Commit 96196587 authored by zinsmatt's avatar zinsmatt
Remove bbox wrong attribute
parent 2b3606c9
...@@ -160,7 +160,6 @@ def main(args): ...@@ -160,7 +160,6 @@ def main(args):
"ellipses" : pred_ellipses}) "ellipses" : pred_ellipses})
out_data = {"file_name": f, out_data = {"file_name": f,
"bbox": b.tolist(),
"detections": detections_txt, "detections": detections_txt,
"orientation": [], "orientation": [],
"position": [] "position": []
