Commit 6c7f0093 authored by PRUVOST Florent's avatar PRUVOST Florent
docs/ directory should be called doc/ for consistency
parent 2146f27a
with 6 additions and 6 deletions
......@@ -205,9 +205,9 @@ endif()
# Options to enable/disable testings and timings
option(CHAMELEON_ENABLE_DOCS "Enable documentation build" OFF)
if (CHAMELEON_ENABLE_DOCS)
message("-- ${BoldGreen}CHAMELEON_ENABLE_DOCS is set to ON, turn it OFF to avoid building docs${ColourReset}")
option(CHAMELEON_ENABLE_DOC "Enable documentation build" OFF)
if (CHAMELEON_ENABLE_DOC)
message("-- ${BoldGreen}CHAMELEON_ENABLE_DOC is set to ON, turn it OFF to avoid building docs${ColourReset}")
endif()
option(CHAMELEON_ENABLE_EXAMPLE "Enable examples build" ON)
if (CHAMELEON_ENABLE_EXAMPLE)
......@@ -1084,10 +1084,10 @@ endif(CHAMELEON_ENABLE_TIMING)
# Documentation #
if(CHAMELEON_ENABLE_DOCS)
add_subdirectory(docs)
if(CHAMELEON_ENABLE_DOC)
add_subdirectory(doc)
if (DOXYGEN_EXECUTABLE AND MAKEINFO_COMPILER AND TEXI2DVI_COMPILER AND TEX_COMPILER)
add_custom_target(docs ALL DEPENDS doxygen-out doc-info-users_guide doc-html-users_guide doc-pdf-users_guide)
add_custom_target(doc ALL DEPENDS doxygen-out doc-info-users_guide doc-html-users_guide doc-pdf-users_guide)
endif()
endif()
File moved
File moved
File moved
File moved
File moved
File moved
File moved
File moved
