GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
942bd0c2
There was a problem fetching the pipeline summary.
942bd0c2
8 years ago
Mathieu Faverge
Downloads
Merge branch 'fix' into 'master'
fix build See merge request
!28
parents
075986df
e2bcc72b
1 merge request
!28
fix build
Pipeline
runtime/starpu/control/runtime_descriptor.c
+1
-1
1 addition, 1 deletion
1 addition
1 deletion
942bd0c2
@@ -78,7 +78,7 @@ void *RUNTIME_mat_alloc( size_t size)
void
RUNTIME_mat_free
void
mat
size_t
size
#if defined(CHAMELEON_SIMULATION) && !defined(STARPU_MALLOC_SIMULATION_FOLDED) && !defined(CHAMELEON_USE_MPI)
return
void
return
#else
starpu_free_flags
mat
size
STARPU_MALLOC_PINNED
FOLDED
STARPU_MALLOC_COUNT
#endif
This diff is collapsed.
Loading
Save comment
