GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
d24ef0a2
d24ef0a2
7 years ago
PRUVOST Florent
Downloads
Patches
Load the environment from a shell script to facilitate CI machines setup.
8eb4229c
2
2 changed files
.gitlab-ci-env.sh
+22
22 additions, 0 deletions
.gitlab-ci-env.sh
.gitlab-ci.yml
+10
-12
10 additions, 12 deletions
.gitlab-ci.yml
32 additions
12 deletions
.gitlab-ci-env.sh
0 → 100755
22
d24ef0a2
#!/bin/bash
# custom environment used during CI tests with gitlab ci
# these paths may depend on the runner used, please be careful and add
# the necessary if blocks depending on the machine
export
JAVA_HOME
/usr/lib/jvm/java-8-openjdk-amd64
export
PATH
/builds/sonar/lcov-to-cobertura-xml-1.6/lcov_cobertura:
$PATH
export
PATH
/builds/sonar/sonar-scanner-2.9.0.670/bin:
$PATH
export
QUARK_DIR
/builds/install/quark
export
PARSEC_DIR
/builds/install/parsec
export
STARPU_DIR
/builds/install/starpu
if
$1
"simu"
then
export
STARPU_DIR
/builds/install/starpu-simgrid
export
SIMGRID_DIR
/builds/install/simgrid
fi
export
PKG_CONFIG_PATH
$PARSEC_DIR
/lib/pkgconfig:
$PKG_CONFIG_PATH
export
PKG_CONFIG_PATH
$STARPU_DIR
/lib/pkgconfig:
$PKG_CONFIG_PATH
This diff is collapsed.
.gitlab-ci.yml
10
12
d24ef0a2
starpu
script
git submodule init
git submodule update
mkdir build
source .gitlab-ci-env.sh
--init --recursive
mkdir
-p
build
cd build
cmake ..
make -j2
@@ -13,22 +13,20 @@ starpu:
starpu-simgrid
script
git submodule init
mkdir build
source .gitlab-ci-env.sh simu
--init --recursive
mkdir
-p
build
cd build
. $HOME/spack/share/spack/setup-env.sh
spack load hwloc && spack load fxt && spack load simgrid && spack load starpu
cmake .. -DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF
make -j2
ctest -V
quark
script
git submodule init
mkdir build
--init --recursive
mkdir
-p
build
cd build
cmake .. -DCHAMELEON_SCHED_QUARK=ON
make -j2
ctest -V -R test_shm_s
\ No newline at end of file
Loading
Save comment
