Commit efb25dc1 authored by Mathieu Faverge's avatar Mathieu Faverge
Add parsec testings in gitlab conf
parent 1226e7d0
1 merge request!92Fix issue #8 and #4 - gitlab parsec
...@@ -78,6 +78,18 @@ build_quark: ...@@ -78,6 +78,18 @@ build_quark:
BUILD_OPTIONS: "-DCHAMELEON_SCHED_QUARK=ON" BUILD_OPTIONS: "-DCHAMELEON_SCHED_QUARK=ON"
VERSION: quark VERSION: quark
build_parsec:
<<: *build_script
artifacts:
expire_in: 48 hours
paths:
- build
- chameleon_parsec.log
variables:
BUILD_OPTIONS: "-DCHAMELEON_SCHED_PARSEC=ON"
VERSION: parsec
test_starpu_branches: test_starpu_branches:
<<: *test_script <<: *test_script
variables: variables:
...@@ -186,12 +198,49 @@ test_quark_master: ...@@ -186,12 +198,49 @@ test_quark_master:
only: only:
- master@solverstack/chameleon - master@solverstack/chameleon
test_parsec_branches:
<<: *test_script
variables:
TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s\""
VERSION: parsec
dependencies:
- build_parsec
artifacts:
expire_in: 48 hours
paths:
- build
- chameleon_parsec.lcov
only:
- branches
except:
- master
test_parsec_master:
<<: *test_script
variables:
TESTS_RESTRICTION: "-R \"test_shm_|test_mpi_\""
VERSION: parsec
dependencies:
- build_parsec
artifacts:
expire_in: 48 hours
paths:
- build
only:
sonar: sonar:
stage: analysis stage: analysis
dependencies: dependencies:
- test_starpu_master - test_starpu_master
- test_starpu_simgrid_master - test_starpu_simgrid_master
- test_quark_master - test_quark_master
- test_parsec_master
artifacts: artifacts:
name: chameleon_analysis name: chameleon_analysis
expire_in: 1 week expire_in: 1 week
...@@ -206,6 +255,7 @@ sonar: ...@@ -206,6 +255,7 @@ sonar:
- lcov -a $PWD/chameleon_starpu.lcov - lcov -a $PWD/chameleon_starpu.lcov
-a $PWD/chameleon_starpu_simgrid.lcov -a $PWD/chameleon_starpu_simgrid.lcov
-a $PWD/chameleon_quark.lcov -a $PWD/chameleon_quark.lcov
-a $PWD/chameleon_parsec.lcov
-o $PWD/chameleon.lcov -o $PWD/chameleon.lcov
- lcov_cobertura.py chameleon.lcov --output chameleon_coverage.xml - lcov_cobertura.py chameleon.lcov --output chameleon_coverage.xml
- ./tools/analysis.sh - ./tools/analysis.sh
...@@ -39,7 +39,7 @@ sonar.sourceEncoding=UTF-8 ...@@ -39,7 +39,7 @@ sonar.sourceEncoding=UTF-8
sonar.c.compiler.charset=UTF-8 sonar.c.compiler.charset=UTF-8
sonar.c.compiler.parser=GCC sonar.c.compiler.parser=GCC
sonar.c.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$ sonar.c.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$
sonar.c.compiler.reportPath=chameleon_starpu.log, chameleon_starpu_simgrid.log, chameleon_quark.log sonar.c.compiler.reportPath=chameleon_starpu.log, chameleon_starpu_simgrid.log, chameleon_quark.log, chameleon_parsec.log
sonar.c.coverage.reportPath=chameleon_coverage.xml sonar.c.coverage.reportPath=chameleon_coverage.xml
sonar.c.cppcheck.reportPath=chameleon_cppcheck.xml sonar.c.cppcheck.reportPath=chameleon_cppcheck.xml
sonar.c.rats.reportPath=chameleon_rats.xml sonar.c.rats.reportPath=chameleon_rats.xml
