Commit a0ec97a1 authored by PETIT Manuel's avatar PETIT Manuel
Add fallback tag logic for release CI job
In release pipelines, assign a dummy tag if CI_COMMIT_TAG is undefined : to test job.
parent a5559f49
Pipeline #1097374 failed
...@@ -114,6 +114,12 @@ create_release: ...@@ -114,6 +114,12 @@ create_release:
- chmod +x /usr/local/bin/release-cli - chmod +x /usr/local/bin/release-cli
script: script:
- echo "Creating release and attaching tutorials.zip..." - echo "Creating release and attaching tutorials.zip..."
- # Set a dummy tag if CI_COMMIT_TAG is not defined
- if [ -z "$CI_COMMIT_TAG" ]; then
- export CI_COMMIT_TAG="test-dummy-tag"
- fi
- echo "Using tag: $CI_COMMIT_TAG"
rules: rules:
- if: '$CI_COMMIT_TAG' # Run only on tag pipelines, e.g., for release tags - if: '$CI_COMMIT_TAG' # Run only on tag pipelines, e.g., for release tags
when: always when: always
