Commit b9da72bd authored by Mathieu Faverge's avatar Mathieu Faverge
testings: Add a parameter_getvalue_fixdbl function to have float parameters
parent 4b568240
1 merge request!448Testings: Add the possibility to change the precision of the check functions
...@@ -671,6 +671,41 @@ parameters_getvalue_int( const char *name ) ...@@ -671,6 +671,41 @@ parameters_getvalue_int( const char *name )
return -1; return -1;
double
parameters_getvalue_fixdbl( const char *name )
parameter_t *param = parameters;
while( param->helper != NULL )
/* This is not an option, we skip it */
if ( param->name == NULL ) {
param++;
continue;
if ( strcasecmp( name, param->name ) != 0 ) {
param++;
continue;
if ( param->has_arg > 1 ) {
fprintf( stderr, "parameters_getvalue_double should not be called with parameter %s\n", name );
return -1;
if ( param->valtype != TestValDouble ) {
fprintf( stderr, "parameters_getvalue_double has been called with a non float parameter (%s)\n", name );
return -1;
return param->value.dval;
fprintf( stderr, "parameters_getvalue_int could not find parameter %s\n", name );
return -1;
char * char *
parameters_getvalue_str( const char *name ) parameters_getvalue_str( const char *name )
...@@ -229,13 +229,13 @@ void parameters_read( parameter_t *param, const char *values ); ...@@ -229,13 +229,13 @@ void parameters_read( parameter_t *param, const char *values );
void parameters_read_file( const char *filename ); void parameters_read_file( const char *filename );
parameter_t *parameters_getbyname( const char *name ); parameter_t *parameters_getbyname( const char *name );
void parameters_addvalues( parameter_t *param, const char *values ); void parameters_addvalues( parameter_t *param, const char *values );
int parameters_getvalue_int( const char *name );
int parameters_compute_q( int p ); int parameters_compute_q( int p );
parameter_t *parameters_get( int shname ); parameter_t *parameters_get( int shname );
void parameters_getopt_init( char *optstring, struct option **longopts ); void parameters_getopt_init( char *optstring, struct option **longopts );
int parameters_getvalue_int( const char *name ); int parameters_getvalue_int( const char *name );
double parameters_getvalue_fixdbl( const char *name );
char * parameters_getvalue_str( const char *name ); char * parameters_getvalue_str( const char *name );
void parameters_parser( int argc, char **argv ); void parameters_parser( int argc, char **argv );
