GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
b20c3384
b20c3384
7 years ago
THIBAULT Samuel
Committed by
Mathieu Faverge
7 years ago
Downloads
Patches
Remove -bounddeps/-bounddepsprio and document -bound
363bf86f
1 merge request
!58
3
3 changed files
example/basic_zposv/basic_posv.h
+0
-4
0 additions, 4 deletions
timing/timing.c
+7
-34
7 additions, 34 deletions
timing/timing.c
timing/timing.h
+0
-2
0 additions, 2 deletions
timing/timing.h
7 additions
40 deletions
b20c3384
@@ -127,8 +127,6 @@ enum iparam_examples {
IPARAM_PARALLEL_TASKS
IPARAM_NO_CPU
IPARAM_NO_CPU
IPARAM_BOUND
IPARAM_BOUND
IPARAM_BOUNDDEPS
IPARAM_BOUNDDEPSPRIO
/* End */
/* End */
IPARAM_SIZEOF
IPARAM_SIZEOF
@@ -191,8 +189,6 @@ static void init_iparam(int iparam[IPARAM_SIZEOF]){
iparam
iparam
iparam
IPARAM_NO_CPU
iparam
IPARAM_NO_CPU
iparam
IPARAM_BOUND
iparam
IPARAM_BOUND
iparam
IPARAM_BOUNDDEPS
iparam
static
void
read_args
int
argc
char
argv
int
iparam
static
void
read_args
int
argc
char
argv
int
iparam
This diff is collapsed.
timing/timing.c
7
34
b20c3384
@@ -201,33 +201,15 @@ Test(int64_t n, int *iparam) {
gflops
flops
t
iter
gflops
flops
t
iter
#if defined (CHAMELEON_SCHED_STARPU)
/* TODO: create chameleon interface encapsulating this instead */
if
iparam
IPARAM_BOUND
if
iparam
IPARAM_BOUND
double
upper_gflops
double
upper_gflops
double
tmin
double
tmin
double
integer_tmin
double
integer_tmin
#if 0
starpu_bound_compute
tmin
integer_tmin
if (iparam[IPARAM_BOUNDDEPS]) {
upper_gflops
flops
tmin
1000
FILE *out = fopen("bounddeps.pl", "w");
sumgf_upper
upper_gflops
starpu_bound_print_lp(out);
fclose(out);
out = fopen("bound.dot", "w");
starpu_bound_print_dot(out);
fclose(out);
} else {
FILE *out = fopen("bound.pl", "w");
fclose(out);
#else
#endif
tmin
integer_tmin
upper_gflops
flops
tmin
1000
sumgf_upper
upper_gflops
#if 0
#endif
#endif
#endif
sumt
t
iter
sumt
t
iter
@@ -241,7 +223,7 @@ Test(int64_t n, int *iparam) {
if
MORSE_My_Mpi_Rank
if
MORSE_My_Mpi_Rank
printf
"%9.3f %9.2f +-%7.2f "
sumt
niter
gflops
sd
printf
sumt
niter
gflops
sd
if
iparam
IPARAM_BOUND
iparam
IPARAM_BOUNDDEPS
if
iparam
IPARAM_BOUND
printf
" %9.2f"
sumgf_upper
niter
printf
" %9.2f"
sumgf_upper
niter
if
iparam
IPARAM_PEAK
if
iparam
IPARAM_PEAK
@@ -408,9 +390,7 @@ show_help(char *prog_name) {
" -o, --ooc Enable out-of-core (available only with StarPU)
\n
\n
" -G, --gemm3m Use gemm3m complex method
\n
\n
//" --peak ?\n"todo
//" --peak ?\n"todo
//" --bound ?\n"todo
" --bound Compare result to area bound
\n
//" --bounddeps ?\n"todo
//" --bounddepsprio ?\n"todo
\n
\n
@@ -458,7 +438,7 @@ print_header(char *prog_name, int * iparam) {
return
return
#define GETOPT_STRING "ht:g:P:8M:m:N:n:K:k:b:i:x:X:1:WwcCT2dpa:l:L:D9:3soG45
67
#define GETOPT_STRING "ht:g:P:8M:m:N:n:K:k:b:i:x:X:1:WwcCT2dpa:l:L:D9:3soG45"
#if defined(CHAMELEON_HAVE_GETOPT_LONG)
static
struct
option
long_options
static
struct
option
long_options
@@ -506,8 +486,6 @@ static struct option long_options[] =
"gemm3m"
no_argument
'G'
"gemm3m"
no_argument
'G'
"peak"
no_argument
'4'
"peak"
no_argument
'4'
"bound"
no_argument
'5'
"bound"
no_argument
'5'
"bounddeps"
no_argument
'6'
"bounddepsprio"
no_argument
'7'
#endif
/* defined(CHAMELEON_HAVE_GETOPT_LONG) */
#endif
@@ -637,11 +615,6 @@ parse_arguments(int *_argc, char ***_argv, int *iparam, int *start, int *stop, i
case
'G'
iparam
IPARAM_GEMM3M
break
case
'G'
iparam
IPARAM_GEMM3M
break
case
'4'
iparam
IPARAM_PEAK
break
case
'4'
iparam
IPARAM_PEAK
break
case
'5'
iparam
IPARAM_BOUND
break
case
'5'
iparam
IPARAM_BOUND
break
case
'6'
iparam
IPARAM_BOUND
iparam
IPARAM_BOUNDDEPS
break
case
'7'
iparam
IPARAM_BOUND
iparam
IPARAM_BOUNDDEPS
iparam
break
case
'h'
case
'h'
case
case
show_help
argv
exit
EXIT_FAILURE
show_help
argv
exit
EXIT_FAILURE
timing/timing.h
b20c3384
@@ -59,8 +59,6 @@ enum iparam_timing {
IPARAM_NO_CPU
IPARAM_NO_CPU
IPARAM_BOUND
IPARAM_BOUND
IPARAM_BOUNDDEPS
/* End */
/* End */
/* Added for libhqr version */
IPARAM_LOWLVL_TREE
/* Tree used for reduction inside nodes */
IPARAM_LOWLVL_TREE
Loading
Save comment
