Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • solverstack/chameleon
  • lvilleve/chameleon-toto
  • jcletort/chameleon
  • thibault/chameleon
  • tcojean/chameleon
  • sylvand/chameleon
  • viroulea/chameleon
  • x-ltac/chameleon
  • agullo/chameleon
  • glucas/chameleon
  • pswartva/chameleon
  • aguermou1/chameleon
  • eyrauddu/chameleon
  • mverite/chameleon
  • alisito/chameleon
  • furmento/chameleon
  • fpruvost/chameleon
  • ahourcau/chameleon
  • bnicolas/chameleon
  • pesterie/chameleon
  • mmarcos/chameleon
21 results
Show changes
Commits on Source (6)
...@@ -232,6 +232,13 @@ if(CHAMELEON_SCHED_STARPU) ...@@ -232,6 +232,13 @@ if(CHAMELEON_SCHED_STARPU)
message("-- ${BoldGreen}CHAMELEON_SIMULATION is set to OFF, turn it ON to use" message("-- ${BoldGreen}CHAMELEON_SIMULATION is set to OFF, turn it ON to use"
" SIMULATION mode (only with StarPU compiled with SimGrid)${ColourReset}") " SIMULATION mode (only with StarPU compiled with SimGrid)${ColourReset}")
endif() endif()
option(CHAMELEON_ENABLE_PRUNING_STATS "Enable pruning statistics" OFF)
if (NOT CHAMELEON_ENABLE_PRUNING_STATS)
message("-- ${BoldGreen}CHAMELEON_ENABLE_PRUNING_STATS is set to OFF, turn it ON to build pruning statistics${ColourReset}")
endif()
if(CHAMELEON_ENABLE_PRUNING_STATS)
add_definitions(-DCHAMELEON_ENABLE_PRUNING_STATS)
endif(CHAMELEON_ENABLE_PRUNING_STATS)
endif() endif()
# Initially we need to generate files for different precisions # Initially we need to generate files for different precisions
Subproject commit 32c1ba6ae5d7e19d570ac3bd86a24acb82f2081e Subproject commit 0a974775b7192227b887dcba77515305083c1f13
...@@ -521,6 +521,8 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt, ...@@ -521,6 +521,8 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt,
morse_sequence_wait(morse, sequence); morse_sequence_wait(morse, sequence);
#if !defined(CHAMELEON_SIMULATION)
info = LAPACKE_zgbbrd( LAPACK_COL_MAJOR, info = LAPACKE_zgbbrd( LAPACK_COL_MAJOR,
gbbrd_vect, gbbrd_vect,
M, N, M, N,
...@@ -533,6 +535,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt, ...@@ -533,6 +535,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt,
if (info != 0) { if (info != 0) {
fprintf(stderr, "MORSE_zgesvd_Tile_Async: LAPACKE_zgbbrd = %d\n", info ); fprintf(stderr, "MORSE_zgesvd_Tile_Async: LAPACKE_zgbbrd = %d\n", info );
#endif /* !defined(CHAMELEON_SIMULATION) */
morse_desc_mat_free(&descAB); morse_desc_mat_free(&descAB);
/* Transform U and Vt into tile format */ /* Transform U and Vt into tile format */
...@@ -594,6 +597,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt, ...@@ -594,6 +597,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt,
/* Solve the bidiagonal SVD problem */ /* Solve the bidiagonal SVD problem */
/* On exit, U and VT are updated with bidiagonal matrix singular vectors */ /* On exit, U and VT are updated with bidiagonal matrix singular vectors */
info = LAPACKE_zbdsqr( LAPACK_COL_MAJOR, 'U', info = LAPACKE_zbdsqr( LAPACK_COL_MAJOR, 'U',
MINMN, ncvt, nru, 0, MINMN, ncvt, nru, 0,
S, E, S, E,
...@@ -601,6 +605,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt, ...@@ -601,6 +605,7 @@ int MORSE_zgesvd_Tile_Async(MORSE_enum jobu, MORSE_enum jobvt,
fprintf(stderr, "MORSE_zgesvd_Tile_Async: LAPACKE_zbdsqr = %d\n", info ); fprintf(stderr, "MORSE_zgesvd_Tile_Async: LAPACKE_zbdsqr = %d\n", info );
if (jobu != MorseNoVec) if (jobu != MorseNoVec)
morse_desc_mat_free( &descU ); morse_desc_mat_free( &descU );
...@@ -420,6 +420,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo, ...@@ -420,6 +420,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo,
if (jobz == MorseNoVec){ if (jobz == MorseNoVec){
/* Tridiagonal eigensolver */ /* Tridiagonal eigensolver */
status = LAPACKE_zstedc( LAPACK_COL_MAJOR, status = LAPACKE_zstedc( LAPACK_COL_MAJOR,
morse_lapack_const(jobz), morse_lapack_const(jobz),
...@@ -428,6 +429,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo, ...@@ -428,6 +429,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo,
if (status != 0) { if (status != 0) {
morse_error("MORSE_zheevd_Tile_Async", "LAPACKE_zstedc failed"); morse_error("MORSE_zheevd_Tile_Async", "LAPACKE_zstedc failed");
free(E); free(E);
return MORSE_SUCCESS; return MORSE_SUCCESS;
...@@ -441,8 +443,11 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo, ...@@ -441,8 +443,11 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo,
/* For bug in lapacke */ /* For bug in lapacke */
memset(V, 0, N * N * sizeof(MORSE_Complex64_t)); memset(V, 0, N * N * sizeof(MORSE_Complex64_t));
/* V contains the eigenvectors of the tridiagonal system on exit */ * Tridiagonal eigensolver
morse_lapack_const(MorseIvec), morse_lapack_const(MorseIvec),
N, W, E, N, W, E,
...@@ -450,6 +455,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo, ...@@ -450,6 +455,7 @@ int MORSE_zheevd_Tile_Async(MORSE_enum jobz, MORSE_enum uplo,
/* Convert matrices in tile format */ /* Convert matrices in tile format */
/* A/T from MORSE_zhetrd refer to Q1 (tile layout) */ /* A/T from MORSE_zhetrd refer to Q1 (tile layout) */
...@@ -408,6 +408,7 @@ int MORSE_zhetrd_Tile_Async(MORSE_enum jobz, ...@@ -408,6 +408,7 @@ int MORSE_zhetrd_Tile_Async(MORSE_enum jobz,
/* Reduce band matrix to tridiagonal matrix */ /* Reduce band matrix to tridiagonal matrix */
status = LAPACKE_zhbtrd( LAPACK_COL_MAJOR, status = LAPACKE_zhbtrd( LAPACK_COL_MAJOR,
morse_lapack_const(uplo), morse_lapack_const(uplo),
...@@ -417,6 +418,7 @@ int MORSE_zhetrd_Tile_Async(MORSE_enum jobz, ...@@ -417,6 +418,7 @@ int MORSE_zhetrd_Tile_Async(MORSE_enum jobz,
morse_error("MORSE_zhetrd_Tile_Async", "LAPACKE_zhbtrd failed"); morse_error("MORSE_zhetrd_Tile_Async", "LAPACKE_zhbtrd failed");
...@@ -126,6 +126,9 @@ double RUNTIME_get_time(); ...@@ -126,6 +126,9 @@ double RUNTIME_get_time();
void RUNTIME_start_profiling(); void RUNTIME_start_profiling();
void RUNTIME_stop_profiling(); void RUNTIME_stop_profiling();
void RUNTIME_start_stats();
void RUNTIME_stop_stats();
#if defined(PRECISION_z) #if defined(PRECISION_z)
void RUNTIME_zdisplay_allprofile (); void RUNTIME_zdisplay_allprofile ();
void RUNTIME_zdisplay_oneprofile (MORSE_kernel_t); void RUNTIME_zdisplay_oneprofile (MORSE_kernel_t);
...@@ -88,6 +88,16 @@ void RUNTIME_stop_profiling() ...@@ -88,6 +88,16 @@ void RUNTIME_stop_profiling()
morse_warning("RUNTIME_stop_profiling()", "FxT profiling is not available with PaRSEC\n"); morse_warning("RUNTIME_stop_profiling()", "FxT profiling is not available with PaRSEC\n");
morse_warning("RUNTIME_start_stats()", "pruning stats are not available with PaRSEC\n");
morse_warning("RUNTIME_stop_stats()", "pruning stats are not available with PaRSEC\n");
void RUNTIME_schedprofile_display(void) void RUNTIME_schedprofile_display(void)
morse_warning("RUNTIME_schedprofile_display(parsec)", "Scheduler profiling is not available with PaRSEC\n"); morse_warning("RUNTIME_schedprofile_display(parsec)", "Scheduler profiling is not available with PaRSEC\n");
...@@ -103,6 +103,16 @@ void RUNTIME_stop_profiling() ...@@ -103,6 +103,16 @@ void RUNTIME_stop_profiling()
morse_warning("RUNTIME_stop_profiling()", "FxT profiling is not available with Quark\n"); morse_warning("RUNTIME_stop_profiling()", "FxT profiling is not available with Quark\n");
morse_warning("RUNTIME_start_stats()", "pruning stats are not available with Quark\n");
morse_warning("RUNTIME_stop_stats()", "pruning stats are not available with Quark\n");
morse_warning("RUNTIME_schedprofile_display(quark)", "Scheduler profiling is not available with Quark\n"); morse_warning("RUNTIME_schedprofile_display(quark)", "Scheduler profiling is not available with Quark\n");
...@@ -29,6 +29,12 @@ ...@@ -29,6 +29,12 @@
#include <starpu_fxt.h> #include <starpu_fxt.h>
#endif #endif
#ifdef CHAMELEON_ENABLE_PRUNING_STATS
unsigned long RUNTIME_total_tasks;
unsigned long RUNTIME_exec_tasks;
unsigned long RUNTIME_comm_tasks;
unsigned long RUNTIME_changed_tasks;
#endif
double RUNTIME_get_time(){ double RUNTIME_get_time(){
return starpu_timing_now()*1e-6; return starpu_timing_now()*1e-6;
...@@ -50,6 +56,21 @@ void RUNTIME_stop_profiling(){ ...@@ -50,6 +56,21 @@ void RUNTIME_stop_profiling(){
#endif #endif
void RUNTIME_start_stats(){
RUNTIME_total_tasks = 0;
RUNTIME_exec_tasks = 0;
RUNTIME_comm_tasks = 0;
RUNTIME_changed_tasks = 0;
#endif
void RUNTIME_stop_stats(){
fprintf(stderr, "\ntasks: %u = exec: %u + comm: %u + changed: %u\n", RUNTIME_total_tasks, RUNTIME_exec_tasks, RUNTIME_comm_tasks, RUNTIME_changed_tasks);
#endif
void RUNTIME_profiling_display_info(const char *kernel_name, measure_t perf[STARPU_NMAXWORKERS]) void RUNTIME_profiling_display_info(const char *kernel_name, measure_t perf[STARPU_NMAXWORKERS])
int header = 1; int header = 1;
...@@ -86,16 +86,53 @@ typedef struct starpu_conf starpu_conf_t; ...@@ -86,16 +86,53 @@ typedef struct starpu_conf starpu_conf_t;
void RUNTIME_set_reduction_methods(starpu_data_handle_t handle, MORSE_enum dtyp); void RUNTIME_set_reduction_methods(starpu_data_handle_t handle, MORSE_enum dtyp);
#define RUNTIME_BEGIN_ACCESS_DECLARATION #ifdef CHAMELEON_ENABLE_PRUNING_STATS
#define RUNTIME_PRUNING_STATS_BEGIN_ACCESS_DECLARATION \
int __morse_exec = 0; \
int __morse_changed = 0;
#define RUNTIME_PRUNING_STATS_ACCESS_W(A, Am, An) \
if (morse_desc_islocal(A, Am, An)) \
__morse_exec = 1;
#define RUNTIME_PRUNING_STATS_END_ACCESS_DECLARATION \
RUNTIME_total_tasks++; \
if (__morse_exec) \
RUNTIME_exec_tasks++; \
else if (__morse_need_submit) \
RUNTIME_comm_tasks++; \
else if (__morse_changed) \
RUNTIME_changed_tasks++;
#define RUNTIME_PRUNING_STATS_RANK_CHANGED(rank) \
int __morse_myrank; \
RUNTIME_comm_rank(&__morse_myrank); \
__morse_exec = (rank) == __morse_myrank; \
__morse_changed = 1; \
#define RUNTIME_ACCESS_R(A, Am, An) #else
#endif
#define RUNTIME_BEGIN_ACCESS_DECLARATION \
#define RUNTIME_ACCESS_R(A, Am, An) \
#define RUNTIME_ACCESS_W(A, Am, An) #define RUNTIME_ACCESS_W(A, Am, An) \
#define RUNTIME_ACCESS_RW(A, Am, An) #define RUNTIME_ACCESS_RW(A, Am, An) \
#define RUNTIME_RANK_CHANGED(rank) #define RUNTIME_RANK_CHANGED(rank) \
#define RUNTIME_END_ACCESS_DECLARATION #define RUNTIME_END_ACCESS_DECLARATION \
RUNTIME_PRUNING_STATS_END_ACCESS_DECLARATION;
#endif /* _MORSE_STARPU_H_ */ #endif /* _MORSE_STARPU_H_ */
...@@ -26,6 +26,13 @@ ...@@ -26,6 +26,13 @@
#ifndef _PROFILING_H_ #ifndef _PROFILING_H_
#define _PROFILING_H_ #define _PROFILING_H_
extern unsigned long RUNTIME_total_tasks;
extern unsigned long RUNTIME_exec_tasks;
extern unsigned long RUNTIME_comm_tasks;
extern unsigned long RUNTIME_changed_tasks;
#endif
typedef struct measure_s { typedef struct measure_s {
double sum; double sum;
double sum2; double sum2;
...@@ -159,6 +159,7 @@ enum dparam_timing { ...@@ -159,6 +159,7 @@ enum dparam_timing {
#define START_TRACING() \ #define START_TRACING() \
RUNTIME_start_stats(); \
if(iparam[IPARAM_TRACE] == 2) { \ if(iparam[IPARAM_TRACE] == 2) { \
RUNTIME_start_profiling(); \ RUNTIME_start_profiling(); \
...@@ -167,6 +168,7 @@ enum dparam_timing { ...@@ -167,6 +168,7 @@ enum dparam_timing {
#define STOP_TRACING() \ #define STOP_TRACING() \
RUNTIME_stop_stats(); \
RUNTIME_stop_profiling(); \ RUNTIME_stop_profiling(); \
