GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
f47b447d
f47b447d
3 years ago
Mathieu Faverge
Downloads
Patches
starpu: make sure starpu is compiled with cuda support when CUDA is enabled
e9e1093b
Branches containing commit
Tags containing commit
1 merge request
!291
StarPU: make sure starpu is compiled with cuda support when CUDA is enabled
runtime/starpu/CMakeLists.txt
+8
8 additions, 0 deletions
8 additions
8
f47b447d
@@ -125,6 +125,14 @@ if ( STARPU_FOUND )
message
Blue
Add definition HAVE_STARPU_MPI_COMM_GET_ATTR
ColourReset
message
Blue
ColourReset
endif
endif
endif
endif
if
CHAMELEON_USE_CUDA AND NOT CHAMELEON_SIMULATION
check_function_exists
starpu_cublas_get_local_handle HAVE_STARPU_CUBLAS_GET_LOCAL_HANDLE
if
NOT HAVE_STARPU_CUBLAS_GET_LOCAL_HANDLE
message
FATAL_ERROR
"The detected StarPU library does not include cublas support. Please disable CHAMELEON_USE_CUDA or provide a StarPU library with cublas support."
endif
endif
morse_cmake_required_unset
endif
STARPU_FOUND
endif
STARPU_FOUND
This diff is collapsed.
Loading
Save comment
