Commit 73bdfe23 authored by PRUVOST Florent's avatar PRUVOST Florent
remove this quark codelet which lies in starpu directory
parent fc00c516
* @copyright (c) 2009-2014 The University of Tennessee and The University
* of Tennessee Research Foundation.
* All rights reserved.
* @copyright (c) 2012-2014 Inria. All rights reserved.
* @copyright (c) 2012-2014, 2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
* @file codelet_zpamm.c
* MORSE codelets kernel
* MORSE is a software package provided by Univ. of Tennessee,
* Univ. of California Berkeley and Univ. of Colorado Denver
* @version 2.5.0
* @comment This file has been automatically generated
* from Plasma 2.5.0 for MORSE 1.0.0
* @author Dulceneia Becker
* @author Mathieu Faverge
* @author Emmanuel Agullo
* @author Cedric Castagnede
* @date 2011-06-14
* @precisions normal z -> c d s
#include "coreblas/include/cblas.h"
#include "runtime/starpu/include/morse_starpu.h"
#include "runtime/starpu/include/runtime_codelet_z.h"
* @ingroup CORE_MORSE_Complex64_t
* ZPAMM performs one of the matrix-matrix operations
* LEFT RIGHT
* OP MorseW : W = A1 + op(V) * A2 or W = A1 + A2 * op(V)
* OP MorseA2 : A2 = A2 - op(V) * W or A2 = A2 - W * op(V)
* where op( V ) is one of
* op( V ) = V or op( V ) = V**T or op( V ) = V**H,
* A1, A2 and W are general matrices, and V is:
* l = k: rectangle + triangle
* l < k: rectangle + trapezoid
* l = 0: rectangle
* Size of V, both rowwise and columnwise, is:
* side trans size
* left N M x K
* T K x M
* right N K x N
* T N x K
* LEFT (columnwise and rowwise):
* | K | | M |
* _ __________ _ _______________ _
* V: | | | V': |_____________|___\ K
* | | | M-L | |
* M | | | |__________________| _
* |____| | _
* \ | | | M - L | L |
* \ | | L
* _ \|____| _
* RIGHT (columnwise and rowwise):
* | K | | N |
* _______________ _ _ __________ _
* V': |_____________|___\ N V: | | |
* | | | | | K-L
* |__________________| _ K | | |
* |____| | _
* | K - L | L | \ | |
* \ | | L
* _ \|____| _
* Arguments
* @param[in] op
* OP specifies which operation to perform:
* @arg MorseW : W = A1 + op(V) * A2 or W = A1 + A2 * op(V)
* @arg MorseA2 : A2 = A2 - op(V) * W or A2 = A2 - W * op(V)
* @param[in] side
* SIDE specifies whether op( V ) multiplies A2
* or W from the left or right as follows:
* @arg MorseLeft : multiply op( V ) from the left
* @arg MorseRight : multiply op( V ) from the right
* OP MorseW : W = A1 + A2 * op(V)
* OP MorseA2 : A2 = A2 - W * op(V)
* @param[in] storev
* Indicates how the vectors which define the elementary
* reflectors are stored in V:
* @arg MorseColumnwise
* @arg MorseRowwise
* @param[in] M
* The number of rows of the A1, A2 and W
* If SIDE is MorseLeft, the number of rows of op( V )
* @param[in] N
* The number of columns of the A1, A2 and W
* If SIDE is MorseRight, the number of columns of op( V )
* @param[in] K
* If SIDE is MorseLeft, the number of columns of op( V )
* If SIDE is MorseRight, the number of rows of op( V )
* @param[in] L
* The size of the triangular part of V
* @param[in] A1
* On entry, the M-by-N tile A1.
* @param[in] LDA1
* The leading dimension of the array A1. LDA1 >= max(1,M).
* @param[in,out] A2
* On entry, the M-by-N tile A2.
* On exit, if OP is MorseA2 A2 is overwritten
* @param[in] LDA2
* The leading dimension of the tile A2. LDA2 >= max(1,M).
* @param[in] V
* The matrix V as described above.
* If SIDE is MorseLeft : op( V ) is M-by-K
* If SIDE is MorseRight: op( V ) is K-by-N
* @param[in] LDV
* The leading dimension of the array V.
* @param[in,out] W
* On entry, the M-by-N matrix W.
* On exit, W is overwritten either if OP is MorseA2 or MorseW.
* If OP is MorseA2, W is an input and is used as a workspace.
* @param[in] LDW
* The leading dimension of array WORK.
* @return
* \retval MORSE_SUCCESS successful exit
* \retval <0 if -i, the i-th argument had an illegal value
void
MORSE_TASK_zpamm(const MORSE_option_t *options,
int op, MORSE_enum side, int storev,
int m, int n, int k, int l,
const MORSE_desc_t *A1, int A1m, int A1n, int lda1,
const MORSE_desc_t *A2, int A2m, int A2n, int lda2,
const MORSE_desc_t *V, int Vm, int Vn, int ldv,
const MORSE_desc_t *W, int Wm, int Wn, int ldw)
(void)nb;
struct starpu_codelet *codelet = &cl_zpamm;
void (*callback)(void*) = options->profiling ? cl_zpamm_callback : NULL;
if ( morse_desc_islocal( A1, A1m, A1n ) ||
morse_desc_islocal( A2, A2m, A2n ) ||
morse_desc_islocal( V, Vm, Vn ) ||
morse_desc_islocal( W, Wm, Wn ) )
starpu_insert_task(
codelet,
STARPU_VALUE, &op, sizeof(int),
STARPU_VALUE, &side, sizeof(MORSE_enum),
STARPU_VALUE, &storev, sizeof(MORSE_enum),
STARPU_VALUE, &m, sizeof(int),
STARPU_VALUE, &n, sizeof(int),
STARPU_VALUE, &k, sizeof(int),
STARPU_VALUE, &l, sizeof(int),
STARPU_R, RTBLKADDR(A1, MORSE_Complex64_t, A1m, A1n),
STARPU_VALUE, &lda1, sizeof(int),
STARPU_RW, RTBLKADDR(A2, MORSE_Complex64_t, A2m, A2n),
STARPU_VALUE, &lda2, sizeof(int),
STARPU_R, RTBLKADDR(V, MORSE_Complex64_t, Vm, Vn),
STARPU_VALUE, &ldv, sizeof(int),
STARPU_RW, RTBLKADDR(W, MORSE_Complex64_t, Wm, Wn),
STARPU_VALUE, &ldw, sizeof(int),
STARPU_PRIORITY, options->priority,
STARPU_CALLBACK, callback,
0);
void
CORE_zpamm_quark(Quark *quark)
int op;
MORSE_enum side;
int storev;
int M;
int N;
int K;
int L;
MORSE_Complex64_t *A1;
int LDA1;
MORSE_Complex64_t *A2;
int LDA2;
MORSE_Complex64_t *V;
int LDV;
MORSE_Complex64_t *W;
int LDW;
A1 = (MORSE_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[0]);
A2 = (MORSE_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[1]);
V = (MORSE_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[2]);
W = (MORSE_Complex64_t *)STARPU_MATRIX_GET_PTR(descr[3]);
starpu_codelet_unpack_args(cl_arg, &op, &side, &storev, &M, &N, &K, &L, &LDA1, &LDA2, &LDV, &LDW);
CORE_zpamm( op, side, storev, M, N, K, L, A1, LDA1, A2, LDA2, V, LDV, W, LDW);
