Commit c1b43338 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'update_contributing_doc' into 'master'
fix url to the upstream + additional info to update the master
See merge request !13
parents cf136686 084e2233
Pipeline #
...@@ -13,7 +13,14 @@ git clone git@gitlab.inria.fr:username/forkname.git ...@@ -13,7 +13,14 @@ git clone git@gitlab.inria.fr:username/forkname.git
Once this is done, you can setup the chameleon repository as the upstream of your clone to simplify the update of your fork repository. Once this is done, you can setup the chameleon repository as the upstream of your clone to simplify the update of your fork repository.
#!shell #!shell
git remote add upstream git@bitbucket.org:solverstack/chameleon.git git remote add upstream git@gitlab.inria.fr:solverstack/chameleon.git
To update your fork with the upstream chameleon's state:
#!shell
git pull upstream master
git push -u origin master
Now, you have your repository configured, and you want to create a new pull request. The first step is to create a branch from the HEAD of the your fork repository. Now, you have your repository configured, and you want to create a new pull request. The first step is to create a branch from the HEAD of the your fork repository.
...@@ -51,4 +58,3 @@ Than apply the patch on your local copy ...@@ -51,4 +58,3 @@ Than apply the patch on your local copy
git apply pr#PR.patch git apply pr#PR.patch
