Commit dbd09773 authored by Mathieu Faverge's avatar Mathieu Faverge
Fix missing comment
parent fef0a1a8
1 merge request!407Fix small issues
...@@ -148,6 +148,7 @@ void INSERT_TASK_zsyrk( const RUNTIME_option_t *options, ...@@ -148,6 +148,7 @@ void INSERT_TASK_zsyrk( const RUNTIME_option_t *options,
/* Reduce the C access if needed */ /* Reduce the C access if needed */
accessC = ( beta == 0. ) ? STARPU_W : STARPU_RW; accessC = ( beta == 0. ) ? STARPU_W : STARPU_RW;
/* Refine name */
cl_name = chameleon_codelet_name( cl_name, 2, cl_name = chameleon_codelet_name( cl_name, 2,
A->get_blktile( A, Am, An ), A->get_blktile( A, Am, An ),
C->get_blktile( C, Cm, Cn ) ); C->get_blktile( C, Cm, Cn ) );
