Commit fc3654cc authored by PRUVOST Florent's avatar PRUVOST Florent
fix spelling
parent 836a9a41
...@@ -23,7 +23,7 @@ ...@@ -23,7 +23,7 @@
# some variables has been set to 1 instead of ON to make the chameleon_config.h file # some variables have been set to 1 instead of ON to make the chameleon_config.h file
# restore ON when necessary # restore ON when necessary
if (CHAMELEON_USE_CUDA) if (CHAMELEON_USE_CUDA)
set(CHAMELEON_USE_CUDA "ON") set(CHAMELEON_USE_CUDA "ON")
