Commit e7aa4554 authored by THIBAULT Samuel's avatar THIBAULT Samuel
fix typo
parent bf115f19
......@@ -164,13 +164,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
# Use intermediate variable since cmake_dependent_option doesn't have OR conditions
set(CHAMELEON_ENABLE_MPI OFF CACHE BOOL "Tells if MPI might be supported by the runtime")
if ( CHAMELEON_SCHED_PARSEC OR CHAMELEOM_SCHED_STARPU )
if ( CHAMELEON_SCHED_PARSEC OR CHAMELEON_SCHED_STARPU )
set(CHAMELEON_ENABLE_MPI ON)
endif()
set(CHAMELEON_ENABLE_CUDA OFF CACHE BOOL "Tells if CUDA might be supported by the runtime")
set(CHAMELEON_ENABLE_CUDA ON)
endif()
