Commit afa472de authored by THIBAULT Samuel's avatar THIBAULT Samuel
Add begin/end memory access hooks for runtimes
parent 6745049c
1 merge request!31Allow runtimes to have their own memory access macros
This commit is part of merge request !32. Comments created here will be created in the context of that merge request.
......@@ -205,7 +205,8 @@ inline static int morse_desc_islocal( const MORSE_desc_t *A, int m, int n )
* MORSE_END_ACCESS_DECLARATION
#define MORSE_BEGIN_ACCESS_DECLARATION { \
unsigned __morse_need_submit = 0;
unsigned __morse_need_submit = 0; \
RUNTIME_BEGIN_ACCESS_DECLARATION
#define MORSE_ACCESS_R(A, Am, An) \
if (morse_desc_islocal(A, Am, An)) __morse_need_submit = 1; \
......@@ -222,6 +223,7 @@ inline static int morse_desc_islocal( const MORSE_desc_t *A, int m, int n )
#define MORSE_RANK_CHANGED __morse_need_submit = 1;
#define MORSE_END_ACCESS_DECLARATION \
RUNTIME_BEGIN_ACCESS_DECLARATION \
if (!__morse_need_submit) return; \
......@@ -24,10 +24,14 @@ typedef struct morse_parsec_desc_s morse_parsec_desc_t;
#define RTBLKADDR( desc, type, m, n ) ( dague_dtd_tile_of( DAGUE_dtd_handle, (desc)->schedopt, m, n ) )
#define RUNTIME_BEGIN_ACCESS_DECLARATION
#define RUNTIME_ACCESS_R(A, Am, An)
#define RUNTIME_ACCESS_W(A, Am, An)
#define RUNTIME_ACCESS_RW(A, Am, An)
#define RUNTIME_END_ACCESS_DECLARATION
#endif /* _MORSE_PARSEC_H_ */
......@@ -47,10 +47,14 @@ typedef struct quark_option_s {
#define RTBLKADDR( desc, type, m, n ) ( (type*)RUNTIME_desc_getaddr( desc, m, n ) )
#endif /* _MORSE_QUARK_H_ */
......@@ -86,10 +86,14 @@ typedef struct starpu_conf starpu_conf_t;
void RUNTIME_set_reduction_methods(starpu_data_handle_t handle, MORSE_enum dtyp);
#endif /* _MORSE_STARPU_H_ */
