Commit a8dc80c7 authored by antoine's avatar antoine
update
parent 1e2c6ccf
No preview for this file type
...@@ -46,12 +46,14 @@ my.theme <- theme_bw() + ...@@ -46,12 +46,14 @@ my.theme <- theme_bw() +
legend.background = element_rect(fill = "transparent"), legend.background = element_rect(fill = "transparent"),
legend.key = element_rect(fill = "transparent", colour = NA), legend.key = element_rect(fill = "transparent", colour = NA),
my.comms <- comms.stats[comms.stats$s != 1 & comms.stats$iter < 12,] my.comms <- comms.stats[comms.stats$s != 1 & comms.stats$iter < 9 &
comms.stats$s < 9,]
print(my.comms)
plt.comms <- ggplot(data=my.comms, plt.comms <- ggplot(data=my.comms,
aes(x=as.factor(iter),y=total_volume,color=abs(s),shape=ifelse(s==-1,"21","22"))) + aes(x=as.factor(iter),y=total_volume,color=as.factor(abs(s)),shape=ifelse(s==-1,"21","22"))) +
geom_line(data=my.comms[my.comms$s != -1,],aes(group=s),linewidth=2) + geom_line(data=my.comms[my.comms$s != -1,],aes(group=s),linewidth=2) +
geom_point(data=my.comms[my.comms$s != -1,],size=10) + geom_point(data=my.comms[my.comms$s != -1,],size=10) +
scale_color_gradient(name="s",low="#18730a",high="#1ee000") + scale_color_manual(name="s",values=c(`2`="#18730a",`4`="#1ee000",`8`="#00ff00")) +
geom_line(data=my.comms[my.comms$s == -1,],aes(group=s),color="#8a0608",linewidth=2) + geom_line(data=my.comms[my.comms$s == -1,],aes(group=s),color="#8a0608",linewidth=2) +
geom_point(data=my.comms[my.comms$s == -1,],color="#8a0608",size=10) + geom_point(data=my.comms[my.comms$s == -1,],color="#8a0608",size=10) +
scale_shape(solid=FALSE,name="Approach", scale_shape(solid=FALSE,name="Approach",
...@@ -52,9 +52,11 @@ pdfname <- "strong.pdf" ...@@ -52,9 +52,11 @@ pdfname <- "strong.pdf"
# here rome is on a weak scalability regime # here rome is on a weak scalability regime
rome <- read.csv("csv/rome.4.strong.csv") rome <- read.csv("csv/rome.4.strong.csv")
skylake <- read.csv("csv/skylake.4.csv") skylake <- read.csv("csv/skylake.4.csv")
print("???")
for (nodes in c(16,36,64)) { for (nodes in c(16,36,64)) {
rome <- rbind(rome, read.csv(paste("csv/rome",nodes,"strong","csv",sep="."))) rome <- rbind(rome, read.csv(paste("csv/rome",nodes,"strong","csv",sep=".")))
skylake <- rbind(skylake, read.csv(paste("csv/skylake",nodes,"csv",sep="."))) skylake <- rbind(skylake, read.csv(paste("csv/skylake",nodes,"csv",sep=".")))
print("???")
rome$arch = "rome" rome$arch = "rome"
rome$ncpu = 128 rome$ncpu = 128
...@@ -62,6 +64,11 @@ skylake$arch = "skylake" ...@@ -62,6 +64,11 @@ skylake$arch = "skylake"
skylake$ncpu = 48 skylake$ncpu = 48
tbl <- rbind(rome,skylake) tbl <- rbind(rome,skylake)
print("===") print("===")
tbl <- subset(tbl, arch == "rome" & X == 144*1024 | arch =="skylake" & X == 64*1024)
tbl <- subset(tbl, cell_ns != 16)
tbl <- subset(tbl, s <= iter)
tbl <- subset(tbl, iter == 38)
print(tbl)
#tbl <- rbind(tbl,tbl_64) #tbl <- rbind(tbl,tbl_64)
...@@ -73,6 +80,7 @@ stats <- ddply(tbl, ...@@ -73,6 +80,7 @@ stats <- ddply(tbl,
summarize, med_time=median(time), summarize, med_time=median(time),
min_time=min(time), min_time=min(time),
max_time=max(time)) max_time=max(time))
print(stats)
simpleCap <- function(x) { simpleCap <- function(x) {
s <- strsplit(x, " ")[[1]] s <- strsplit(x, " ")[[1]]
...@@ -120,15 +128,16 @@ my_labeller <- function(data) { ...@@ -120,15 +128,16 @@ my_labeller <- function(data) {
stats$med_floprate <- with(stats,iter*9*X*Y/med_time/10^9) stats$med_floprate <- with(stats,iter*9*X*Y/med_time/10^9)
stats$max_floprate <- with(stats,iter*9*X*Y/max_time/10^9) stats$max_floprate <- with(stats,iter*9*X*Y/max_time/10^9)
stats$min_floprate <- with(stats,iter*9*X*Y/min_time/10^9) stats$min_floprate <- with(stats,iter*9*X*Y/min_time/10^9)
color_values <- c(`0`="#8a0608",`4`="#146e2c",`16`="#27c250",`40`="#1df557") color_values <- c(`0`="#8a0608",`4`="#146e2c",`16`="#27c250",`38`="#1df557")
my.tbl <- stats#"[stats$arch == "skylake",] my.tbl <- stats#"[stats$arch == "skylake",]
plt <- ggplot(data = my.tbl,aes(x=P,y=100*med_floprate/(P*ncpu*9/cell_ns), #iter/med_time, plt <- ggplot(data = my.tbl,aes(x=P,y=100*med_floprate/(P*ncpu*9/cell_ns), #iter/med_time,
fill=as.factor(s),color=as.factor(s))) + fill=as.factor(s),color=as.factor(s))) +
#geom_ribbon(aes(ymin=iter/min_time,ymax=iter/max_time),alpha=0.2) + #geom_ribbon(aes(ymin=iter/min_time,ymax=iter/max_time),alpha=0.2) +
# geom_ribbon(aes(ymin=min_floprate,ymax=max_floprate),alpha=0.2) + # geom_ribbon(aes(ymin=min_floprate,ymax=max_floprate),alpha=0.2) +
geom_ribbon(aes(ymin=100*min_floprate/(P*ncpu*9/cell_ns),ymax=100*max_floprate/(P*ncpu*9/cell_ns)),alpha=0.2) + # geom_ribbon(aes(ymin=100*min_floprate/(P*ncpu*9/cell_ns),ymax=100*max_floprate/(P*ncpu*9/cell_ns)),alpha=0.2) +
geom_line() + geom_line(linewidth=4) +
geom_point(shape=21,size=10,fill=NA) + geom_point(shape=21,stroke=3,size=8,fill="white") +
geom_point(shape=21,stroke=3,size=8,fill=NA) +
scale_y_continuous(guide=guide_axis(check.overlap=TRUE), scale_y_continuous(guide=guide_axis(check.overlap=TRUE),
limits=c(0,NA), limits=c(0,NA),
labels = function(x) format(x,big.mark=",",scientific=FALSE), labels = function(x) format(x,big.mark=",",scientific=FALSE),
...@@ -147,4 +156,4 @@ plt <- ggplot(data = my.tbl,aes(x=P,y=100*med_floprate/(P*ncpu*9/cell_ns), #iter ...@@ -147,4 +156,4 @@ plt <- ggplot(data = my.tbl,aes(x=P,y=100*med_floprate/(P*ncpu*9/cell_ns), #iter
values=color_values)+ values=color_values)+
my.theme my.theme
ggsave(pdfname, plt, width=60, height=40, units="cm", device=cairo_pdf, bg="transparent") ggsave(pdfname, plt, width=60, height=36, units="cm", device=cairo_pdf, bg="transparent")
