Commit 773f47bb authored by PRUVOST Florent's avatar PRUVOST Florent
udpate orgmode doc
parent 16e29148
@c -*-texinfo-*-
@c This file is part of the MORSE Handbook.
@c Copyright (C) 2017 Inria
@c Copyright (C) 2014 The University of Tennessee
@c Copyright (C) 2014 King Abdullah University of Science and Technology
@c See the file ../chameleon.texi for copying conditions.
@menu
* Compilation configuration::
* Dependencies detection::
@c * Dependencies compilation::
* Use FxT profiling through StarPU::
* Use simulation mode with StarPU-SimGrid::
* Use out of core support with StarPU::
@end menu
@c @code{} @option{}
@c @table @code
@c @item truc
@c @item muche
@c @item et zut
@c @c @end table
@node Compilation configuration
@section Compilation configuration
The following arguments can be given to the @command{cmake <path to source
directory>} script.
In this chapter, the following convention is used:
@itemize @bullet
@item
@option{path} is a path in your filesystem,
@item
@option{var} is a string and the correct value or an example will be given,
@item
@option{trigger} is an CMake option and the correct value is @code{ON} or
@code{OFF}.
@end itemize
Using CMake there are several ways to give options:
@enumerate
@item directly as CMake command line arguments
@item invoque @command{cmake <path to source directory>} once and then use
@command{ccmake <path to source directory>} to edit options through a
minimalist gui (required
@samp{cmake-curses-gui} installed on a Linux system)
@item invoque @command{cmake-gui} command and fill information about the
location of the sources and where to build the project, then you have
access to options through a user-friendly Qt interface (required
@samp{cmake-qt-gui} installed on a Linux system)
@end enumerate
Example of configuration using the command line
@example
cmake ~/chameleon/ -DCMAKE_BUILD_TYPE=Debug \
-DCMAKE_INSTALL_PREFIX=~/install \
-DCHAMELEON_USE_CUDA=ON \
-DCHAMELEON_USE_MPI=ON \
-DBLA_VENDOR=Intel10_64lp \
-DSTARPU_DIR=~/install/starpu-1.1 \
-DCHAMELEON_ENABLE_TRACING=ON
@end example
You can get the full list of options with @option{-L[A][H]} options of
@command{cmake} command:
@example
cmake -LH <path to source directory>
@end example
@menu
* General CMake options::
* CHAMELEON options::
@end menu
@node General CMake options
@subsection General CMake options
@table @code
@item -DCMAKE_INSTALL_PREFIX=@option{path} (default:@option{path=/usr/local})
Install directory used by @code{make install} where some headers and libraries
will be copied.
Permissions have to be granted to write onto @option{path} during @code{make
install} step.
@item -DCMAKE_BUILD_TYPE=@option{var} (default: @option{Release})
Define the build type and the compiler optimization level.
The possible values for @option{var} are:
@table @code
@item empty
@item Debug
@item Release
@item RelWithDebInfo
@item MinSizeRel
@end table
@item -DBUILD_SHARED_LIBS=@option{trigger} (default:@option{OFF})
Indicate wether or not CMake has to build CHAMELEON static (@option{OFF}) or
shared (@option{ON}) libraries.
@end table
@node CHAMELEON options
@subsection CHAMELEON options
List of CHAMELEON options that can be enabled/disabled (value=@code{ON}
or @code{OFF}):
@table @code
@item @option{-DCHAMELEON_SCHED_STARPU}=@option{trigger} (default: @code{ON})
to link with StarPU library (runtime system)
@item @option{-DCHAMELEON_SCHED_QUARK}=@option{trigger} (default: @code{OFF})
to link with QUARK library (runtime system)
@item @option{-DCHAMELEON_USE_CUDA}=@option{trigger} (default: @code{OFF})
to link with CUDA runtime (implementation paradigm for accelerated codes on
GPUs) and cuBLAS library (optimized BLAS kernels on GPUs), can only be used with
StarPU
@item @option{-DCHAMELEON_USE_MPI}=@option{trigger} (default: @code{OFF})
to link with MPI library (message passing implementation for use of multiple
nodes with distributed memory), can only be used with StarPU
@item @option{-DCHAMELEON_ENABLE_TRACING}=@option{trigger} (default: @code{OFF})
to enable trace generation during execution of timing drivers.
It requires StarPU to be linked with FxT library (trace execution of kernels on workers).
@item @option{-DCHAMELEON_SIMULATION=trigger} (default: @code{OFF})
to enable simulation mode, means CHAMELEON will not really execute tasks,
see details in section @ref{Use simulation mode with StarPU-SimGrid}.
This option must be used with StarPU compiled with
@uref{http://simgrid.gforge.inria.fr/, SimGrid} allowing to guess the
execution time on any architecture.
This feature should be used to make experiments on the scheduler behaviors and
performances not to produce solutions of linear systems.
@item @option{-DCHAMELEON_ENABLE_DOCS=trigger} (default: @code{ON})
to control build of the documentation contained in @file{docs/} sub-directory
@item @option{-DCHAMELEON_ENABLE_EXAMPLE=trigger} (default: @code{ON})
to control build of the examples executables (API usage)
contained in @file{example/} sub-directory
@item @option{-DCHAMELEON_ENABLE_TESTING=trigger} (default: @code{ON})
to control build of testing executables (numerical check) contained in
@file{testing/} sub-directory
@item @option{-DCHAMELEON_ENABLE_TIMING=trigger} (default: @code{ON})
to control build of timing executables (performances check) contained in
@file{timing/} sub-directory
@item @option{-DCHAMELEON_PREC_S=trigger} (default: @code{ON})
to enable the support of simple arithmetic precision (float in C)
@item @option{-DCHAMELEON_PREC_D=trigger} (default: @code{ON})
to enable the support of double arithmetic precision (double in C)
@item @option{-DCHAMELEON_PREC_C=trigger} (default: @code{ON})
to enable the support of complex arithmetic precision (complex in C)
@item @option{-DCHAMELEON_PREC_Z=trigger} (default: @code{ON})
to enable the support of double complex arithmetic precision (double complex
in C)
@item @option{-DBLAS_VERBOSE=trigger} (default: @code{OFF})
to make BLAS library discovery verbose
@item @option{-DLAPACK_VERBOSE=trigger} (default: @code{OFF})
to make LAPACK library discovery verbose (automatically enabled if
@option{BLAS_VERBOSE=@code{ON}})
@end table
List of CHAMELEON options that needs a specific value:
@table @code
@item @option{-DBLA_VENDOR=@option{var}} (default: @option{empty})
@table @code
@item empty
@item all
@item Intel10_64lp
@item Intel10_64lp_seq
@item ACML
@item Apple
@item Generic
@item ...
@end table
to force CMake to find a specific BLAS library, see the full list of BLA_VENDOR
in @file{FindBLAS.cmake} in @file{cmake_modules/morse/find}.
By default @option{BLA_VENDOR} is empty so that CMake tries to detect all
possible BLAS vendor with a preference for Intel MKL.
@end table
List of CHAMELEON options which requires to give a path:
@table @code
@item @option{-DLIBNAME_DIR=@option{path}} (default: empty)
root directory of the LIBNAME library installation
@item @option{-DLIBNAME_INCDIR=@option{path}} (default: empty)
directory of the LIBNAME library headers installation
@item @option{-DLIBNAME_LIBDIR=@option{path}} (default: empty)
directory of the LIBNAME libraries (.so, .a, .dylib, etc) installation
@end table
LIBNAME can be one of the following: BLAS - CBLAS - FXT - HWLOC -
LAPACK - LAPACKE - QUARK - STARPU - TMG.
See paragraph about @ref{Dependencies detection} for details.
Libraries detected with an official CMake module (see module files in
@file{CMAKE_ROOT/Modules/}):
@itemize @bullet
@item CUDA
@item MPI
@item Threads
@end itemize
Libraries detected with CHAMELEON cmake modules (see module files in
@file{cmake_modules/morse/find/} directory of CHAMELEON sources):
@itemize @bullet
@item BLAS
@item CBLAS
@item FXT
@item HWLOC
@item LAPACK
@item LAPACKE
@item QUARK
@item STARPU
@item TMG
@end itemize
@node Dependencies detection
@section Dependencies detection
You have different choices to detect dependencies on your system, either by
setting some environment variables containing paths to the libs and headers or
by specifying them directly at cmake configure.
Different cases :
@enumerate
@item detection of dependencies through environment variables:
@itemize @bullet
@item @env{LD_LIBRARY_PATH} environment variable should contain the list of
paths
where to find the libraries:
@example
export @env{LD_LIBRARY_PATH}=$@env{LD_LIBRARY_PATH}:path/to/your/libs
@end example
@item @env{INCLUDE} environment variable should contain the list of paths
where to find the header files of libraries
@example
export @env{INCLUDE}=$@env{INCLUDE}:path/to/your/headers
@end example
@end itemize
@item detection with user's given paths:
@itemize @bullet
@item you can specify the path at cmake configure by invoking
@example
cmake <path to SOURCE_DIR> -DLIBNAME_DIR=path/to/your/lib
@end example
where LIB stands for the name of the lib to look for, example
@example
cmake <path to SOURCE_DIR> -DSTARPU_DIR=path/to/starpudir \
-DCBLAS_DIR= ...
@end example
@item it is also possible to specify headers and library directories
separately, example
@example
cmake <path to SOURCE_DIR> \
-DSTARPU_INCDIR=path/to/libstarpu/include/starpu/1.1 \
-DSTARPU_LIBDIR=path/to/libstarpu/lib
@end example
@item Note BLAS and LAPACK detection can be tedious so that we provide a
verbose mode. Use @option{-DBLAS_VERBOSE=ON} or @option{-DLAPACK_VERBOSE=ON} to
enable it.
@end itemize
@end enumerate
@c @node Dependencies compilation
@c @section Dependencies compilation
@node Use FxT profiling through StarPU
@section Use FxT profiling through StarPU
StarPU can generate its own trace log files by compiling it with the
@option{--with-fxt}
option at the configure step (you can have to specify the directory where you
installed FxT by giving @option{--with-fxt=...} instead of @option{--with-fxt}
alone).
By doing so, traces are generated after each execution of a program which uses
StarPU in the directory pointed by the @env{STARPU_FXT_PREFIX} environment
variable. Example:
@example
export @env{STARPU_FXT_PREFIX}=/home/yourname/fxt_files/
@end example
When executing a @command{./timing/...} CHAMELEON program, if it has been
enabled (StarPU compiled with FxT and @option{-DCHAMELEON_ENABLE_TRACING=ON}), you
can give the option @option{--trace} to tell the program to generate trace log
files.
Finally, to generate the trace file which can be opened with
@uref{http://vite.gforge.inria.fr/, Vite} program, you have to use the
@command{starpu_fxt_tool} executable of StarPU.
This tool should be in @file{path/to/your/install/starpu/bin}.
You can use it to generate the trace file like this:
@itemize @bullet
@item @command{path/to/your/install/starpu/bin/starpu_fxt_tool -i prof_filename}
There is one file per mpi processus (prof_filename_0, prof_filename_1 ...).
To generate a trace of mpi programs you can call it like this:
prof_filename*}
The trace file will be named paje.trace (use -o option to specify an output
name).
@end itemize
Alternatively, one can also generate directly .paje trace files after the execution
by setting @env{STARPU_GENERATE_TRACE=1}.
@node Use simulation mode with StarPU-SimGrid
@section Use simulation mode with StarPU-SimGrid
Simulation mode can be enabled by setting the cmake option
@option{-DCHAMELEON_SIMULATION=ON}.
This mode allows you to simulate execution of algorithms with StarPU compiled
with @uref{http://simgrid.gforge.inria.fr/, SimGrid}.
To do so, we provide some perfmodels in the @file{simucore/perfmodels/}
directory of CHAMELEON sources.
To use these perfmodels, please set the following
@itemize @bullet
@item @env{STARPU_HOME} environment variable to:
@example
@code{<path to SOURCE_DIR>/simucore/perfmodels}
@end example
@item @env{STARPU_HOSTNAME} environment variable to the name of the machine to
simulate. For example, on our platform (PlaFRIM) with GPUs at Inria Bordeaux
@example
@env{STARPU_HOSTNAME}=mirage
@end example
Note that only POTRF kernels with block sizes of 320 or 960 (simple and double
precision) on mirage machine are available for now.
Database of models is subject to change, it should be enrich in a near future.
@end itemize
@node Use out of core support with StarPU
@section Use out of core support with StarPU
If the matrix can not fit in the main memory, StarPU can automatically evict
tiles to the disk. The descriptors for the matrices which can not fit in the
main memory need to be created with @code{MORSE_Desc_Create_OOC}, so that MORSE
does not force StarPU to keep it in the main memory.
The following variables then need to be set:
@itemize @bullet
@item @env{STARPU_DISK_SWAP} environment variable to a place where to store
evicted tiles, for example:
@example
@env{STARPU_DISK_SWAP}=/tmp
@end example
@item @env{STARPU_DISK_SWAP_BACKEND} environment variable to the I/O method,
for example:
@example
@env{STARPU_DISK_SWAP_BACKEND}=unistd_o_direct
@end example
@item @env{STARPU_LIMIT_CPU_MEM} environment variable to the amount of memory
that can be used in MBytes, for example:
@example
@env{STARPU_LIMIT_CPU_MEM}=1000
@end example
@end itemize
...@@ -322,7 +322,7 @@ we encourage users to use the morse branch of *Spack*. ...@@ -322,7 +322,7 @@ we encourage users to use the morse branch of *Spack*.
libraries, executables, etc, will be copied when invoking make libraries, executables, etc, will be copied when invoking make
install install
* *BUILD_SHARED_LIBS=ON|OFF* : Indicate wether or not CMake has to * *BUILD_SHARED_LIBS=ON|OFF* : Indicate wether or not CMake has to
build CHAMELEON static (~OFF~) or shared (~ON~) libraries. build Chameleon static (~OFF~) or shared (~ON~) libraries.
* *CMAKE_C_COMPILER=gcc|icc|...* : to choose the C compilers * *CMAKE_C_COMPILER=gcc|icc|...* : to choose the C compilers
if several exist in the environment if several exist in the environment
* *CMAKE_Fortran_COMPILER=gfortran|ifort|...*: to choose the * *CMAKE_Fortran_COMPILER=gfortran|ifort|...*: to choose the
...@@ -381,7 +381,7 @@ we encourage users to use the morse branch of *Spack*. ...@@ -381,7 +381,7 @@ we encourage users to use the morse branch of *Spack*.
kernels on workers), see also [[sec:trace][Execution tracing kernels on workers), see also [[sec:trace][Execution tracing
with StarPU]]. with StarPU]].
* *CHAMELEON_SIMULATION=ON|OFF* (default OFF) : to enable * *CHAMELEON_SIMULATION=ON|OFF* (default OFF) : to enable
simulation mode, means CHAMELEON will not really execute tasks, simulation mode, means Chameleon will not really execute tasks,
see details in section [[sec:simu][Use simulation mode with see details in section [[sec:simu][Use simulation mode with
StarPU-SimGrid]]. This option must be used with StarPU compiled StarPU-SimGrid]]. This option must be used with StarPU compiled
with [[http://simgrid.gforge.inria.fr/][SimGrid]] allowing to guess the execution time on any with [[http://simgrid.gforge.inria.fr/][SimGrid]] allowing to guess the execution time on any
...@@ -198,6 +198,7 @@ ...@@ -198,6 +198,7 @@
[[file:tile_lu.jpg]] [[file:tile_lu.jpg]]
**** Tile Data Layout **** Tile Data Layout
<<sec:tile>>
Tile layout is based on the idea of storing the matrix by square Tile layout is based on the idea of storing the matrix by square
tiles of relatively small size, such that each tile occupies a tiles of relatively small size, such that each tile occupies a
continuous memory region. This way a tile can be loaded to the continuous memory region. This way a tile can be loaded to the
This diff is collapsed.
