Commit c98507dc authored by PRUVOST Florent's avatar PRUVOST Florent
add analysis script
parent a4a26538
......@@ -62,23 +62,6 @@ analysis:
script:
- source .gitlab-ci-env.sh
- git submodule update --init --recursive
- mkdir -p build
- cd build
- export CFLAGS="-O0 -g -fPIC -fdiagnostics-show-option --coverage -fno-inline -Wall"
- export LDFLAGS="--coverage"
- cmake .. -DCHAMELEON_USE_MPI=ON -DCMAKE_INSTALL_PREFIX=$PWD/install -DCMAKE_C_FLAGS="$CFLAGS" -DCMAKE_EXE_LINKER_FLAGS="$LDFLAGS" -DCMAKE_VERBOSE_MAKEFILE=ON
- make -j5 | tee ../chameleon-build.log
- STARPU_SILENT=1 ctest --no-compress-output || /usr/bin/true
- lcov --directory . --capture --output-file ../chameleon.lcov
- cd ..
- genhtml -o coverage chameleon.lcov
- lcov_cobertura.py chameleon.lcov --output chameleon-coverage.xml
- export SOURCES_TO_ANALYZE=`bash -c 'find ./build -type d -name CMakeFiles -prune -o -type d -name Testing -prune -o -type f -regex ".*\.c\|.*\.h" -print && \
find . -path ./build -prune -o -type f -regex "^[^z]*\.c" -print && \
find . -path ./build -prune -o -type f -regex "^[^z]*\.h" ! -name 'lapacke*.h' ! -name 'cblas*.h' -print | xargs'`
- export UNDEFINITIONS="-UCHAMELEON_USE_CUBLAS_V2 -UCHAMELEON_USE_OPENCL"
- cppcheck -v -f --language=c --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingIncludeSystem ${UNDEFINITIONS} ${SOURCES_TO_ANALYZE} ${SOURCES_TO_EXCLUDE} 2> chameleon-cppcheck.xml
- rats -w 3 --xml ${SOURCES_TO_ANALYZE} > chameleon-rats.xml
- sonar-scanner -X -Dsonar.login=077ef775a8b4fe9ba722497ef0511ca6dcfb3fcd > sonar.log
- source ./tools/analysis.sh
only:
- master
\ No newline at end of file
