Commit ced3e88e authored by VIGNET Pierre's avatar VIGNET Pierre
Cleaner exception handle
parent d23c0db0
...@@ -596,12 +596,13 @@ class CLUnfolder(object): ...@@ -596,12 +596,13 @@ class CLUnfolder(object):
MODIFIES __lit_cpt for numbering of auxiliary variables (not coding) MODIFIES __lit_cpt for numbering of auxiliary variables (not coding)
if self.__locked: if self.__locked:
mess = "Trying to compile property while unfolder is locked" raise MCLException("Trying to compile property while unfolder is locked")
raise MCLException(mess)
reporter = self.__dyn_sys.report
symb_t = self.__dyn_sys.symb_tab
# syntax analyser and type checker # syntax analyser and type checker
tree_prop = compile_cond(property_text, symb_t, reporter) # property_text, symb_t, reporter
self.__dyn_sys.symb_tab,
self.__dyn_sys.report)
# avoid name collisions of aux var # avoid name collisions of aux var
prop_visitor = CLPropertyVisitor(self.__lit_cpt) prop_visitor = CLPropertyVisitor(self.__lit_cpt)
tree_prop.accept(prop_visitor) tree_prop.accept(prop_visitor)
