GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
2c5abaf6
2c5abaf6
8 years ago
Mathieu Faverge
Downloads
Patches
Add documentation to cuda_zgeadd kernel
7034ee8f
1 merge request
!39
CUDA geadd kernel
cudablas/compute/cuda_zgeadd.c
+58
-6
58 additions, 6 deletions
58 additions
6 deletions
58
6
2c5abaf6
* @copyright (c) 2009-2014 The University of Tennessee and The University
* of Tennessee Research Foundation.
* All rights reserved.
* @copyright (c) 2012-2016 Inria. All rights reserved.
* @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
* @copyright (c) 2009-2014 The University of Tennessee and The University of
* Tennessee Research Foundation. All rights reserved.
* @copyright (c) 2012-2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* Univ. Bordeaux. All rights reserved.
* @file cuda_zgeadd.c
@@ -29,6 +27,60 @@
#error "This file requires cublas api v2 support"
#endif
* @ingroup CUDA_MORSE_Complex64_t
* CUDA_zgeadd adds to matrices together as in PBLAS pzgeadd.
* B <- alpha * op(A) + beta * B,
* where op(X) = X, X', or conj(X')
* @param[in] trans
* Specifies whether the matrix A is non-transposed, transposed, or
* conjugate transposed
* = MorseNoTrans: op(A) = A
* = MorseTrans: op(A) = A'
* = MorseConjTrans: op(A) = conj(A')
* @param[in] M
* Number of rows of the matrices op(A) and B.
* @param[in] N
* Number of columns of the matrices op(A) and B.
* @param[in] alpha
* Scalar factor of A.
* @param[in] A
* Matrix of size LDA-by-N, if trans = MorseNoTrans, LDA-by-M
* otherwise.
* @param[in] LDA
* Leading dimension of the array A. LDA >= max(1,k), with k=M, if
* trans = MorseNoTrans, and k=N otherwise.
* @param[in] beta
* Scalar factor of B.
* @param[in,out] B
* Matrix of size LDB-by-N.
* On exit, B = alpha * op(A) + beta * B
* @param[in] LDB
* Leading dimension of the array B. LDB >= max(1,M)
* @return
* \retval MORSE_SUCCESS successful exit
* \retval <0 if -i, the i-th argument had an illegal value
int
CUDA_zgeadd
MORSE_enum
trans
int
m
int
n
const
cuDoubleComplex
alpha
This diff is collapsed.
Loading
Save comment
