GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
dc4ad4c0
dc4ad4c0
10 months ago
Mathieu Faverge
Downloads
Patches
parameters: fix error message to use function name
8cf5bbe7
1 merge request
!468
Many minor hotfix issued from the mixed precision branch
testing/parameters.c
+3
-3
3 additions, 3 deletions
3 additions
3 deletions
3
3
dc4ad4c0
@@ -690,19 +690,19 @@ parameters_getvalue_fixdbl( const char *name )
if
param
has_arg
if
param
has_arg
fprintf
stderr
"parameters_getvalue_
dou
bl
e
should not be called with parameter %s
\n
name
fprintf
stderr
fixd
bl should not be called with parameter %s
\n
name
return
return
if
param
valtype
TestValDouble
if
param
valtype
TestValDouble
fprintf
stderr
dou
bl
e
has been called with a non float parameter (%s)
\n
name
fprintf
stderr
fixd
bl has been called with a non float parameter (%s)
\n
name
return
return
return
param
value
dval
return
param
value
dval
fprintf
stderr
int
could not find parameter %s
\n
name
fprintf
stderr
fixdbl
\n
name
return
return
This diff is collapsed.
Loading
Save comment
