GitLab
Support
Community forum
Keyboard shortcuts
Chameleon
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
solverstack
Chameleon
5fe41d5b
5fe41d5b
Mathieu Faverge
Merge branch 'fix_leading_dimensions' into 'master'
Fix leading dimensions See merge request
!159
parents
2be2ccd3
b94e4481
3
3 changed files
2 additions
5 deletions
+2
-5
runtime/starpu/codelets/codelet_zgessm.c
+0
-2
runtime/starpu/codelets/codelet_zgetrf_incpiv.c
+1
-2
runtime/starpu/codelets/codelet_zsyrk.c
+1
-1
5fe41d5b
@@ -35,7 +35,6 @@ static void cl_zgessm_cpu_func(void *descr[], void *cl_arg)
int
k
int
k
int
ib
int
ib
int
IPIV
int
IPIV
int
ldL
CHAMELEON_Complex64_t
D
D
int
ldD
int
ldD
A
A
@@ -44,7 +43,6 @@ static void cl_zgessm_cpu_func(void *descr[], void *cl_arg)
D
STARPU_MATRIX_GET_PTR
descr
D
descr
A
descr
2
A
descr
2
ldL
STARPU_MATRIX_GET_LD
descr
ldD
descr
ldD
descr
ldA
descr
2
ldA
descr
2
5fe41d5b
@@ -35,7 +35,7 @@ static void cl_zgetrf_incpiv_cpu_func(void *descr[], void *cl_arg)
int
n
int
n
int
ib
int
ib
A
A
int
ldA
ldL
int
ldA
int
IPIV
int
IPIV
cham_bool_t
check_info
cham_bool_t
check_info
int
iinfo
int
iinfo
@@ -45,7 +45,6 @@ static void cl_zgetrf_incpiv_cpu_func(void *descr[], void *cl_arg)
A
descr
A
descr
ldA
descr
ldA
descr
ldL
descr
starpu_codelet_unpack_args
cl_arg
m
n
ib
IPIV
check_info
iinfo
h_work
sequence
request
cl_arg
m
n
ib
IPIV
check_info
iinfo
h_work
sequence
request
CORE_zgetrf_incpiv
m
n
ib
A
ldA
IPIV
info
CORE_zgetrf_incpiv
m
n
ib
A
ldA
IPIV
info
5fe41d5b
@@ -70,7 +70,7 @@ static void cl_zsyrk_cuda_func(void *descr[], void *cl_arg)
A
const
cuDoubleComplex
descr
A
const
cuDoubleComplex
descr
C
cuDoubleComplex
descr
C
cuDoubleComplex
descr
ldA
descr
ldA
descr
ld
A
descr
ld
C
descr
cl_arg
uplo
trans
n
k
alpha
beta
cl_arg
uplo
trans
n
k
alpha
beta
RUNTIME_getStream
stream
RUNTIME_getStream
stream
