GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
4500fdc3
4500fdc3
9 years ago
THIBAULT Samuel
Downloads
Patches
Avoid duplicate detection if the test ends up working someday
9212cca0
CMakeLists.txt
+6
-6
6 additions, 6 deletions
CMakeLists.txt
6 additions
6 deletions
CMakeLists.txt
6
6
4500fdc3
@@ -625,12 +625,12 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/cmake_modules/")
message
Red
Looking for starpu with starpu_mpi_data_register"
" - starpu_mpi_data_register() test fails in StarPU
ColourReset
message
Red
Check in CMakeFiles/CMakeError.log to figure out why it fails
ColourReset
endif
if
CHAMELEON_SIMULATION
# function detection fails due to conflicting mai
n
# definitions. We know that the StarPU-simgrid-MPI version
# has it anyway.
add_definitions
-DHAVE_STARPU_MPI_DATA_REGISTER
if
# function detection fails due to conflicting main
n
# has it anyway.
add_definitions
endif
endif
endif
if
HWLOC_FOUND AND HWLOC_LIBRARY_DIRS
This diff is collapsed.
Loading
Save comment
