Commit 3457fd89 authored by PRUVOST Florent's avatar PRUVOST Florent
test with -j4
parent d48ebaa4
...@@ -20,7 +20,7 @@ build_starpu_mpi: ...@@ -20,7 +20,7 @@ build_starpu_mpi:
- mkdir -p build - mkdir -p build
- cd build - cd build
- cmake .. -DCHAMELEON_USE_MPI=ON -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON - cmake .. -DCHAMELEON_USE_MPI=ON -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON
- make | tee ../chameleon-build-starpu.log - make -j4 | tee ../chameleon-build-starpu.log
- make install | tee -a ../chameleon-build-starpu.log && rm install/ -r - make install | tee -a ../chameleon-build-starpu.log && rm install/ -r
build_starpu_cuda: build_starpu_cuda:
...@@ -37,7 +37,7 @@ build_starpu_cuda: ...@@ -37,7 +37,7 @@ build_starpu_cuda:
- cmake .. -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON - cmake .. -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON
- make | tee ../chameleon-build-starpu-cuda.log - make -j4 | tee ../chameleon-build-starpu-cuda.log
- make install | tee -a ../chameleon-build-starpu-cuda.log && rm install/ -r - make install | tee -a ../chameleon-build-starpu-cuda.log && rm install/ -r
build_starpu_simgrid: build_starpu_simgrid:
...@@ -54,7 +54,7 @@ build_starpu_simgrid: ...@@ -54,7 +54,7 @@ build_starpu_simgrid:
- cmake .. -DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON - cmake .. -DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON
- make | tee ../chameleon-build-starpu-simgrid.log - make -j4 | tee ../chameleon-build-starpu-simgrid.log
- make install | tee -a ../chameleon-build-starpu-simgrid.log && rm install/ -r - make install | tee -a ../chameleon-build-starpu-simgrid.log && rm install/ -r
build_quark: build_quark:
...@@ -71,7 +71,7 @@ build_quark: ...@@ -71,7 +71,7 @@ build_quark:
- cmake .. -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON -DCHAMELEON_SCHED_QUARK=ON - cmake .. -DCMAKE_INSTALL_PREFIX=${PWD}/install -DCMAKE_VERBOSE_MAKEFILE=ON -DMORSE_ENABLE_WARNING=ON -DMORSE_ENABLE_COVERAGE=ON -DCHAMELEON_SCHED_QUARK=ON
- make | tee ../chameleon-build-quark.log - make -j4 | tee ../chameleon-build-quark.log
- make install | tee -a ../chameleon-build-quark.log && rm install/ -r - make install | tee -a ../chameleon-build-quark.log && rm install/ -r
test_starpu_mpi: test_starpu_mpi:
