Commit bd77ba66 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'cti_size' into 'master'
cti: Fix get_size method
See merge request solverstack/chameleon!186
parents 26a4faad f2861742
1 merge request!186cti: Fix get_size method
...@@ -151,13 +151,14 @@ cti_get_size(starpu_data_handle_t handle) ...@@ -151,13 +151,14 @@ cti_get_size(starpu_data_handle_t handle)
starpu_cham_tile_interface_t *cham_tile_interface = starpu_cham_tile_interface_t *cham_tile_interface =
starpu_data_get_interface_on_node( handle, STARPU_MAIN_RAM ); starpu_data_get_interface_on_node( handle, STARPU_MAIN_RAM );
size_t elemsize = CHAMELEON_Element_Size( cham_tile_interface->flttype );
#ifdef STARPU_DEBUG #ifdef STARPU_DEBUG
STARPU_ASSERT_MSG( cham_tile_interface->id == STARPU_CHAM_TILE_INTERFACE_ID, STARPU_ASSERT_MSG( cham_tile_interface->id == STARPU_CHAM_TILE_INTERFACE_ID,
"Error. The given data is not a cham_tile." ); "Error. The given data is not a cham_tile." );
#endif #endif
return cham_tile_interface->allocsize; return cham_tile_interface->tile.m * cham_tile_interface->tile.n * elemsize;
static size_t static size_t
