GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
91a3d7d3
91a3d7d3
7 years ago
PRUVOST Florent
Downloads
Patches
factorize STARPU_SILENT=1
1752446b
.gitlab-ci-env.sh
+1
1 addition, 0 deletions
.gitlab-ci-env.sh
1 addition
.gitlab-ci-env.sh
91a3d7d3
@@ -12,6 +12,7 @@ export PATH=/builds/sonar/sonar-scanner-2.9.0.670/bin:$PATH
export
QUARK_DIR
/builds/install/quark
export
QUARK_DIR
export
PARSEC_DIR
/builds/install/parsec
export
PARSEC_DIR
export
STARPU_DIR
/builds/install/starpu
export
STARPU_DIR
export
STARPU_SILENT
if
$1
"simu"
then
if
$1
"simu"
then
export
STARPU_DIR
/builds/install/starpu-simgrid
export
STARPU_DIR
This diff is collapsed.
Loading
Save comment
