GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
f08ed1d4
f08ed1d4
9 months ago
Mathieu Faverge
Downloads
Patches
cmake/gpucublas: Move the cuda toolkit detection to better select the inclusion of extra kernels
806a2160
1 merge request
!470
Issue #127: Fix the protection of half precision kernels with cuda
2
2 changed files
gpucublas/CMakeLists.txt
+42
42 additions, 0 deletions
gpucublas/compute/CMakeLists.txt
+21
-19
21 additions, 19 deletions
63 additions
19 deletions
42
f08ed1d4
@@ -26,6 +26,48 @@
@@ -26,6 +26,48 @@
# Add CUDA kernel if compiler and toolkit are available
include
CheckLanguage
check_language
CUDA
if
CMAKE_CUDA_COMPILER
enable_language
CUDA
find_package
CUDAToolkit
else
message
STATUS
"CUDA language is not supported"
endif
if
CUDAToolkit_FOUND
set
GPUCUBLAS_HAVE_CUDA_TOOLKIT ON CACHE INTERNAL
"Indicate if cuda kernels are enabled or not"
FORCE
include
SetCMakeCudaArchitectures
if
CUDAToolkit_VERSION VERSION_GREATER_EQUAL
"7.5"
set
GPUCUBLAS_HAVE_CUDA_HALF ON CACHE INTERNAL
"Indicate if half precision support is enabled or not"
FORCE
else
set
GPUCUBLAS_HAVE_CUDA_HALF OFF CACHE INTERNAL
FORCE
endif
else
set
GPUCUBLAS_HAVE_CUDA_TOOLKIT OFF CACHE INTERNAL
FORCE
set
FORCE
endif
if
##morse_cmake_required_set( CUBLAS )
set
CMAKE_REQUIRED_LIBRARIES CUDA::CUBLAS
check_function_exists
cublasHgemm GPUCUBLAS_HAVE_CUBLASHGEMM
if
message
Blue
Add definition HAVE_CUBLASHGEMM
ColourReset
endif
cublasGemmEx GPUCUBLAS_HAVE_CUBLASGEMMEX
if
message
Blue
Add definition HAVE_CUBLASGEMMEX
ColourReset
endif
morse_cmake_required_unset
endif
add_subdirectory
include
add_subdirectory
include
add_subdirectory
compute
add_subdirectory
compute
add_subdirectory
eztrace_module
add_subdirectory
eztrace_module
This diff is collapsed.
21
19
f08ed1d4
@@ -56,24 +56,15 @@ set(ZSRC
cuda_zunmqrt.c
cuda_zunmqrt.c
if
include
CheckLanguage
check_language
CUDA
if
CMAKE_CUDA_COMPILER
enable_language
CUDA
find_package
CUDAToolkit
else
message
STATUS
endif
if
CUDAToolkit_FOUND
include
set
ZSRC
set
ZSRC
ZSRC
ZSRC
cuda_zlag2c.cu
cuda_zlag2c.cu
endif
if
set
ZSRC
ZSRC
cuda_dlag2h.cu
cuda_dlag2h.cu
endif
endif
@@ -102,13 +93,24 @@ precisions_rules_py(
set
GPUCUBLAS_SRCS
set
GPUCUBLAS_SRCS
GPUCUBLAS_SRCS_GENERATED
cuda_hgemm.c
cuda_gemmex.c
cudaglobal.c
cudaglobal.c
if
set
GPUCUBLAS_SRCS
GPUCUBLAS_SRCS
cuda_hgemm.c
# Need to use CXX compiler to have the __half support and access to cublasHgemm()
set_source_files_properties
cuda_hgemm.c PROPERTIES LANGUAGE CXX
endif
if
set
GPUCUBLAS_SRCS
GPUCUBLAS_SRCS
cuda_gemmex.c
endif
# Force generation of sources
Loading
Save comment
