Commit 5b6c941d authored by PRUVOST Florent's avatar PRUVOST Florent
trailing whitespace
parent aa0412e4
...@@ -82,17 +82,17 @@ if(NOT CHAMELEON_SIMULATION) ...@@ -82,17 +82,17 @@ if(NOT CHAMELEON_SIMULATION)
link_directories(${MAGMA_LIBRARY_DIRS}) link_directories(${MAGMA_LIBRARY_DIRS})
endif() endif()
list(APPEND libs_for_ltm list(APPEND libs_for_ltm
coreblas coreblas
${LAPACKE_LIBRARIES} ${LAPACKE_LIBRARIES}
${CBLAS_LIBRARIES} ${CBLAS_LIBRARIES}
${LAPACK_SEQ_LIBRARIES} ${LAPACK_SEQ_LIBRARIES}
${BLAS_SEQ_LIBRARIES} ${BLAS_SEQ_LIBRARIES}
${HWLOC_LIBRARIES} ${HWLOC_LIBRARIES}
${EXTRA_LIBRARIES} ${EXTRA_LIBRARIES}
if( BLA_VENDOR MATCHES "Intel10_64lp*" OR BLA_VENDOR MATCHES "ACML*") if( BLA_VENDOR MATCHES "Intel10_64lp*" OR BLA_VENDOR MATCHES "ACML*")
if(BLAS_PAR_LIBRARIES) if(BLAS_PAR_LIBRARIES)
set(CBLAS_LIBRARIES "${BLAS_PAR_LIBRARIES}") set(CBLAS_LIBRARIES "${BLAS_PAR_LIBRARIES}")
...@@ -110,20 +110,20 @@ if(NOT CHAMELEON_SIMULATION) ...@@ -110,20 +110,20 @@ if(NOT CHAMELEON_SIMULATION)
${BLAS_PAR_LIBRARIES} ${BLAS_PAR_LIBRARIES}
else() else()
list(APPEND libs_for_step0 list(APPEND libs_for_step0
coreblas coreblas
endif () endif ()
link_directories(${LAPACKE_LIBRARY_DIRS}) link_directories(${LAPACKE_LIBRARY_DIRS})
link_directories(${LAPACK_LIBRARY_DIRS}) link_directories(${LAPACK_LIBRARY_DIRS})
link_directories(${CBLAS_LIBRARY_DIRS}) link_directories(${CBLAS_LIBRARY_DIRS})
...@@ -133,19 +133,19 @@ else() ...@@ -133,19 +133,19 @@ else()
coreblas coreblas
simulapacke simulapacke
simucblas simucblas
coreblas coreblas
simucblas simucblas
endif() endif()
link_directories(${HWLOC_LIBRARY_DIRS}) link_directories(${HWLOC_LIBRARY_DIRS})
