Commit f8896238 authored by PRUVOST Florent's avatar PRUVOST Florent Committed by Mathieu Faverge
update available build variants with guix
parent 71b28393
...@@ -329,13 +329,14 @@ we encourage users to use [[sec:spack][Spack]]. ...@@ -329,13 +329,14 @@ we encourage users to use [[sec:spack][Spack]].
Notice that there exist several build variants Notice that there exist several build variants
- chameleon (default) : with starpu - with mpi - chameleon (default) : with starpu - with mpi
- chameleon-mkl-mt : default version but with Intel MKL multithreaded to replace OpenBlas
- chameleon-cuda : with starpu - with mpi - with cuda - chameleon-cuda : with starpu - with mpi - with cuda
- chameleon-fxt : with starpu - with mpi - with fxt
- chameleon-simgrid : with starpu - with mpi - with simgrid - chameleon-simgrid : with starpu - with mpi - with simgrid
- chameleon-openmp : with openmp - without mpi - chameleon-openmp : with openmp - without mpi
- chameleon-parsec : with parsec - without mpi - chameleon-parsec : with parsec - without mpi
- chameleon-quark : with quark - without mpi - chameleon-quark : with quark - without mpi
Change the version Change the version
#+begin_src sh #+begin_src sh
guix install chameleon --with-branch=chameleon=master guix install chameleon --with-branch=chameleon=master
...@@ -349,8 +350,8 @@ we encourage users to use [[sec:spack][Spack]]. ...@@ -349,8 +350,8 @@ we encourage users to use [[sec:spack][Spack]].
Change some dependencies Change some dependencies
# install chameleon with intel mkl to replace openblas and nmad to replace openmpi # install chameleon with intel mkl to replace openblas, nmad to replace openmpi and starpu with fxt
guix install chameleon --with-input=openblas=mkl --with-input=openmpi=nmad guix install chameleon --with-input=openblas=mkl --with-input=openmpi=nmad --with-input=starpu=starpu-fxt
#+end_src #+end_src
*** Generate a Chameleon Docker image with Guix *** Generate a Chameleon Docker image with Guix
