GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
f3fc8b9b
f3fc8b9b
6 years ago
Mathieu Faverge
Downloads
Patches
Remove OOC testings for now
9dc19a30
timing/CTestLists.cmake
+26
-26
26 additions, 26 deletions
26 additions
26 deletions
26
26
f3fc8b9b
@@ -62,32 +62,32 @@ if (NOT CHAMELEON_SIMULATION)
endforeach
endforeach
endforeach
endforeach
if
CHAMELEON_SCHED_STARPU
if ( CHAMELEON_SCHED_STARPU )
foreach
cat
TEST_CATEGORIES
foreach(cat ${TEST_CATEGORIES})
foreach
prec
RP_CHAMELEON_PRECISIONS
foreach(prec ${RP_CHAMELEON_PRECISIONS})
string
TOUPPER
prec
PREC
string(TOUPPER ${prec} PREC)
if
CHAMELEON_PREC_
PREC
if (CHAMELEON_PREC_${PREC})
foreach
test
TESTLIST
foreach(test ${TESTLIST})
add_test
time_ooc_
cat
_
prec
test
MPI_CMD_
cat
./time_
prec
test
_tile
TEST_CMD_
cat
--ooc --check
add_test(time_ooc_${cat}_${prec}${test} ${MPI_CMD_${cat}} ./time_${prec}${test}_tile ${TEST_CMD_${cat}} --ooc --check)
set_tests_properties
time_ooc_
cat
_
prec
test
PROPERTIES
set_tests_properties(time_ooc_${cat}_${prec}${test} PROPERTIES
ENVIRONMENT
"STARPU_DISK_SWAP=/tmp;STARPU_LIMIT_CPU_MEM=1"
ENVIRONMENT "STARPU_DISK_SWAP=/tmp;STARPU_LIMIT_CPU_MEM=1"
endforeach
endforeach()
endif
endif()
endforeach
endforeach()
foreach
prec
CHAMELEON_PRECISIONS_ZC
foreach(prec ${CHAMELEON_PRECISIONS_ZC})
string
TOUPPER
prec
PREC
if
CHAMELEON_PREC_
PREC
foreach
test
TESTLIST_ZC
foreach(test ${TESTLIST_ZC})
add_test
time_ooc_
cat
_
prec
test
MPI_CMD_
cat
./time_
prec
test
_tile
TEST_CMD_
cat
--ooc --check
time_ooc_
cat
_
prec
test
PROPERTIES
ENVIRONMENT
endforeach
endforeach()
endif
endif()
endforeach
endforeach()
endforeach
endforeach()
endif
endif()
if
CHAMELEON_USE_MPI AND MPI_C_FOUND
if
set
TEST_CATEGORIES mpi
set
TEST_CATEGORIES mpi
This diff is collapsed.
Loading
Save comment
