Commit 857eedef authored by Mathieu Faverge's avatar Mathieu Faverge
tools: add lapack.h to check_header exceptions
parent 94092a9f
1 merge request!475A small set of modifications to allow external applications to use the RUNTIME API
...@@ -186,6 +186,7 @@ files=$( git ls-files | ...@@ -186,6 +186,7 @@ files=$( git ls-files |
grep -v CTest | grep -v CTest |
grep -v cblas.h | grep -v cblas.h |
grep -v "lapacke.*\.h" | grep -v "lapacke.*\.h" |
grep -v "coreblas/lapack\.h" |
grep -v ".*eztrace_module$" | grep -v ".*eztrace_module$" |
grep -v "simucore/perfmodels/\.starpu" | grep -v "simucore/perfmodels/\.starpu" |
grep -v "\.xml" | grep -v "\.xml" |
