Commit 6d71da30 authored by PRUVOST Florent's avatar PRUVOST Florent
start an orgmode version of the texinfo users guide doc
parent e9dc21e8
with 2824 additions and 3 deletions
...@@ -3,7 +3,7 @@ ...@@ -3,7 +3,7 @@
# @copyright (c) 2009-2014 The University of Tennessee and The University # @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation. # of Tennessee Research Foundation.
# All rights reserved. # All rights reserved.
# @copyright (c) 2012-2014 Inria. All rights reserved. # @copyright (c) 2012-2017 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved. # @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -22,6 +22,7 @@ ...@@ -22,6 +22,7 @@
# @author Cedric Castagnede # @author Cedric Castagnede
# @author Emmanuel Agullo # @author Emmanuel Agullo
# @author Mathieu Faverge # @author Mathieu Faverge
# @author Florent Pruvost
# @date 13-07-2012 # @date 13-07-2012
...@@ -34,8 +35,8 @@ cmake_minimum_required(VERSION 2.8) ...@@ -34,8 +35,8 @@ cmake_minimum_required(VERSION 2.8)
add_subdirectory(doxygen) add_subdirectory(doxygen)
add_subdirectory(texinfo) add_subdirectory(orgmode)
#add_subdirectory(texinfo)
### END CMakeLists.txt ### END CMakeLists.txt
# @copyright (c) 2017 Inria. All rights reserved.
# @file CMakeLists.txt
# @project MORSE
# MORSE is a software package provided by:
# Inria Bordeaux - Sud-Ouest,
# Univ. of Tennessee,
# King Abdullah Univesity of Science and Technology
# Univ. of California Berkeley,
# Univ. of Colorado Denver.
# @version 1.0.0
# @date 25-08-2017
# Create file version.org
configure_file("version.org.in"
"version.org"
@ONLY)
configure_file("users_guide.org.in"
"users_guide.org"
@ONLY)
set(FIGURES
tile_lu.pdf
tile_layout.pdf
trace_qr.pdf
set(FIGURES_HTML
foreach(_fig ${FIGURES})
configure_file(${CMAKE_CURRENT_SOURCE_DIR}/figures/${_fig}
${CMAKE_CURRENT_BINARY_DIR}/${_fig}
COPYONLY)
endforeach()
# Looking for emacs
FIND_PROGRAM(EMACS_COMPILER emacs)
if(EMACS_COMPILER)
# Add target
add_custom_command(OUTPUT users_guide.html
COMMAND ${EMACS_COMPILER}
ARGS ${CMAKE_CURRENT_BINARY_DIR}/users_guide.org
--batch
-f
org-html-export-to-html
--kill
DEPENDS ${CMAKE_CURRENT_BINARY_DIR}/users_guide.org
add_custom_command(OUTPUT users_guide.pdf
--batch
-f
org-latex-export-to-pdf
--kill
add_custom_target(doc-html-users_guide ALL DEPENDS users_guide.html)
add_custom_target(doc-pdf-users_guide ALL DEPENDS users_guide.pdf)
# Installation
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/users_guide.html
DESTINATION share/chameleon/html)
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/users_guide.pdf
DESTINATION share/chameleon/pdf)
foreach(_fig ${FIGURES_HTML})
install(FILES ${CMAKE_CURRENT_BINARY_DIR}/${_fig}
endforeach()
else(EMACS_COMPILER)
message(STATUS "Looking for emacs - not found")
endif(EMACS_COMPILER)
@c -*-texinfo-*-
@c This file is part of the MORSE Handbook.
@c Copyright (C) 2017 Inria
@c Copyright (C) 2014 The University of Tennessee
@c Copyright (C) 2014 King Abdullah University of Science and Technology
@c See the file ../chameleon.texi for copying conditions.
@menu
* Compilation configuration::
* Dependencies detection::
@c * Dependencies compilation::
* Use FxT profiling through StarPU::
* Use simulation mode with StarPU-SimGrid::
* Use out of core support with StarPU::
@end menu
@c @code{} @option{}
@c @table @code
@c @item truc
@c @item muche
@c @item et zut
@c @c @end table
@node Compilation configuration
@section Compilation configuration
The following arguments can be given to the @command{cmake <path to source
directory>} script.
In this chapter, the following convention is used:
@itemize @bullet
@item
@option{path} is a path in your filesystem,
@item
@option{var} is a string and the correct value or an example will be given,
@item
@option{trigger} is an CMake option and the correct value is @code{ON} or
@code{OFF}.
@end itemize
Using CMake there are several ways to give options:
@enumerate
@item directly as CMake command line arguments
@item invoque @command{cmake <path to source directory>} once and then use
@command{ccmake <path to source directory>} to edit options through a
minimalist gui (required
@samp{cmake-curses-gui} installed on a Linux system)
@item invoque @command{cmake-gui} command and fill information about the
location of the sources and where to build the project, then you have
access to options through a user-friendly Qt interface (required
@samp{cmake-qt-gui} installed on a Linux system)
@end enumerate
Example of configuration using the command line
@example
cmake ~/chameleon/ -DCMAKE_BUILD_TYPE=Debug \
-DCMAKE_INSTALL_PREFIX=~/install \
-DCHAMELEON_USE_CUDA=ON \
-DCHAMELEON_USE_MPI=ON \
-DBLA_VENDOR=Intel10_64lp \
-DSTARPU_DIR=~/install/starpu-1.1 \
-DCHAMELEON_ENABLE_TRACING=ON
@end example
You can get the full list of options with @option{-L[A][H]} options of
@command{cmake} command:
@example
cmake -LH <path to source directory>
@end example
@menu
* General CMake options::
* CHAMELEON options::
@end menu
@node General CMake options
@subsection General CMake options
@table @code
@item -DCMAKE_INSTALL_PREFIX=@option{path} (default:@option{path=/usr/local})
Install directory used by @code{make install} where some headers and libraries
will be copied.
Permissions have to be granted to write onto @option{path} during @code{make
install} step.
@item -DCMAKE_BUILD_TYPE=@option{var} (default: @option{Release})
Define the build type and the compiler optimization level.
The possible values for @option{var} are:
@table @code
@item empty
@item Debug
@item Release
@item RelWithDebInfo
@item MinSizeRel
@end table
@item -DBUILD_SHARED_LIBS=@option{trigger} (default:@option{OFF})
Indicate wether or not CMake has to build CHAMELEON static (@option{OFF}) or
shared (@option{ON}) libraries.
@end table
@node CHAMELEON options
@subsection CHAMELEON options
List of CHAMELEON options that can be enabled/disabled (value=@code{ON}
or @code{OFF}):
@table @code
@item @option{-DCHAMELEON_SCHED_STARPU}=@option{trigger} (default: @code{ON})
to link with StarPU library (runtime system)
@item @option{-DCHAMELEON_SCHED_QUARK}=@option{trigger} (default: @code{OFF})
to link with QUARK library (runtime system)
@item @option{-DCHAMELEON_USE_CUDA}=@option{trigger} (default: @code{OFF})
to link with CUDA runtime (implementation paradigm for accelerated codes on
GPUs) and cuBLAS library (optimized BLAS kernels on GPUs), can only be used with
StarPU
@item @option{-DCHAMELEON_USE_MPI}=@option{trigger} (default: @code{OFF})
to link with MPI library (message passing implementation for use of multiple
nodes with distributed memory), can only be used with StarPU
@item @option{-DCHAMELEON_ENABLE_TRACING}=@option{trigger} (default: @code{OFF})
to enable trace generation during execution of timing drivers.
It requires StarPU to be linked with FxT library (trace execution of kernels on workers).
@item @option{-DCHAMELEON_SIMULATION=trigger} (default: @code{OFF})
to enable simulation mode, means CHAMELEON will not really execute tasks,
see details in section @ref{Use simulation mode with StarPU-SimGrid}.
This option must be used with StarPU compiled with
@uref{http://simgrid.gforge.inria.fr/, SimGrid} allowing to guess the
execution time on any architecture.
This feature should be used to make experiments on the scheduler behaviors and
performances not to produce solutions of linear systems.
@item @option{-DCHAMELEON_ENABLE_DOCS=trigger} (default: @code{ON})
to control build of the documentation contained in @file{docs/} sub-directory
@item @option{-DCHAMELEON_ENABLE_EXAMPLE=trigger} (default: @code{ON})
to control build of the examples executables (API usage)
contained in @file{example/} sub-directory
@item @option{-DCHAMELEON_ENABLE_TESTING=trigger} (default: @code{ON})
to control build of testing executables (numerical check) contained in
@file{testing/} sub-directory
@item @option{-DCHAMELEON_ENABLE_TIMING=trigger} (default: @code{ON})
to control build of timing executables (performances check) contained in
@file{timing/} sub-directory
@item @option{-DCHAMELEON_PREC_S=trigger} (default: @code{ON})
to enable the support of simple arithmetic precision (float in C)
@item @option{-DCHAMELEON_PREC_D=trigger} (default: @code{ON})
to enable the support of double arithmetic precision (double in C)
@item @option{-DCHAMELEON_PREC_C=trigger} (default: @code{ON})
to enable the support of complex arithmetic precision (complex in C)
@item @option{-DCHAMELEON_PREC_Z=trigger} (default: @code{ON})
to enable the support of double complex arithmetic precision (double complex
in C)
@item @option{-DBLAS_VERBOSE=trigger} (default: @code{OFF})
to make BLAS library discovery verbose
@item @option{-DLAPACK_VERBOSE=trigger} (default: @code{OFF})
to make LAPACK library discovery verbose (automatically enabled if
@option{BLAS_VERBOSE=@code{ON}})
@end table
List of CHAMELEON options that needs a specific value:
@table @code
@item @option{-DBLA_VENDOR=@option{var}} (default: @option{empty})
@table @code
@item empty
@item all
@item Intel10_64lp
@item Intel10_64lp_seq
@item ACML
@item Apple
@item Generic
@item ...
@end table
to force CMake to find a specific BLAS library, see the full list of BLA_VENDOR
in @file{FindBLAS.cmake} in @file{cmake_modules/morse/find}.
By default @option{BLA_VENDOR} is empty so that CMake tries to detect all
possible BLAS vendor with a preference for Intel MKL.
@end table
List of CHAMELEON options which requires to give a path:
@table @code
@item @option{-DLIBNAME_DIR=@option{path}} (default: empty)
root directory of the LIBNAME library installation
@item @option{-DLIBNAME_INCDIR=@option{path}} (default: empty)
directory of the LIBNAME library headers installation
@item @option{-DLIBNAME_LIBDIR=@option{path}} (default: empty)
directory of the LIBNAME libraries (.so, .a, .dylib, etc) installation
@end table
LIBNAME can be one of the following: BLAS - CBLAS - FXT - HWLOC -
LAPACK - LAPACKE - QUARK - STARPU - TMG.
See paragraph about @ref{Dependencies detection} for details.
Libraries detected with an official CMake module (see module files in
@file{CMAKE_ROOT/Modules/}):
@itemize @bullet
@item CUDA
@item MPI
@item Threads
@end itemize
Libraries detected with CHAMELEON cmake modules (see module files in
@file{cmake_modules/morse/find/} directory of CHAMELEON sources):
@itemize @bullet
@item BLAS
@item CBLAS
@item FXT
@item HWLOC
@item LAPACK
@item LAPACKE
@item QUARK
@item STARPU
@item TMG
@end itemize
@node Dependencies detection
@section Dependencies detection
You have different choices to detect dependencies on your system, either by
setting some environment variables containing paths to the libs and headers or
by specifying them directly at cmake configure.
Different cases :
@enumerate
@item detection of dependencies through environment variables:
@itemize @bullet
@item @env{LD_LIBRARY_PATH} environment variable should contain the list of
paths
where to find the libraries:
@example
export @env{LD_LIBRARY_PATH}=$@env{LD_LIBRARY_PATH}:path/to/your/libs
@end example
@item @env{INCLUDE} environment variable should contain the list of paths
where to find the header files of libraries
@example
export @env{INCLUDE}=$@env{INCLUDE}:path/to/your/headers
@end example
@end itemize
@item detection with user's given paths:
@itemize @bullet
@item you can specify the path at cmake configure by invoking
@example
cmake <path to SOURCE_DIR> -DLIBNAME_DIR=path/to/your/lib
@end example
where LIB stands for the name of the lib to look for, example
@example
cmake <path to SOURCE_DIR> -DSTARPU_DIR=path/to/starpudir \
-DCBLAS_DIR= ...
@end example
@item it is also possible to specify headers and library directories
separately, example
@example
cmake <path to SOURCE_DIR> \
-DSTARPU_INCDIR=path/to/libstarpu/include/starpu/1.1 \
-DSTARPU_LIBDIR=path/to/libstarpu/lib
@end example
@item Note BLAS and LAPACK detection can be tedious so that we provide a
verbose mode. Use @option{-DBLAS_VERBOSE=ON} or @option{-DLAPACK_VERBOSE=ON} to
enable it.
@end itemize
@end enumerate
@c @node Dependencies compilation
@c @section Dependencies compilation
@node Use FxT profiling through StarPU
@section Use FxT profiling through StarPU
StarPU can generate its own trace log files by compiling it with the
@option{--with-fxt}
option at the configure step (you can have to specify the directory where you
installed FxT by giving @option{--with-fxt=...} instead of @option{--with-fxt}
alone).
By doing so, traces are generated after each execution of a program which uses
StarPU in the directory pointed by the @env{STARPU_FXT_PREFIX} environment
variable. Example:
@example
export @env{STARPU_FXT_PREFIX}=/home/yourname/fxt_files/
@end example
When executing a @command{./timing/...} CHAMELEON program, if it has been
enabled (StarPU compiled with FxT and @option{-DCHAMELEON_ENABLE_TRACING=ON}), you
can give the option @option{--trace} to tell the program to generate trace log
files.
Finally, to generate the trace file which can be opened with
@uref{http://vite.gforge.inria.fr/, Vite} program, you have to use the
@command{starpu_fxt_tool} executable of StarPU.
This tool should be in @file{path/to/your/install/starpu/bin}.
You can use it to generate the trace file like this:
@itemize @bullet
@item @command{path/to/your/install/starpu/bin/starpu_fxt_tool -i prof_filename}
There is one file per mpi processus (prof_filename_0, prof_filename_1 ...).
To generate a trace of mpi programs you can call it like this:
prof_filename*}
The trace file will be named paje.trace (use -o option to specify an output
name).
@end itemize
Alternatively, one can also generate directly .paje trace files after the execution
by setting @env{STARPU_GENERATE_TRACE=1}.
@node Use simulation mode with StarPU-SimGrid
@section Use simulation mode with StarPU-SimGrid
Simulation mode can be enabled by setting the cmake option
@option{-DCHAMELEON_SIMULATION=ON}.
This mode allows you to simulate execution of algorithms with StarPU compiled
with @uref{http://simgrid.gforge.inria.fr/, SimGrid}.
To do so, we provide some perfmodels in the @file{simucore/perfmodels/}
directory of CHAMELEON sources.
To use these perfmodels, please set the following
@itemize @bullet
@item @env{STARPU_HOME} environment variable to:
@example
@code{<path to SOURCE_DIR>/simucore/perfmodels}
@end example
@item @env{STARPU_HOSTNAME} environment variable to the name of the machine to
simulate. For example, on our platform (PlaFRIM) with GPUs at Inria Bordeaux
@example
@env{STARPU_HOSTNAME}=mirage
@end example
Note that only POTRF kernels with block sizes of 320 or 960 (simple and double
precision) on mirage machine are available for now.
Database of models is subject to change, it should be enrich in a near future.
@end itemize
@node Use out of core support with StarPU
@section Use out of core support with StarPU
If the matrix can not fit in the main memory, StarPU can automatically evict
tiles to the disk. The descriptors for the matrices which can not fit in the
main memory need to be created with @code{MORSE_Desc_Create_OOC}, so that MORSE
does not force StarPU to keep it in the main memory.
The following variables then need to be set:
@itemize @bullet
@item @env{STARPU_DISK_SWAP} environment variable to a place where to store
evicted tiles, for example:
@example
@env{STARPU_DISK_SWAP}=/tmp
@end example
@item @env{STARPU_DISK_SWAP_BACKEND} environment variable to the I/O method,
for example:
@example
@env{STARPU_DISK_SWAP_BACKEND}=unistd_o_direct
@end example
@item @env{STARPU_LIMIT_CPU_MEM} environment variable to the amount of memory
that can be used in MBytes, for example:
@example
@env{STARPU_LIMIT_CPU_MEM}=1000
@end example
@end itemize
This diff is collapsed.
# This file is part of the CHAMELEON User's Guide.
# Copyright (C) 2017 Inria
# See the file ../users_guide.org for copying conditions.
** MORSE project
#+NAME: fig:morse_header
#+ATTR_HTML: :align center
[[file:morse_header.png]]
*** MORSE Objectives
When processor clock speeds flatlined in 2004, after more than
fifteen years of exponential increases, the era of near automatic
performance improvements that the HPC application community had
previously enjoyed came to an abrupt end. To develop software that
will perform well on petascale and exascale systems with thousands
of nodes and millions of cores, the list of major challenges that
must now be confronted is formidable:
1) dramatic escalation in the costs of intrasystem communication
between processors and/or levels of memory hierarchy;
2) increased heterogeneity of the processing units (mixing CPUs,
GPUs, etc. in varying and unexpected design combinations);
3) high levels of parallelism and more complex constraints means
that cooperating processes must be dynamically and unpredictably
scheduled for asynchronous execution;
4) software will not run at scale without much better resilience to
faults and far more robustness; and
5) new levels of self-adaptivity will be required to enable
software to modulate process speed in order to satisfy limited
energy budgets.
The MORSE associate team will tackle the first three challenges in
a orchestrating work between research groups respectively
specialized in sparse linear algebra, dense linear algebra and
runtime systems. The overall objective is to develop robust linear
algebra libraries relying on innovative runtime systems that can
fully benefit from the potential of those future large-scale
complex machines. Challenges 4) and 5) will also be investigated
by the different teams in the context of other partnerships, but
they will not be the main focus of the associate team as they are
much more prospective.
*** Research fields
The overall goal of the MORSE associate team is to enable advanced
numerical algorithms to be executed on a scalable unified runtime
system for exploiting the full potential of future exascale
machines. We expect advances in three directions based first on
strong and closed interactions between the runtime and numerical
linear algebra communities. This initial activity will then
naturally expand to more focused but still joint research in both
fields.
**** Fine interaction between linear algebra and runtime systems
On parallel machines, HPC applications need to take care of data
movement and consistency, which can be either explicitly managed
at the level of the application itself or delegated to a runtime
system. We adopt the latter approach in order to better keep up
with hardware trends whose complexity is growing exponentially.
One major task in this project is to define a proper interface
between HPC applications and runtime systems in order to maximize
productivity and expressivity. As mentioned in the next section,
a widely used approach consists in abstracting the application as
a DAG that the runtime system is in charge of scheduling.
Scheduling such a DAG over a set of heterogeneous processing units
introduces a lot of new challenges, such as predicting accurately
the execution time of each type of task over each kind of unit,
minimizing data transfers between memory banks, performing data
prefetching, etc. Expected advances: In a nutshell, a new runtime
system API will be designed to allow applications to provide
scheduling hints to the runtime system and to get real-time
feedback about the consequences of scheduling decisions.
**** Runtime systems
A runtime environment is an intermediate layer between the system
and the application. It provides low-level functionality not
provided by the system (such as scheduling or management of the
heterogeneity) and high-level features (such as performance
portability). In the framework of this proposal, we will work on
the scalability of runtime environment. To achieve scalability it
is required to avoid all centralization. Here, the main problem
is the scheduling of the tasks. In many task-based runtime
environments the scheduler is centralized and becomes a bottleneck
as soon as too many cores are involved. It is therefore required
to distribute the scheduling decision or to compute a data
distribution that impose the mapping of task using, for instance
the so-called ``owner-compute'' rule. Expected advances: We will
design runtime systems that enable an efficient and scalable use
of thousands of distributed multicore nodes enhanced with
accelerators.
**** Linear algebra
Because of its central position in HPC and of the well understood
structure of its algorithms, dense linear algebra has often
pioneered new challenges that HPC had to face. Again, dense
linear algebra has been in the vanguard of the new era of
petascale computing with the design of new algorithms that can
efficiently run on a multicore node with GPU accelerators. These
algorithms are called ``communication-avoiding'' since they have
been redesigned to limit the amount of communication between
processing units (and between the different levels of memory
hierarchy). They are expressed through Direct Acyclic Graphs
(DAG) of fine-grained tasks that are dynamically
scheduled. Expected advances: First, we plan to investigate the
impact of these principles in the case of sparse applications
(whose algorithms are slightly more complicated but often rely on
dense kernels). Furthermore, both in the dense and sparse cases,
the scalability on thousands of nodes is still limited; new
numerical approaches need to be found. We will specifically
design sparse hybrid direct/iterative methods that represent a
promising approach.
*** Research papers
Research papers about MORSE can be found at
http://icl.cs.utk.edu/projectsdev/morse/pubs/index.html
** CHAMELEON
*** CHAMELEON software
The main purpose is to address the performance shortcomings of the
[[http://www.netlib.org/lapack/][LAPACK]] and [[http://www.netlib.org/scalapack/][ScaLAPACK]] libraries on multicore processors and
multi-socket systems of multicore processors and their inability to
efficiently utilize accelerators such as Graphics Processing Units
(GPUs).
CHAMELEON is a framework written in C which provides routines to
solve dense general systems of linear equations, symmetric positive
definite systems of linear equations and linear least squares
problems, using LU, Cholesky, QR and LQ factorizations. Real
arithmetic and complex arithmetic are supported in both single
precision and double precision. It supports Linux and Mac OS/X
machines (only tested on Intel x86-64 architecture).
CHAMELEON is based on [[http://icl.cs.utk.edu/plasma/][PLASMA]] source code but is not limited to
shared-memory environment and can exploit multiple GPUs. CHAMELEON
is interfaced in a generic way with both [[http://icl.cs.utk.edu/quark/][QUARK]] and [[http://runtime.bordeaux.inria.fr/StarPU/][StarPU]] runtime
systems. This feature allows to analyze in a unified framework how
sequential task-based algorithms behave regarding different runtime
systems implementations. Using CHAMELEON with [[http://runtime.bordeaux.inria.fr/StarPU/][StarPU]] runtime
system allows to exploit GPUs through kernels provided by [[https://developer.nvidia.com/cublas][cuBLAS]]
and clusters of interconnected nodes with distributed memory (using
[[http://www.open-mpi.org/][MPI]]). Computation of very large systems with dense matrices on a
cluster of nodes is still being experimented and stabilized. It is
not expected to get stable performances with the current version
using MPI.
*** PLASMA's design principles
CHAMELEON is originally based on [[http://icl.cs.utk.edu/plasma/][PLASMA]] so that design principles
are very similar. The content of this section PLASMA's design
principles has been copied from the /Design principles/ section of
the PLASMA User's Guide.
**** Tile Algorithms
Tile algorithms are based on the idea of processing the matrix by
square tiles of relatively small size, such that a tile fits
entirely in one of the cache levels associated with one core.
This way a tile can be loaded to the cache and processed
completely before being evicted back to the main memory. Of the
three types of cache misses, *compulsory*, *capacity* and *conflict*,
the use of tile algorithms minimizes the number of capacity
misses, since each operation loads the amount of data that does
not ``overflow'' the cache.
For some operations such as matrix multiplication and Cholesky
factorization, translating the classic algorithm to the tile
algorithm is trivial. In the case of matrix multiplication, the
tile algorithm is simply a product of applying the technique of
*loop tiling* to the canonical definition of three nested loops. It
is very similar for the Cholesky factorization. The *left-looking*
definition of Cholesky factorization from LAPACK is a loop with a
sequence of calls to four routines: xSYRK (symmetric *rank-k*
update), xPOTRF (Cholesky factorization of a small block on the
diagonal), xGEMM (matrix multiplication) and xTRSM (triangular
solve). If the xSYRK, xGEMM and xTRSM operations are expressed
with the canonical definition of three nested loops and the
technique of loop tiling is applied, the tile algorithm results.
Since the algorithm is produced by simple reordering of
operations, neither the number of operations nor numerical
stability of the algorithm are affected.
The situation becomes slightly more complicated for LU and QR
factorizations, where the classic algorithms factorize an entire
panel of the matrix (a block of columns) at every step of the
algorithm. One can observe, however, that the process of matrix
factorization is synonymous with introducing zeros in approproate
places and a tile algorithm can be fought of as one that zeroes
one tile of the matrix at a time. This process is referred to as
updating of a factorization or *incremental factorization*. The
process is equivalent to factorizing the top tile of a panel, then
placing the upper triangle of the result on top of the tile blow
and factorizing again, then moving to the next tile and so on.
Here, the tile LU and QR algorithms perform slightly more floating
point operations and require slightly more memory for auxiliary
data. Also, the tile LU factorization applies a different
pivoting pattern and, as a result, is less numerically stable than
classic LU with full pivoting. Numerical stability is not an
issue in case of the tile QR, which relies on orthogonal
transformations (Householder reflections), which are numerically
stable.
#+CAPTION: Schematic illustration of the tile LU factorization (kernel names for real arithmetics in double precision), courtesey of the [[http://icl.cs.utk.edu/plasma/][PLASMA]] team.
#+NAME: fig:tile_lu
#+ATTR_HTML: :width 640px :align center
[[file:tile_lu.jpg]]
**** Tile Data Layout
Tile layout is based on the idea of storing the matrix by square
tiles of relatively small size, such that each tile occupies a
continuous memory region. This way a tile can be loaded to the
cache memory efficiently and the risk of evicting it from the
cache memory before it is completely processed is minimized. Of
the three types of cache misses, *compulsory*, *capacity* and
*conflict*, the use of tile layout minimizes the number of conflict
misses, since a continuous region of memory will completely fill
out a /set-associative/ cache memory before an eviction can
happen. Also, from the standpoint of multithreaded execution, the
probability of *false sharing* is minimized. It can only
affect the cache lines containing the beginning and the ending of
a tile.
In standard *cache-based* architecture, tiles continously laid out
in memory maximize the profit from automatic prefetching. Tile
layout is also beneficial in situations involving the use of
accelerators, where explicit communication of tiles through DMA
transfers is required, such as moving tiles between the system
memory and the local store in Cell B. E. or moving tiles between
the host memory and the device memory in GPUs. In most
circumstances tile layout also minimizes the number of TLB misses
and conflicts to memory banks or partitions. With the standard
(*column-major*) layout, access to each column of a tile is much
more likely to cause a conflict miss, a false sharing miss, a TLB
miss or a bank or partition conflict. The use of the standard
layout for dense matrix operations is a performance minefield.
Although occasionally one can pass through it unscathed, the risk
of hitting a spot deadly to performance is very high.
Another property of the layout utilized in PLASMA is that it is
``flat'', meaning that it does not involve a level of
indirection. Each tile stores a small square submatrix of the main
matrix in a *column-major* layout. In turn, the main matrix is an
arrangement of tiles immediately following one another in a
*column-major* layout. The offset of each tile can be calculated
through address arithmetics and does not involve pointer
indirection. Alternatively, a matrix could be represented as an
array of pointers to tiles, located anywhere in memory. Such
layout would be a radical and unjustifiable departure from LAPACK
and ScaLAPACK. Flat tile layout is a natural progression from
LAPACK's *column-major* layout and ScaLAPACK's
/block-cyclic/ layout.
Another related property of PLASMA's tile layout is that it
includes provisions for padding of tiles, i.e., the actual region
of memory designated for a tile can be larger than the memory
occupied by the actual data. This allows to force a certain
alignment of tile boundaries, while using the flat organization
described in the previous paragraph. The motivation is that, at
the price of small memory overhead, alignment of tile boundaries
may prove benefivial in multiple scenarios involving memory
systems of standard multicore processors, as well as accelerators.
The issues that come into play are, again, the use of TLBs and
#+CAPTION: Schematic illustration of the tile layout with *column-major* order of tiles, *column-major* order of elements within tiles and (optional) padding for enforcing a certain alighment of tile bondaries, courtesey of the [[http://icl.cs.utk.edu/plasma/][PLASMA]] team.
#+NAME: fig:tile_layout
[[file:tile_layout.jpg]]
**** Dynamic Task Scheduling
Dynamic scheduling is the idea of assigning work to cores based on
the availability of data for processing at any given point in time
and is also referred to as *data-driven* scheduling. The concept is
related closely to the idea of expressing computation through a
task graph, often referred to as the DAG (*Direct Acyclic Graph*),
and the flexibility exploring the DAG at runtime. Thus, to a
large extent, dynamic scheduling is synonymous with *runtime
scheduling*. An important concept here is the one of the *critical
path*, which defines the upper bound on the achievable parallelism,
and needs to be pursued at the maximum speed. This is in direct
opposition to the *fork-and-join* or *data-parallel* programming
models, where artificial synchronization points expose serial
sections of the code, where multiple cores are idle, while
sequential processing takes place. The use of dynamic scheduling
introduces a *trade-off*, though. The more dynamic (flexible)
scheduling is, the more centralized (and less scalable) the
scheduling mechanism is. For that reason, currently PLASMA uses
two scheduling mechanisms, one which is fully dynamic and one
where work is assigned statically and dependency checks are done
at runtime.
The first scheduling mechanism relies on unfolding a *sliding
window* of the task graph at runtime and scheduling work by
resolving data hazards: *Read After Write(RAW)*, *Write After Read
(WAR)* and *Write After Write (WAW)*, a technique analogous to
instruction scheduling in superscalar processors. It also relies
on *work-stealing* for balanding the load among all multiple cores.
The second scheduling mechanism relies on statically designating a
path through the execution space of the algorithm to each core and
following a cycle: transition to a task, wait for its
dependencies, execute it, update the overall progress. Task are
identified by tuples and task transitions are done through locally
evaluated formulas. Progress information can be centralized,
replicated or distributed (currently centralized).
#+CAPTION: A trace of the tile QR factorization executing on eight cores without any global synchronization points (kernel names for real arithmetics in single precision), courtesey of the [[http://icl.cs.utk.edu/plasma/][PLASMA]] team.
#+NAME: fig:trace_qr
[[file:trace_qr.jpg]]
doc/orgmode/figures/morse_header.png
6.15 KiB
doc/orgmode/figures/potri_async.png
525 KiB
doc/orgmode/figures/tile_layout.jpg
19.5 KiB
File added
doc/orgmode/figures/tile_lu.jpg
49 KiB
File added
doc/orgmode/figures/trace_qr.jpg
35.8 KiB
File added
body {
padding: 2em 1em 2em 70px;
margin: 0;
font-family: sans-serif;
color: black;
background: white;
background-position: top left;
background-attachment: fixed;
background-repeat: no-repeat;
:link { color: #00C; background: transparent }
:visited { color: #609; background: transparent }
a:active { color: #C00; background: transparent }
a:link img, a:visited img { border-style: none }
a img { color: white; }
@media all {
a img { color: inherit; }
th, td {
h1, h2, h3, h4, h5, h6 { text-align: left }
h1, h2, h3 { color: #005A9C; background: white }
h1 { font: 170% sans-serif }
h2 { font: 140% sans-serif }
h3 { font: 120% sans-serif }
h4 { font: bold 100% sans-serif }
h5 { font: italic 100% sans-serif }
h6 { font: small-caps 100% sans-serif }
.hide { display: none }
div.head { margin-bottom: 1em }
div.head h1 { margin-top: 2em; clear: both }
div.head table { margin-left: 2em; margin-top: 2em }
p.copyright { font-size: small }
p.copyright small { font-size: small }
@media screen {
a[href]:hover { background: #ffa }
pre { margin-left: 2em }
dt, dd { margin-top: 0; margin-bottom: 0 }
dt { font-weight: bold }
pre, code { font-family: monospace }
ul.toc, ol.toc {
list-style: disc;
list-style: none;
@media aural {
h1, h2, h3 { stress: 20; richness: 90 }
.hide { speak: none }
p.copyright { volume: x-soft; speech-rate: x-fast }
dt { pause-before: 20% }
pre { speak-punctuation: code }
body {
background-image: url();
#+TITLE: CHAMELEON User's Guide
#+SUBTITLE: A dense linear algebra software for heterogeneous architectures
#+LANGUAGE: en
#+OPTIONS: H:3 num:t \n:nil @:t ::t |:t _:nil ^:nil -:t f:t *:t <:t
#+OPTIONS: TeX:t LaTeX:t skip:nil d:nil pri:nil tags:not-in-toc html-style:nil
#+INCLUDE: "./version.org"
#+AUTHOR: version {{{VERSION}}}
* Version
This manual documents the usage of CHAMELEON *version {{{VERSION}}}*.
It was last updated on {{{UPDATED}}}.
* Authors
* Inria,
* University of Tennessee,
* University of Colorado Denver,
* King Abdullah University of Science and Technology
* Copying
Copyright \copy 2017 Inria
Copyright \copy 2014 The University of Tennessee
Copyright \copy 2014 King Abdullah University of Science and Technology
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are
met:
- Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer listed
in this license in the documentation and/or other materials provided
with the distribution.
- Neither the name of the copyright holders nor the names of its
contributors may be used to endorse or promote products derived from
this software without specific prior written permission.
This software is provided by the copyright holders and contributors
"as is" and any express or implied warranties, including, but not
limited to, the implied warranties of merchantability and fitness for
a particular purpose are disclaimed. In no event shall the copyright
owner or contributors be liable for any direct, indirect, incidental,
special, exemplary, or consequential damages (including, but not
limited to, procurement of substitute goods or services; loss of use,
data, or profits; or business interruption) however caused and on any
theory of liability, whether in contract, strict liability, or tort
(including negligence or otherwise) arising in any way out of the use
of this software, even if advised of the possibility of such damage.
* Introduction to Chameleon
#+INCLUDE: @CMAKE_CURRENT_SOURCE_DIR@/chapters/introduction.org
* Installing Chameleon
#+INCLUDE: @CMAKE_CURRENT_SOURCE_DIR@/chapters/installing.org
# #+INCLUDE: @CMAKE_CURRENT_SOURCE_DIR@/chapters/configuration.org
# #+INCLUDE: @CMAKE_CURRENT_SOURCE_DIR@/chapters/using.org
#+MACRO: UPDATED 25 August 2017
#+MACRO: UPDATED-MONTH August 2017
#+MACRO: EDITION @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_MICRO@
#+MACRO: VERSION @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_MICRO@
