Commit dc4ad4c0 authored by Mathieu Faverge's avatar Mathieu Faverge
parameters: fix error message to use function name
parent 8cf5bbe7
1 merge request!468Many minor hotfix issued from the mixed precision branch
......@@ -690,19 +690,19 @@ parameters_getvalue_fixdbl( const char *name )
if ( param->has_arg > 1 ) {
fprintf( stderr, "parameters_getvalue_double should not be called with parameter %s\n", name );
fprintf( stderr, "parameters_getvalue_fixdbl should not be called with parameter %s\n", name );
return -1;
if ( param->valtype != TestValDouble ) {
fprintf( stderr, "parameters_getvalue_double has been called with a non float parameter (%s)\n", name );
fprintf( stderr, "parameters_getvalue_fixdbl has been called with a non float parameter (%s)\n", name );
return -1;
return param->value.dval;
fprintf( stderr, "parameters_getvalue_int could not find parameter %s\n", name );
fprintf( stderr, "parameters_getvalue_fixdbl could not find parameter %s\n", name );
return -1;
