Commit b411b555 authored by SYLVAND Guillaume's avatar SYLVAND Guillaume Committed by Mathieu Faverge
Adapt to latest evolutions in hmat-oss CMake
lib is now called libhmat and target is well defined.
parent 2c1e236a
1 merge request!203Integrate H-Mat support via hmat-oss
...@@ -198,7 +198,7 @@ if (CHAMELEON_ENABLE_CUDA AND NOT CHAMELEON_USE_CUDA) ...@@ -198,7 +198,7 @@ if (CHAMELEON_ENABLE_CUDA AND NOT CHAMELEON_USE_CUDA)
endif() endif()
# Enable Hmat-OSS kernels # Enable Hmat-OSS kernels
option(CHAMELEON_USE_HMAT "Enable hmat-oss kernels" OFF) option(CHAMELEON_USE_HMAT "Enable hmat kernels" OFF)
option(CHAMELEON_RUNTIME_SYNC "Enable synchronous task submission when available to debug the code without parallelism" OFF) option(CHAMELEON_RUNTIME_SYNC "Enable synchronous task submission when available to debug the code without parallelism" OFF)
if (CHAMELEON_RUNTIME_SYNC) if (CHAMELEON_RUNTIME_SYNC)
...@@ -271,14 +271,11 @@ add_subdirectory(hqr) ...@@ -271,14 +271,11 @@ add_subdirectory(hqr)
if ( CHAMELEON_USE_HMAT ) if ( CHAMELEON_USE_HMAT )
find_package(HMAT REQUIRED) find_package(HMAT REQUIRED)
if(HMAT_FOUND) if(HMAT_FOUND)
# hmat-oss target is not correctly defined set_target_properties(HMAT::hmat PROPERTIES
add_library(HMAT::hmat-oss INTERFACE IMPORTED)
set_target_properties(HMAT::hmat-oss PROPERTIES
INTERFACE_INCLUDE_DIRECTORIES "${HMAT_INCLUDE_DIRS}" INTERFACE_INCLUDE_DIRECTORIES "${HMAT_INCLUDE_DIRS}"
INTERFACE_COMPILE_DEFINITIONS "${HMAT_DEFINITIONS}" INTERFACE_COMPILE_DEFINITIONS "${HMAT_DEFINITIONS}"
INTERFACE_LINK_DIRECTORIES "${HMAT_LIBRARY_DIRS}" INTERFACE_LINK_DIRECTORIES "${HMAT_LIBRARY_DIRS}"
INTERFACE_LINK_LIBRARIES "hmat-oss" INTERFACE_LINK_LIBRARIES "hmat"
message( STATUS "HMAT: Found" ) message( STATUS "HMAT: Found" )
else() else()
...@@ -138,7 +138,7 @@ target_include_directories(coreblas PUBLIC ...@@ -138,7 +138,7 @@ target_include_directories(coreblas PUBLIC
set_property(TARGET coreblas PROPERTY INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}/lib") set_property(TARGET coreblas PROPERTY INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}/lib")
if( CHAMELEON_USE_HMAT ) if( CHAMELEON_USE_HMAT )
target_link_libraries(coreblas PUBLIC HMAT::hmat-oss ) target_link_libraries(coreblas PUBLIC HMAT::hmat )
endif() endif()
target_link_libraries(coreblas PRIVATE MORSE::LAPACKE) target_link_libraries(coreblas PRIVATE MORSE::LAPACKE)
