Commit 7eb0925d authored by Mathieu Faverge's avatar Mathieu Faverge
starpu/ipiv: Fix MPI data cpy
parent b5d7efb6
1 merge request!404GETRF: add panel permutation to get a full partial pivoting available
...@@ -276,14 +276,38 @@ void RUNTIME_ipiv_gather( CHAM_ipiv_t *desc, int *ipiv, int node ) ...@@ -276,14 +276,38 @@ void RUNTIME_ipiv_gather( CHAM_ipiv_t *desc, int *ipiv, int node )
int64_t mb = desc->mb; int64_t mb = desc->mb;
int64_t tag = chameleon_starpu_tag_book( (int64_t)(desc->mt) ); int64_t tag = chameleon_starpu_tag_book( (int64_t)(desc->mt) );
int rank = CHAMELEON_Comm_rank(); int rank = CHAMELEON_Comm_rank();
int owner = rank;
int m; int m;
for (m = 0; m < mt; m++, ipiv += mb) { for (m = 0; m < mt; m++, ipiv += mb) {
starpu_data_handle_t ipiv_src = RUNTIME_ipiv_getaddr( desc, m ); starpu_data_handle_t ipiv_src = RUNTIME_ipiv_getaddr( desc, m );
#if defined(CHAMELEON_USE_MPI) #if defined(CHAMELEON_USE_MPI)
if ( (rank == node) || owner = starpu_mpi_data_get_rank( ipiv_src );
(rank == starpu_mpi_data_get_rank(ipiv_src)) ) if ( node != owner ) {
starpu_mpi_tag_t tag = starpu_mpi_data_get_tag( ipiv_src );
if ( rank == node )
/* Need to receive the data */
int already_received = starpu_mpi_cached_receive_set( ipiv_src );
if (already_received == 0)
MPI_Status status;
starpu_mpi_recv( ipiv_src, owner, tag, MPI_COMM_WORLD, &status );
else if ( rank == owner )
/* Need to send the data */
int already_sent = starpu_mpi_cached_send_set( ipiv_src, node );
if (already_sent == 0)
starpu_mpi_send( ipiv_src, node, tag, MPI_COMM_WORLD );
if ( rank == node )
#endif #endif
starpu_data_handle_t ipiv_dst; starpu_data_handle_t ipiv_dst;
