Commit fbd087b7 authored by Mathieu Faverge's avatar Mathieu Faverge
Disable GPU on LQ case as it is not implemented yet
parent 0ef1dcea
1 merge request!81Migration QR/LQ
...@@ -112,8 +112,8 @@ ...@@ -112,8 +112,8 @@
* V = [V1] [V2]. * V = [V1] [V2].
* The size of the trapezoidal block V2 is determined by the parameter L, * The size of the trapezoidal block V2 is determined by the parameter L,
* where 0 <= L <= K; V2 is upper trapezoidal, consisting of the first L * where 0 <= L <= K; V2 is lower trapezoidal, consisting of the first L
* rows of a K-by-K upper triangular matrix. If L=K, V2 is upper triangular; * rows of a K-by-K upper triangular matrix. If L=K, V2 is lower triangular;
* if L=0, there is no trapezoidal block, hence V = V1 is rectangular. * if L=0, there is no trapezoidal block, hence V = V1 is rectangular.
* If side = MorseLeft: C = [A] where A is K-by-N, B is M-by-N and V is K-by-M. * If side = MorseLeft: C = [A] where A is K-by-N, B is M-by-N and V is K-by-M.
...@@ -54,7 +54,7 @@ static void cl_ztpmlqt_cpu_func(void *descr[], void *cl_arg) ...@@ -54,7 +54,7 @@ static void cl_ztpmlqt_cpu_func(void *descr[], void *cl_arg)
V, ldv, T, ldt, A, lda, B, ldb, WORK ); V, ldv, T, ldt, A, lda, B, ldb, WORK );
#if defined(CHAMELEON_USE_CUDA) #if defined(CHAMELEON_USE_CUDA) && 0
static void cl_ztpmlqt_cuda_func(void *descr[], void *cl_arg) static void cl_ztpmlqt_cuda_func(void *descr[], void *cl_arg)
MORSE_enum side; MORSE_enum side;
...@@ -100,7 +100,8 @@ static void cl_ztpmlqt_cuda_func(void *descr[], void *cl_arg) ...@@ -100,7 +100,8 @@ static void cl_ztpmlqt_cuda_func(void *descr[], void *cl_arg)
* Codelet definition * Codelet definition
CODELETS(ztpmlqt, 5, cl_ztpmlqt_cpu_func, cl_ztpmlqt_cuda_func, STARPU_CUDA_ASYNC) CODELETS_CPU(ztpmlqt, 5, cl_ztpmlqt_cpu_func)
//CODELETS(ztpmlqt, 5, cl_ztpmlqt_cpu_func, cl_ztpmlqt_cuda_func, STARPU_CUDA_ASYNC)
void void
MORSE_TASK_ztpmlqt( const MORSE_option_t *options, MORSE_TASK_ztpmlqt( const MORSE_option_t *options,
