Commit f2009582 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'issue51/cudablas_headers' into 'master'
Fix issue #51 with cudablas headers
Closes #51
See merge request !67
parents e4c0d244 42ce5fce
1 merge request!67Fix issue #51 with cudablas headers
with 0 additions and 20 deletions
...@@ -21,7 +21,6 @@ ...@@ -21,7 +21,6 @@
#include "cudablas.h" #include "cudablas.h"
#include "cudablas/cudablas_z.h"
#if !defined(CHAMELEON_USE_CUBLAS_V2) #if !defined(CHAMELEON_USE_CUBLAS_V2)
#error "This file requires cublas api v2 support" #error "This file requires cublas api v2 support"
...@@ -23,7 +23,6 @@ ...@@ -23,7 +23,6 @@
#if defined(CHAMELEON_USE_MAGMA) #if defined(CHAMELEON_USE_MAGMA)
int CUDA_zgelqt( int CUDA_zgelqt(
int int
CUDA_zgemerge( MORSE_enum side, MORSE_enum diag, CUDA_zgemerge( MORSE_enum side, MORSE_enum diag,
int CUDA_zgemm(MORSE_enum transa, MORSE_enum transb, int CUDA_zgemm(MORSE_enum transa, MORSE_enum transb,
int m, int n, int k, int m, int n, int k,
int CUDA_zgeqrt( int CUDA_zgeqrt(
#if defined(HAVE_MAGMA_GETRF_INCPIV_GPU) #if defined(HAVE_MAGMA_GETRF_INCPIV_GPU)
int CUDA_zhemm(MORSE_enum side, MORSE_enum uplo, int CUDA_zhemm(MORSE_enum side, MORSE_enum uplo,
int m, int n, int m, int n,
int CUDA_zher2k(MORSE_enum uplo, MORSE_enum trans, int CUDA_zher2k(MORSE_enum uplo, MORSE_enum trans,
int n, int k, int n, int k,
int int
CUDA_zherfb( MORSE_enum uplo, int n, CUDA_zherfb( MORSE_enum uplo, int n,
int CUDA_zherk( MORSE_enum uplo, MORSE_enum trans, int CUDA_zherk( MORSE_enum uplo, MORSE_enum trans,
...@@ -25,7 +25,6 @@ ...@@ -25,7 +25,6 @@
int int
CUDA_zlarfb(MORSE_enum side, MORSE_enum trans, CUDA_zlarfb(MORSE_enum side, MORSE_enum trans,
int CUDA_zlauum( int CUDA_zlauum(
int CUDA_zpotrf( int CUDA_zpotrf(
int CUDA_zsymm(MORSE_enum side, MORSE_enum uplo, int CUDA_zsymm(MORSE_enum side, MORSE_enum uplo,
int CUDA_zsyr2k( int CUDA_zsyr2k(
MORSE_enum uplo, MORSE_enum trans, MORSE_enum uplo, MORSE_enum trans,
int CUDA_zsyrk(MORSE_enum uplo, MORSE_enum trans, int CUDA_zsyrk(MORSE_enum uplo, MORSE_enum trans,
int int
CUDA_ztpmqrt( MORSE_enum side, MORSE_enum trans, CUDA_ztpmqrt( MORSE_enum side, MORSE_enum trans,
