Commit e455a279 authored by Mathieu Faverge's avatar Mathieu Faverge
Update GEPDF_QDWH
parent 0a26f77a
...@@ -99,13 +99,17 @@ chameleon_pzgepdf_parameters( double Li, double *params ) ...@@ -99,13 +99,17 @@ chameleon_pzgepdf_parameters( double Li, double *params )
* @param[out] B2, TS2, TT2, Q2, D2 * @param[out] B2, TS2, TT2, Q2, D2
* Set of workspace that match the size of H for the QR iteration * Set of workspace that match the size of H for the QR iteration
* @param[out] gemm_ws
* Pointer to the workspace data structure used by the GEMM operation
static inline void static inline void
chameleon_pzgepdf_qdwh_init( const CHAM_desc_t *U, const CHAM_desc_t *H, chameleon_pzgepdf_qdwh_init( const CHAM_desc_t *U, const CHAM_desc_t *H,
libhqr_tree_t *qrtreeT, libhqr_tree_t *qrtreeB, libhqr_tree_t *qrtreeT, libhqr_tree_t *qrtreeB,
CHAM_desc_t *A, CHAM_desc_t *Ut, CHAM_desc_t *A, CHAM_desc_t *Ut,
CHAM_desc_t *B1, CHAM_desc_t *TS1, CHAM_desc_t *TT1, CHAM_desc_t *Q1, CHAM_desc_t *D1, CHAM_desc_t *B1, CHAM_desc_t *TS1, CHAM_desc_t *TT1, CHAM_desc_t *Q1, CHAM_desc_t *D1,
CHAM_desc_t *B2, CHAM_desc_t *TS2, CHAM_desc_t *TT2, CHAM_desc_t *Q2, CHAM_desc_t *D2 ) CHAM_desc_t *B2, CHAM_desc_t *TS2, CHAM_desc_t *TT2, CHAM_desc_t *Q2, CHAM_desc_t *D2,
void **gemm_ws )
CHAM_context_t *chamctxt; CHAM_context_t *chamctxt;
int ib, nb = U->nb; int ib, nb = U->nb;
...@@ -203,6 +207,12 @@ chameleon_pzgepdf_qdwh_init( const CHAM_desc_t *U, const CHAM_desc_t *H, ...@@ -203,6 +207,12 @@ chameleon_pzgepdf_qdwh_init( const CHAM_desc_t *U, const CHAM_desc_t *H,
U->n, U->m, 0, 0, U->n, U->m, 0, 0,
U->n, U->m, U->p, U->q, U->n, U->m, U->p, U->q,
NULL, NULL, NULL ); NULL, NULL, NULL );
* Allocate the data descriptors for the lookahead if needed
*gemm_ws = CHAMELEON_zgemm_WS_Alloc( ChamNoTrans, ChamNoTrans, NULL, NULL, U );
return; return;
...@@ -425,7 +435,7 @@ chameleon_pzgeqdwh_condest_qr( CHAM_context_t *chamctxt, ...@@ -425,7 +435,7 @@ chameleon_pzgeqdwh_condest_qr( CHAM_context_t *chamctxt,
chameleon_pzgepdf_qdwh_qrstep( int do_qr, int last, double *params, chameleon_pzgepdf_qdwh_qrstep( int do_qr, int last, double *params,
const libhqr_tree_t *qrtreeT, const libhqr_tree_t *qrtreeB, const libhqr_tree_t *qrtreeT, const libhqr_tree_t *qrtreeB,
CHAM_desc_t *U, CHAM_desc_t *U, void *gemm_ws,
CHAM_desc_t *B2, CHAM_desc_t *TS2, CHAM_desc_t *TT2, CHAM_desc_t *Q2, CHAM_desc_t *D2, CHAM_desc_t *B2, CHAM_desc_t *TS2, CHAM_desc_t *TT2, CHAM_desc_t *Q2, CHAM_desc_t *D2,
RUNTIME_sequence_t *sequence, RUNTIME_request_t *request ) RUNTIME_sequence_t *sequence, RUNTIME_request_t *request )
...@@ -474,7 +484,7 @@ chameleon_pzgepdf_qdwh_qrstep( int do_qr, int last, double *params, ...@@ -474,7 +484,7 @@ chameleon_pzgepdf_qdwh_qrstep( int do_qr, int last, double *params,
beta = b / c; beta = b / c;
alpha = ( a - beta ) / sqrt_c; alpha = ( a - beta ) / sqrt_c;
chameleon_pzgemm( ChamNoTrans, ChamConjTrans, chameleon_pzgemm( gemm_ws, ChamNoTrans, ChamConjTrans,
alpha, Q1, Q2, beta, U, alpha, Q1, Q2, beta, U,
sequence, request ); sequence, request );
...@@ -621,6 +631,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t ...@@ -621,6 +631,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t
CHAM_desc_t descB1, descTS1, descTT1, descD1, descQ1, *D1ptr; CHAM_desc_t descB1, descTS1, descTT1, descD1, descQ1, *D1ptr;
CHAM_desc_t descB2, descTS2, descTT2, descD2, descQ2, *D2ptr; CHAM_desc_t descB2, descTS2, descTT2, descD2, descQ2, *D2ptr;
libhqr_tree_t qrtreeT, qrtreeB; libhqr_tree_t qrtreeT, qrtreeB;
void *gemm_ws;
double conv = 100.; double conv = 100.;
double Li, params[3]; double Li, params[3];
...@@ -657,7 +668,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t ...@@ -657,7 +668,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t
&qrtreeT, &qrtreeB, &qrtreeT, &qrtreeB,
&descA, &descUt, &descA, &descUt,
&descB1, &descTS1, &descTT1, &descQ1, &descD1, &descB1, &descTS1, &descTT1, &descQ1, &descD1,
&descB2, &descTS2, &descTT2, &descQ2, &descD2 ); &descB2, &descTS2, &descTT2, &descQ2, &descD2, &gemm_ws );
if ( _zgepdf_qdwh_opt_genD ) { if ( _zgepdf_qdwh_opt_genD ) {
D1ptr = &descD1; D1ptr = &descD1;
D2ptr = &descD2; D2ptr = &descD2;
...@@ -762,7 +773,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t ...@@ -762,7 +773,7 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t
chameleon_pzgepdf_qdwh_qrstep( do_qr, last, params, chameleon_pzgepdf_qdwh_qrstep( do_qr, last, params,
&qrtreeT, &qrtreeB, descU, &qrtreeT, &qrtreeB, descU, gemm_ws,
&descB1, &descTS1, &descTT1, &descQ1, D1ptr, &descB1, &descTS1, &descTT1, &descQ1, D1ptr,
&descB2, &descTS2, &descTT2, &descQ2, D2ptr, &descB2, &descTS2, &descTT2, &descQ2, D2ptr,
sequence_it, request_it ); sequence_it, request_it );
...@@ -859,9 +870,10 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t ...@@ -859,9 +870,10 @@ chameleon_pzgepdf_qdwh( cham_mtxtype_t mtxtype, CHAM_desc_t *descU, CHAM_desc_t
break; break;
default: default:
chameleon_pzgemm( ChamConjTrans, ChamNoTrans, chameleon_pzgemm( gemm_ws, ChamConjTrans, ChamNoTrans,
1., descU, &descA, 1., descU, &descA,
0., descH, sequence, request ); 0., descH,
if ( info ) { if ( info ) {
info->flops += flops_zgemm( descH->m, descH->n, descA.m ); info->flops += flops_zgemm( descH->m, descH->n, descA.m );
