Commit a47085a6 authored by PRUVOST Florent's avatar PRUVOST Florent
fix option name
parent 6d71da30
......@@ -58,7 +58,7 @@ set(dep_message "${dep_message}"
" Simulation mode .....: ${CHAMELEON_SIMULATION}\n"
"\n"
" Binaries to build\n"
" documentation ........: ${CHAMELEON_ENABLE_DOCS}\n"
" documentation ........: ${CHAMELEON_ENABLE_DOC}\n"
" example ..............: ${CHAMELEON_ENABLE_EXAMPLE}\n"
" testing ..............: ${CHAMELEON_ENABLE_TESTING}\n"
" timing ...............: ${CHAMELEON_ENABLE_TIMING}\n"
