Commit 58190b82 authored by PETIT Manuel's avatar PETIT Manuel
Refactor solution and growth handling in GBVP class
Centralize solution and growth copying to improve code clarity and reduce redundancy. Updated file output logic to use pre-copied variables for consistency. Also fixed test to align with updated file format, switching from `.xdmf` to `.h5`.
parent a2fa8a47
Pipeline #1104600 skipped
...@@ -114,9 +114,12 @@ class GBVP(BVP): ...@@ -114,9 +114,12 @@ class GBVP(BVP):
self.set_time(tmin) self.set_time(tmin)
self.growth_scheme.dt = dt self.growth_scheme.dt = dt
current_solution = self.solution.copy(deepcopy=True)
current_growth = self.growth_scheme.get_growth().copy(deepcopy=True)
if store_steps: if store_steps:
self.solution_steps[self.time.current] = self.solution.copy(deepcopy=True) self.solution_steps[self.time.current] = current_solution
self.growth_steps[self.time.current] = self.growth_scheme.get_growth() self.growth_steps[self.time.current] = current_growth
if filename is not None: if filename is not None:
with fe.HDF5File(MPI_COMM_WORLD, filename, 'w') as file: with fe.HDF5File(MPI_COMM_WORLD, filename, 'w') as file:
...@@ -124,8 +127,8 @@ class GBVP(BVP): ...@@ -124,8 +127,8 @@ class GBVP(BVP):
#file.write(self.domain.cdata, "cell_labels") #file.write(self.domain.cdata, "cell_labels")
#file.write(self.domain.bdata, "boundary_labels") #file.write(self.domain.bdata, "boundary_labels")
file.write(self.solution, f'solution_t{self.time.current}') file.write(current_solution, f'solution_t{self.time.current}')
file.write(self.growth_steps[self.time.current], f'growth_t{self.time.current}') file.write(current_growth, f'growth_t{self.time.current}')
# Add parameters related to the domain : sub_domain / sub_boundary # Add parameters related to the domain : sub_domain / sub_boundary
# if MPI_COMM_WORLD.rank == 0: # h5py does not support parallal mode, use only the main process # if MPI_COMM_WORLD.rank == 0: # h5py does not support parallal mode, use only the main process
...@@ -146,14 +149,17 @@ class GBVP(BVP): ...@@ -146,14 +149,17 @@ class GBVP(BVP):
while tmax - self.time.current >= dt: while tmax - self.time.current >= dt:
self.step(dt, **kwargs) self.step(dt, **kwargs)
self.growth_steps[self.time.current] = self.growth_scheme.get_growth().copy(deepcopy=True) self.growth_steps[self.time.current] = current_growth
with fe.HDF5File(MPI_COMM_WORLD, filename, 'a') as file: with fe.HDF5File(MPI_COMM_WORLD, filename, 'a') as file:
self._progressbar.update(self.time.current) self._progressbar.update(self.time.current)
self._progressbar.show() self._progressbar.show()
...@@ -35,7 +35,7 @@ class TestGBVP(unittest.TestCase): ...@@ -35,7 +35,7 @@ class TestGBVP(unittest.TestCase):
def test_run_with_file(self): def test_run_with_file(self):
gbvp = GBVP(self.domain, self.vform, self.bc, growth_scheme=self.growth_scheme) gbvp = GBVP(self.domain, self.vform, self.bc, growth_scheme=self.growth_scheme)
gbvp.info() gbvp.info()
gbvp.run(0, 0.4, 0.2, filename=self.dir.name+'/solution.xdmf', linear_solver='mumps') gbvp.run(0, 0.4, 0.2, filename=self.dir.name+'/solution.h5', linear_solver='mumps')
def test_run_without_file(self): def test_run_without_file(self):
ibvp = GBVP(self.domain, self.vform, self.bc, growth_scheme=self.growth_scheme) ibvp = GBVP(self.domain, self.vform, self.bc, growth_scheme=self.growth_scheme)
