@@ -3,8 +3,25 @@ set -ex
SCAN=""
if [[ "$SYSTEM" != "windows" ]]; then
if [[ "$SYSTEM" == "macosx" ]]; then
# Configure with CMake
case $SYSTEM in
guix)
echo "build on guix"
cmake -B build-${VERSION} -S . -C cmake_modules/gitlab-ci-initial-cache.cmake $BUILD_OPTIONS
linux)
echo "build on linux"
source .gitlab-ci-env.sh $CHAM_CI_ENV_ARG
if [[ $CI_COMMIT_REF_NAME == $CI_DEFAULT_BRANCH ]]; then
SCAN="scan-build -plist --intercept-first --exclude CMakeFiles --analyze-headers -o analyzer_reports "
fi
eval '${SCAN}cmake -B build-${VERSION} -S . -C cmake_modules/gitlab-ci-initial-cache.cmake $BUILD_OPTIONS'
macosx)
echo "build on macosx"
# check starpu is already installed and install it if necessary
DEP_INSTALLED=`brew ls --versions starpu | cut -d " " -f 2`
if [[ -z "${DEP_INSTALLED}" ]]; then
......@@ -24,29 +41,39 @@ if [[ "$SYSTEM" != "windows" ]]; then
cmake -B build-${VERSION} -S . \
-DBUILD_SHARED_LIBS=ON -DCMAKE_INSTALL_PREFIX=$PWD/install-${VERSION} \
-DMORSE_ENABLE_COVERAGE=OFF -DBLA_PREFER_PKGCONFIG=ON
else
then
fi
fi
else
# on windows the mpi_f08 interface is missing, see https://www.scivision.dev/windows-mpi-msys2/
# do not use static libraries because executables are too large and the build
# directory can reach more than 10Go
cmake -GNinja -B build-${VERSION} -S . \
-DCHAMELEON_USE_MPI=OFF
fi
eval '${SCAN}cmake --build build-${VERSION} -j 4'
windows)
echo "build on windows"
echo "The SYSTEM environment variable is $SYSTEM. It is not one of : guix, linux, macosx, windows -> exit 1."
exit 1
esac
# Compile
eval '${SCAN}cmake --build build-${VERSION} -j ${CMAKE_BUILD_PARALLEL_LEVEL} > /dev/null'
# Install
cmake --install build-${VERSION}
# Check link to chameleon
cd .gitlab/check_link/
# Set the path variables
export PATH="/c/Windows/WinSxS/x86_microsoft-windows-m..namespace-downlevel_31bf3856ad364e35_10.0.19041.1_none_21374cb0681a6320":$PATH
fi
source install-${VERSION}/bin/chameleon_env
# Set the compiler
......@@ -57,18 +84,7 @@ else
fi
export FC=gfortran
export LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$LIBRARY_PATH
export LD_LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$LD_LIBRARY_PATH
elif [[ "$SYSTEM" == "macosx" ]]; then
export DYLD_LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$DYLD_LIBRARY_PATH
export PATH=$PWD/../../install-${VERSION}/bin:$PATH
fi
# 1) using cmake:
./link_cmake.sh $PWD/../../install-${VERSION}
# 2) using pkg-config:
.build_script_linux:
.build_script_common:
stage: build
tags: ["docker", "large"]
extends: .only-master-mr
script:
- bash .gitlab/build.sh | tee ${LOGNAME}.log
variables:
CMAKE_BUILD_PARALLEL_LEVEL: 4
artifacts:
expire_in: 180 minutes
expire_in: 1 week
untracked: true
when: always
extends: .build_script_common
tags: ['ci.inria.fr', 'linux', 'large']
variables:
GIT_CLONE_PATH: $CI_BUILDS_DIR/$CI_PROJECT_NAMESPACE/$CI_PROJECT_NAME
SYSTEM: linux
script:
build_hmat:
extends: .build_script_linux
variables:
SYSTEM: linux
VERSION: hmat
LOGNAME: "chameleon-build-${SYSTEM}-${VERSION}"
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=OFF -DCHAMELEON_USE_MPI=ON -DCHAMELEON_USE_HMAT=ON"
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=OFF -DCHAMELEON_USE_MPI=ON -DCHAMELEON_USE_HMATOSS=ON"
build_openmp:
variables:
SYSTEM: linux
VERSION: openmp
BUILD_OPTIONS: "-DCHAMELEON_SCHED=OPENMP"
build_parsec:
variables:
SYSTEM: linux
VERSION: parsec
BUILD_OPTIONS: "-DCHAMELEON_SCHED=PARSEC"
......@@ -39,7 +43,6 @@ build_parsec:
build_quark:
variables:
SYSTEM: linux
VERSION: quark
BUILD_OPTIONS: "-DCHAMELEON_SCHED=QUARK"
......@@ -47,33 +50,42 @@ build_quark:
build_starpu:
variables:
SYSTEM: linux
VERSION: starpu
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=ON"
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=OFF -DCHAMELEON_USE_MPI=ON"
build_starpu_hip:
.build_script_guix:
tags: ['plafrim']
variables:
SYSTEM: linux
VERSION: starpu_hip
SYSTEM: guix
CMAKE_BUILD_PARALLEL_LEVEL: 20
script:
- guix describe -f channels
- guix shell --pure --preserve=SYSTEM --preserve=VERSION --preserve=LOGNAME --preserve=BUILD_OPTIONS --preserve=CMAKE_BUILD_PARALLEL_LEVEL
-D chameleon-${GPU_BACKEND} ${BLAS} coreutils bash-minimal --
build_starpu_cuda:
extends: .build_script_guix
variables:
VERSION: starpu_cuda
GPU_BACKEND: cuda
BLAS: "--with-input=openblas=intel-oneapi-mkl"
CHAM_CI_ENV_ARG: hip
BUILD_OPTIONS: "-DCHAMELEON_USE_HIP_ROC=ON -DCHAMELEON_USE_MPI=ON"
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF -DBLA_VENDOR=Intel10_64lp_seq"
build_starpu_hipcuda:
build_starpu_hip:
variables:
SYSTEM: linux
VERSION: starpu_hipcuda
VERSION: starpu_hip
GPU_BACKEND: hip
CHAM_CI_ENV_ARG: hipcuda
BUILD_OPTIONS: "-DCHAMELEON_USE_HIP_CUDA=ON -DCHAMELEON_HIPBLAS_PATH=/home/gitlab/hipcuda/hipblas -DCHAMELEON_USE_MPI=ON"
BUILD_OPTIONS: "-DCHAMELEON_USE_HIP_ROC=ON -DCHAMELEON_USE_MPI=OFF -DBLA_VENDOR=OpenBLAS -DCMAKE_C_COMPILER=gcc -DCMAKE_Fortran_COMPILER=gfortran"
build_starpu_simgrid:
variables:
SYSTEM: linux
VERSION: starpu_simgrid
CHAM_CI_ENV_ARG: simgrid
......@@ -87,11 +99,13 @@ build_starpu_macosx:
SYSTEM: macosx
VERSION: starpu
script:
artifacts:
expire_in: 1 week
when: always
paths:
- ${LOGNAME}.log
cache:
......@@ -109,11 +123,13 @@ build_starpu_macosx:
MSYSTEM: UCRT64
VERSION: starpu
script:
- bash -lc .gitlab/build.sh | tee "$env:LOGNAME.log"
artifacts:
expire_in: 1 week
when: always
paths:
- ${LOGNAME}.log
cache:
# @copyright 2013-2024 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# @copyright 2013-2025 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# @version 1.3.0
# @author Mathieu Faverge
# @date 2024-06-13
# @date 2024-06-17
cmake_minimum_required(VERSION 3.5)
......@@ -2,13 +2,13 @@
# @file link_cmake.sh
# @copyright 2023-2024 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# @copyright 2023-2025 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# @version 1.3.0
# @date 2023-12-07
# @date 2024-12-03
# Check that linking with the project is ok when using cmake.
......@@ -21,7 +21,7 @@ then
exit 1
fi
cmake -B build -DCMAKE_PREFIX_PATH=$1
cmake --build build --verbose
if [[ "$VERSION" != "starpu_simgrid" ]]; then
ctest --test-dir build --verbose
fi
# @file link_pkgconfig.sh
# @version 1.3.0
# @date 2023-12-07
# @date 2024-06-17
# Check that linking with the project is ok when using pkg-config.
......@@ -3,13 +3,15 @@
default:
image: registry.gitlab.inria.fr/solverstack/docker/distrib
image: $CI_REGISTRY_IMAGE
interruptible: true
variables:
GIT_SUBMODULE_STRATEGY: recursive
# push event: executed only if the source branch name is master or starts with ci-
# schedule event: not executed
.only-master:
interruptible: true
rules:
- if: ($CI_COMMIT_BRANCH == $CI_DEFAULT_BRANCH || $CI_COMMIT_BRANCH =~ /^ci-.*$/) && $CI_PIPELINE_SOURCE != "schedule"
......@@ -17,24 +19,27 @@ default:
# merge request event: executed if the source branch name does not start with notest-
.only-master-mr:
interruptible: true
rules:
- if: ($CI_PIPELINE_SOURCE == "merge_request_event" && $CI_MERGE_REQUEST_SOURCE_BRANCH_NAME !~ /^notest-.*$/)
.only-mr:
interruptible: true
rules:
.test_script_linux:
stage: test
variables:
SYSTEM: linux
script:
- bash .gitlab/test.sh | tee ${LOGNAME}.log
artifacts:
expire_in: 1 week
untracked: true
when: always
reports:
junit: ${LOGNAME}-junit.xml
......@@ -7,12 +7,15 @@
.coverage:
stage: coverage
tags: ['ci.inria.fr', 'linux']
variables:
script:
- tools/coverage.sh
- ./tools/coverage.sh
coverage: /^\s*lines......:\s*\d+.\d+\%/
artifacts:
expire_in: 1 week
paths:
- chameleon-*.lcov
- chameleon.lcov
......@@ -32,7 +35,6 @@ coverage_master:
coverage_mr:
extends: .coverage
interruptible: true
rules:
needs: [test_openmp_mr,test_parsec_mr,test_quark_mr,test_starpu_mr,test_starpu_simgrid_simu_all]
coverity:
stage: analyze
interruptible: true
rules:
......@@ -12,17 +11,7 @@ coverity:
variables:
VERSION: coverity
script:
- (mkdir -p build-$VERSION && cd build-$VERSION &&
cmake .. -C ../cmake_modules/gitlab-ci-initial-cache.cmake
-DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=ON &&
cov-build --dir ../cov-int make -j 4)
- tar czvf chameleon.tgz cov-int
- curl --form token=$COVERITY_TOKEN
--form email=florent.pruvost@inria.fr
--form file=@chameleon.tgz
--form version="`git rev-parse --short HEAD`"
--form description=""
https://scan.coverity.com/builds?project=Chameleon
- ./tools/coverity.sh
artifacts:
expire_in: 1 week
.docker_script_common:
stage: docker
image: docker
when: manual
before_script:
- docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
script:
- docker build -f $IMAGE_FILE -t $IMAGE_NAME $PWD
- docker push $IMAGE_NAME
docker-tests:
extends: .docker_script_common
variables:
IMAGE_FILE: .gitlab/Dockerfile
IMAGE_NAME: $CI_REGISTRY_IMAGE
docker-pages:
variables:
IMAGE_FILE: .gitlab/Dockerfile-pages
IMAGE_NAME: $CI_REGISTRY_IMAGE/pages
pages:
stage: deploy
image: $CI_REGISTRY_IMAGE/pages
needs: [coverage_master]
variables:
VERSION: pages
script:
- ./tools/pages.sh
artifacts:
expire_in: 1 week
paths:
- public
variables:
VERSION: pages
script:
- ./tools/pages.sh
......@@ -4,7 +4,8 @@
preliminary_checks:
stage: pre
interruptible: true
image: registry.gitlab.inria.fr/solverstack/docker/pre
rules:
- if: $CI_PIPELINE_SOURCE == "merge_request_event"
parallel:
release:
stage: deploy
rules:
- if: $CI_COMMIT_TAG =~ /^v[0-9]\.[0-9]\.[0-9]$/ && $CI_PIPELINE_SOURCE != "schedule"
dependencies: []
variables:
GIT_CONFIG_COUNT: 1
GIT_CONFIG_KEY_0: "safe.directory"
GIT_CONFIG_VALUE_0: "*"
VERSION: release
script:
- ./tools/release.sh
artifacts:
expire_in: 1 week
paths:
- chameleon-*.tar.gz
variables:
VERSION: release
script:
#!/bin/bash
# sbatch.sh : submit slurm jobs and wait for completion before exiting
set -x
if [ $# -gt 0 ]
then
JOB_NAME=$1
fi
JOB_NAME=${JOB_NAME:-chameleon}
# to get kernels execution on both cpus and gpus
export STARPU_SCHED=random
# execution commands
sbatch --wait \
--job-name="$JOB_NAME" \
--output="$JOB_NAME.out" \
--nodes=1 \
--exclusive --ntasks-per-node=1 --threads-per-core=1 \
--constraint="$SLURM_CONSTRAINTS" \
--time=01:00:00 \
$(dirname "$0")/test.sh
# get the error code from the last command: sbatch --wait ...
err=$?
cat $JOB_NAME.out
# exit with error code from the guix command
exit $err
.sonarqube:
stage: analyze
variables:
GIT_CONFIG_COUNT: 1
GIT_DEPTH: "0"
VERSION: sonarqube
script:
- ls -l build*/*.json
......@@ -13,7 +18,7 @@
- ./tools/analysis.sh
artifacts:
expire_in: 1 week
when: always
paths:
- filelist.txt
......@@ -30,7 +35,6 @@ sonarqube_master:
sonarqube_mr:
extends: .sonarqube
interruptible: true
rules:
when: manual
#!/usr/bin/env bash
fatal() {
echo "$0: error occurred, exit"
exit 1
set -e
set -x
cd build-$VERSION
source ../.gitlab-ci-env.sh $CHAM_CI_ENV_ARG || fatal
CTESTCOMMAND=`echo "ctest --output-on-failure --no-compress-output $TESTS_RESTRICTION -T Test --output-junit ../${LOGNAME}-junit.xml"`
$CTESTCOMMAND || fatal
ctest --output-on-failure --no-compress-output $TESTS_RESTRICTION --output-junit ../${LOGNAME}-junit.xml
# clang is used on macosx and it is not compatible with MORSE_ENABLE_COVERAGE=ON
# so that we can only make the coverage report on the linux runner with gcc
......@@ -5,7 +5,6 @@ test_hmat:
- .only-master-mr
needs: [build_hmat]
variables:
SYSTEM: linux
VERSION: hmat
CATEGORY: none
PRECISION: all
