GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
ced3e88e
ced3e88e
7 years ago
VIGNET Pierre
Downloads
Patches
Cleaner exception handle
d23c0db0
cadbiom/models/clause_constraints/mcl/CLUnfolder.py
+6
-5
6 additions, 5 deletions
6 additions
5 deletions
6
5
ced3e88e
@@ -596,12 +596,13 @@ class CLUnfolder(object):
MODIFIES __lit_cpt for numbering of auxiliary variables (not coding)
if
self
__locked
mess
Trying to compile property while unfolder is locked
raise
MCLException
mess
reporter
self
__dyn_sys
report
symb_t
self
__dyn_sys
symb_tab
raise
MCLException
# syntax analyser and type checker
tree_prop
compile_cond
property_text
symb_t
reporter
# property_text, symb_t, reporter
tree_prop
compile_cond
property_text
self
__dyn_sys
symb_tab
self
__dyn_sys
report
# avoid name collisions of aux var
prop_visitor
CLPropertyVisitor
self
__lit_cpt
tree_prop
accept
prop_visitor
This diff is collapsed.
Loading
Save comment
