Commit 9c0a8237 authored by EYRAUD-DUBOIS Lionel's avatar EYRAUD-DUBOIS Lionel Committed by Mathieu Faverge
Update documentation, with an example
parent c927cc7e
1 merge request!398Generic data distribution specification
...@@ -517,14 +517,18 @@ ...@@ -517,14 +517,18 @@
0, 0, N, N, 1, 1, 0, 0, N, N, 1, 1,
user_getaddr_arrayofpointers, user_getaddr_arrayofpointers,
user_getblkldd_arrayofpointers, user_getblkldd_arrayofpointers,
user_getrankof_zero); user_getrankof_zero, NULL);
#+end_example #+end_example
Firsts arguments are the same than *CHAMELEON_Desc_Create* routine. Firsts arguments are the same than *CHAMELEON_Desc_Create* routine.
Following arguments allows you to give pointer to functions that Following arguments allows you to give pointer to functions that
manage the access to tiles from the structure given as second manage the access to tiles from the structure given as second
argument. Here for example, *matA* is an array containing argument. Here for example, *matA* is an array containing
addresses to tiles, see the function *allocate_tile_matrix* addresses to tiles, see the function *allocate_tile_matrix*
defined in step3.h. The three functions you have to defined in step3.h. If you want the matrix to be allocate by
Chameleon, you can use the *CHAMELEON_MAT_ALLOC_GLOBAL*, or the
*CHAMELEON_MAT_ALLOC_TILE* variables to allocate repectively as a
single large allocation, or to allocate tile by tile as late as
possible. The three functions you have to
define for *Desc_Create_User* are: define for *Desc_Create_User* are:
* a function that returns address of tile $A(m,n)$, m and n * a function that returns address of tile $A(m,n)$, m and n
standing for the indexes of the tile in the global matrix. Lets standing for the indexes of the tile in the global matrix. Lets
...@@ -533,8 +537,10 @@ ...@@ -533,8 +537,10 @@
$A(m=1,n=0)$, $A(m=1,n=1)$ $A(m=1,n=0)$, $A(m=1,n=1)$
* a function that returns the leading dimension of tile $A(m,*)$ * a function that returns the leading dimension of tile $A(m,*)$
* a function that returns MPI rank of tile $A(m,n)$ * a function that returns MPI rank of tile $A(m,n)$
* a pointer to a structure that these three functions can use to store
additional data.
Examples for these functions are vizible in step3.h. Note that Examples for these functions are visible in step3.h. Note that
the way we define these functions is related to the tile matrix the way we define these functions is related to the tile matrix
format and to the data distribution considered. This example format and to the data distribution considered. This example
should not be used with MPI since all tiles are affected to should not be used with MPI since all tiles are affected to
...@@ -680,7 +686,7 @@ ...@@ -680,7 +686,7 @@
GRID_P, GRID_Q, GRID_P, GRID_Q,
chameleon_getaddr_ccrb, chameleon_getaddr_ccrb,
chameleon_getblkldd_ccrb, chameleon_getblkldd_ccrb,
chameleon_getrankof_2d); chameleon_getrankof_2d, NULL);
is equivalent to the following call is equivalent to the following call
...@@ -738,6 +744,71 @@ ...@@ -738,6 +744,71 @@
by his function. The last parameter is the pointer to the user's by his function. The last parameter is the pointer to the user's
function. function.
*** Using custom data distributions
:PROPERTIES:
:CUSTOM_ID: doc-using-custom-distributions
:END:
**** Interface
It is possible to provide custom data distributions to Chameleon, to go beyond the 2D block
cyclic distributions. A generic interface is provided with the functions
*chameleon_getrankof_custom_init*, *chameleon_getrankof_custom_destroy* and
*chameleon_getrankof_custom*, with the following signatures:
#+begin_src
int chameleon_getrankof_custom_init( custom_dist_t **custom_dist,
const char *dist_file );
int chameleon_getrankof_custom_destroy( custom_dist_t **dist );
int chameleon_getrankof_custom( const CHAM_desc_t *desc, int m, int n );
The first function is used to read a custom distribution from an external file, whose name is
provided in the *dist_file* argument. The file format is described below. The second function
can be used to destroy the *custom_dist_t* pointer when it is no longer useful. The last
function should be used as the *get_rankof* argument to *CHAMELEON_Desc_Create_User*, together
with the custom distribution obtained from *chameleon_getrankof_custom_init*. The typical usage
is the following:
#+begin_src
custom_dist_t* custom_dist;
chameleon_getrankof_custom_init( &custom_dist, "filename" );
CHAMELEON_Desc_Create_User(&descA, NULL, ChamRealDouble,
NB, NB, NB*NB, N, N,
0, 0, N, N,
CHAMELEON_Comm_size(), 1,
chameleon_getrankof_custom, custom_dist);
/* Use the descriptor */
CHAMELEON_Desc_Destroy(&descA);
chameleon_getrankof_custom_destroy(&custom_dist);
Since we do not use a 2D block-cyclic distribution, the values of
*P* and *Q* have no importance in
*CHAMELEON_Desc_Create_User*. However, make sure that the product
of *P* and *Q* is equal to the number of processes by using the
couple *(CHAMELEON_Comm_size(), 1)* as a replacement for *(P,
Q)*.
**** File format
The custom distribution is provided by a pattern that can have any dimension, and which is
repeated all over the matrix. The file format expected by *chameleon_getrankof_custom_init* is
a simple text format, with space-separated integer values. The first two values represent the
size of the pattern (number of rows $m_d$ and number of columns $n_d$). Then, the function
expects $m_d * n_d$ values, where each value is the index of the process that should handle
this tile. For example, the following file content would result in a 2D block-cyclic
distribution with *P=2* and *Q=3* (it is not necessary to skip lines, but it can make the file
more readable):
#+begin_src
2 3
0 1 2
3 4 5
*** List of available routines *** List of available routines
:PROPERTIES: :PROPERTIES:
:CUSTOM_ID: doc-using-list-routines :CUSTOM_ID: doc-using-list-routines
...@@ -1009,7 +1080,8 @@ ...@@ -1009,7 +1080,8 @@
int i, int j, int m, int n, int p, int q, int i, int j, int m, int n, int p, int q,
void* (*get_blkaddr)( const CHAM_desc_t*, int, int), void* (*get_blkaddr)( const CHAM_desc_t*, int, int),
int (*get_blkldd)( const CHAM_desc_t*, int ), int (*get_blkldd)( const CHAM_desc_t*, int ),
int (*get_rankof)( const CHAM_desc_t*, int, int )); int (*get_rankof)( const CHAM_desc_t*, int, int ),
void* get_rankof_arg);
#+end_src #+end_src
Create matrix descriptor for tiled matrix which may not fit Create matrix descriptor for tiled matrix which may not fit
...@@ -1023,7 +1095,8 @@ ...@@ -1023,7 +1095,8 @@
#+begin_src #+begin_src
int CHAMELEON_Desc_Create_OOC_User(CHAM_desc_t **descptr, cham_flttype_t dtyp, int mb, int nb, int bsiz, int CHAMELEON_Desc_Create_OOC_User(CHAM_desc_t **descptr, cham_flttype_t dtyp, int mb, int nb, int bsiz,
int lm, int ln, int i, int j, int m, int n, int p, int q, int lm, int ln, int i, int j, int m, int n, int p, int q,
#+end_src #+end_src
Destroys matrix descriptor. Destroys matrix descriptor.
