GitLab
Explore
Primary navigation
Search or go to…
spm
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
spm
0a9a5a41
0a9a5a41
8 years ago
Mathieu Faverge
Downloads
Patches
Add function to updtae expended, and global fields
dfb71d05
Branches containing commit
Tags containing commit
3
3 changed files
spm.c
+76
76 additions, 0 deletions
spm.c
spm.h
+19
-18
19 additions, 18 deletions
spm.h
spm_dofs.c
+5
-50
5 additions, 50 deletions
spm_dofs.c
100 additions
68 deletions
spm.c
76
0a9a5a41
@@ -108,6 +108,82 @@ spmInit( pastix_spm_t *spm )
spm
values
NULL
* @ingroup pastix_spm
* @brief Update all the computed fields based on the static values stored
* @param[in,out] spm
* The sparse matrix to init.
void
spmUpdateFields
pastix_spm_t
spm
* Compute the local expended field for multi-dofs
if
spm
dof
spm
nexp
spm
n
spm
dof
spm
nnzexp
spm
nnz
spm
dof
spm
dof
else
pastix_int_t
i
j
k
dofi
dofj
baseval
pastix_int_t
dofptr
colptr
rowptr
baseval
spmFindBase
spm
colptr
spm
colptr
rowptr
spm
rowptr
dofptr
spm
dofs
spm
nexp
dofptr
spm
n
baseval
spm
nnzexp
switch
spm
fmttype
case
PastixCSR
/* Swap pointers to call CSC */
colptr
spm
rowptr
rowptr
spm
colptr
case
PastixCSC
for
j
j
spm
n
j
colptr
dofj
dofptr
j
dofptr
j
for
k
colptr
k
colptr
k
rowptr
i
rowptr
baseval
dofi
dofptr
i
dofptr
i
spm
nnzexp
dofi
dofj
break
case
PastixIJV
for
k
k
spm
nnz
k
rowptr
colptr
i
rowptr
baseval
j
colptr
baseval
dofi
dofptr
i
dofptr
i
dofj
dofptr
j
dofptr
j
spm
nnzexp
dofi
dofj
/* TODO: add communicator */
spm
gN
spm
n
spm
gnnz
spm
nnz
spm
gNexp
spm
nexp
spm
gnnzexp
spm
nnzexp
This diff is collapsed.
spm.h
19
18
0a9a5a41
@@ -61,32 +61,32 @@ typedef enum pastix_driver_e {
struct
pastix_spm_s
int
mtxtype
/**< Matrix structure: PastixGeneral, PastixSymmetric
or PastixHermitian. */
or PastixHermitian.
pastix_coeftype_t
flttype
/**< avals datatype: PastixPattern, PastixFloat, PastixDouble,
PastixComplex32 or PastixComplex64 */
pastix_fmttype_t
fmttype
/**< Matrix storage format: PastixCSC, PastixCSR, PastixIJV */
pastix_fmttype_t
fmttype
pastix_int_t
gN
/**< Global number of vertices in the compressed graph
pastix_int_t
n
/**< Local number of vertices in the compressed graph */
pastix_int_t
gnnz
/**< Global number of non zeroes in the compressed graph
pastix_int_t
nnz
/**< Local number of non zeroes in the compressed graph */
pastix_int_t
gN
(Computed)
pastix_int_t
n
pastix_int_t
gnnz
(Computed)
pastix_int_t
nnz
pastix_int_t
gNexp
pastix_int_t
nexp
pastix_int_t
gnnzexp
pastix_int_t
nnzexp
pastix_int_t
gNexp
(Computed)
pastix_int_t
nexp
(Computed)
pastix_int_t
gnnzexp
(Computed)
pastix_int_t
nnzexp
(Computed)
pastix_int_t
dof
/**< Number of degrees of freedom per unknown,
if > 0, constant degree of freedom
otherwise, irregular degree of freedom (refer to dofs) */
pastix_int_t
dofs
/**< Array of the first column of each element in the
expanded matrix [+baseval] */
pastix_order_t
layout
/**< PastixColMajor, or PastixRowMajor */
pastix_order_t
layout
pastix_int_t
colptr
/**< List of indirections to rows for each vertex [+baseval] */
pastix_int_t
rowptr
/**< List of edges for each vertex [+baseval] */
pastix_int_t
loc2glob
/**< Corresponding numbering from local to global [+baseval] */
void
values
/**< Values stored in the matrix */
pastix_int_t
colptr
pastix_int_t
rowptr
pastix_int_t
loc2glob
void
values
int
@@ -145,6 +145,7 @@ void spmInit( pastix_spm_t *spm );
void
spmExit
pastix_spm_t
spm
pastix_spm_t
spmCopy
const
pastix_spm_t
spm
void
spmBase
pastix_spm_t
spm
int
baseval
void
spmUpdateFields
pastix_spm_t
spm
int
spmConvert
int
ofmttype
pastix_spm_t
ospm
void
spm2Dense
const
pastix_spm_t
spm
pastix_int_t
spmFindBase
const
pastix_spm_t
spm
spm_dofs.c
5
50
0a9a5a41
@@ -44,15 +44,11 @@ spmDofExtend( const int type,
* Generate constant dof
if
type
newspm
dof
dof
newspm
nexp
spm
n
dof
newspm
gNexp
spm
gN
dof
newspm
nnzexp
spm
nnz
dof
dof
newspm
gnnzexp
spm
gnnz
dof
dof
newspm
dof
dof
else
pastix_int_t
i
j
k
dofi
dofj
baseval
pastix_int_t
dofptr
colptr
rowptr
pastix_int_t
i
dofi
baseval
pastix_int_t
dofptr
baseval
spmFindBase
spm
@@ -69,51 +65,10 @@ spmDofExtend( const int type,
dofi
rand
dof
dofptr
dofptr
dofi
newspm
nexp
dofptr
baseval
newspm
gNexp
newspm
nexp
* Count the number of non zeroes
newspm
nnzexp
colptr
newspm
colptr
rowptr
newspm
rowptr
dofptr
newspm
dofs
switch
spm
fmttype
case
PastixCSR
colptr
newspm
rowptr
rowptr
newspm
colptr
case
PastixCSC
for
j
j
newspm
n
j
colptr
dofj
dofptr
j
dofptr
j
for
k
colptr
k
colptr
k
rowptr
i
rowptr
baseval
dofi
dofptr
i
dofptr
i
newspm
nnzexp
dofi
dofj
break
case
PastixIJV
for
k
k
newspm
nnz
k
rowptr
colptr
i
rowptr
baseval
j
colptr
baseval
dofi
dofptr
i
dofptr
i
dofj
dofptr
j
dofptr
j
newspm
nnzexp
dofi
dofj
newspm
gnnzexp
newspm
nnzexp
spmUpdateFields
newspm
switch
spm
flttype
case
PastixFloat
s_spmDofExtend
newspm
Loading
Save comment
