Commit 2b1ffb41 authored by THIBAULT Samuel's avatar THIBAULT Samuel
Also make step6 use MORSE_Distributed_size
parent 34558c7a
...@@ -4,7 +4,7 @@ ...@@ -4,7 +4,7 @@
* of Tennessee Research Foundation. * of Tennessee Research Foundation.
* All rights reserved. * All rights reserved.
* @copyright (c) 2012-2014 Inria. All rights reserved. * @copyright (c) 2012-2014 Inria. All rights reserved.
* @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved. * @copyright (c) 2012-2015 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -110,7 +110,7 @@ int main(int argc, char *argv[]) { ...@@ -110,7 +110,7 @@ int main(int argc, char *argv[]) {
MORSE_Set(MORSE_INNER_BLOCK_SIZE, iparam[IPARAM_IB] ); MORSE_Set(MORSE_INNER_BLOCK_SIZE, iparam[IPARAM_IB] );
#if defined(CHAMELEON_USE_MPI) #if defined(CHAMELEON_USE_MPI)
MPI_Comm_size( MPI_COMM_WORLD, &NMPIPROC ); MORSE_Distributed_size( &NMPIPROC );
/* Check P */ /* Check P */
if ( (iparam[IPARAM_P] > 1) && if ( (iparam[IPARAM_P] > 1) &&
(NMPIPROC % iparam[IPARAM_P] != 0) ) { (NMPIPROC % iparam[IPARAM_P] != 0) ) {
