Commit ecaa0498 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'ci/change_docker_image' into 'master'
ci: update docker image name
See merge request solverstack/chameleon!248
parents d39d5c16 c3975334
...@@ -17,7 +17,7 @@ ...@@ -17,7 +17,7 @@
- schedules - schedules
.build_script_template: .build_script_template:
image: hpclib/hiepacs image: registry.gitlab.inria.fr/solverstack/docker/distrib
stage: build stage: build
tags: ["large"] tags: ["large"]
script: script:
...@@ -41,7 +41,7 @@ ...@@ -41,7 +41,7 @@
.test_script_template: .test_script_template:
stage: test stage: test
script: script:
...@@ -6,7 +6,7 @@ ...@@ -6,7 +6,7 @@
coverage: coverage:
stage: analyse stage: analyse
script: script:
- export INPUT_FILES="" - export INPUT_FILES=""
coverity: coverity:
dependencies: [] dependencies: []
pages: pages:
stage: deploy stage: deploy
artifacts: artifacts:
release: release:
sonarqube: sonarqube:
