Commit da3de956 authored by PRUVOST Florent's avatar PRUVOST Florent
indent
parent 32552409
...@@ -721,11 +721,11 @@ if( CHAMELEON_SCHED_STARPU ) ...@@ -721,11 +721,11 @@ if( CHAMELEON_SCHED_STARPU )
" - starpu_mpi_comm_rank() test fails in StarPU${ColourReset}") " - starpu_mpi_comm_rank() test fails in StarPU${ColourReset}")
message("-- ${Red}Check in CMakeFiles/CMakeError.log to figure out why it fails${ColourReset}") message("-- ${Red}Check in CMakeFiles/CMakeError.log to figure out why it fails${ColourReset}")
endif() endif()
check_function_exists(starpu_mpi_cached_receive STARPU_MPI_CACHED_RECEIVE) check_function_exists(starpu_mpi_cached_receive STARPU_MPI_CACHED_RECEIVE)
if ( STARPU_MPI_CACHED_RECEIVE ) if ( STARPU_MPI_CACHED_RECEIVE )
set(HAVE_STARPU_MPI_CACHED_RECEIVE 1) set(HAVE_STARPU_MPI_CACHED_RECEIVE 1)
message("-- ${Blue}Add definition HAVE_STARPU_MPI_CACHED_RECEIVE${ColourReset}") message("-- ${Blue}Add definition HAVE_STARPU_MPI_CACHED_RECEIVE${ColourReset}")
endif() endif()
endif() endif()
if(HWLOC_FOUND AND HWLOC_LIBRARY_DIRS) if(HWLOC_FOUND AND HWLOC_LIBRARY_DIRS)
# the RPATH to be used when installing # the RPATH to be used when installing
