Commit 1b943777 authored by Matthieu KUHN's avatar Matthieu KUHN Committed by Mathieu Faverge
codelet/starpu: Add the tasks for LU factorization without pivoting per column
parent ad4e9746
1 merge request!365GETRF: Add a version without pivotin column per column
......@@ -23,7 +23,7 @@
* @author Florent Pruvost
* @author Alycia Lisito
* @author Romain Peressoni
* @date 2022-02-22
* @date 2023-02-21
* @precisions normal z -> c d s
......@@ -476,4 +476,18 @@ void RUNTIME_zgersum_set_methods( const CHAM_desc_t *A, int Am, int An );
void RUNTIME_zgersum_submit_tree( const RUNTIME_option_t *options,
* Tasks for LU factorization with partial pivoting
void INSERT_TASK_zgetrf_panel_nopiv_percol_diag( const RUNTIME_option_t *options,
int m, int n, int k,
const CHAM_desc_t *A, int Am, int An,
const CHAM_desc_t *U, int Um, int Un,
int iinfo );
void INSERT_TASK_zgetrf_panel_nopiv_percol_trsm( const RUNTIME_option_t *options,
const CHAM_desc_t *U, int Um, int Un );
#endif /* _chameleon_tasks_z_h_ */
# @author Mathieu Faverge
# @author Florent Pruvost
# @author Philippe Virouleau
# @date 2022-02-22
# @date 2023-02-21
......@@ -65,6 +65,7 @@ set(CODELETS_ZSRC
codelets/codelet_zgetrf.c
codelets/codelet_zgetrf_incpiv.c
codelets/codelet_zgetrf_nopiv.c
codelets/codelet_zpanel.c
codelets/codelet_zhe2ge.c
codelets/codelet_zherfb.c
codelets/codelet_zhessq.c
* @file starpu/codelet_zpanel.c
* @copyright 2012-2023 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* Univ. Bordeaux. All rights reserved.
* @brief Chameleon zpanel StarPU codelets
* @version 1.2.0
* @comment Codelets to perform panel factorization with partial pivoting
* @author Mathieu Faverge
* @author Matthieu Kuhn
* @date 2023-02-21
#include "chameleon_starpu.h"
#include "runtime_codelet_z.h"
#include <coreblas/cblas_wrapper.h>
static const CHAMELEON_Complex64_t zone = (CHAMELEON_Complex64_t) 1.0;
static const CHAMELEON_Complex64_t mzone = (CHAMELEON_Complex64_t)-1.0;
#if !defined(CHAMELEON_SIMULATION)
static void cl_zgetrf_panel_nopiv_percol_diag_cpu_func( void *descr[], void *cl_arg )
CHAM_tile_t *tileA, *tileU;
int m, n, k, lda, iinfo;
RUNTIME_sequence_t *sequence;
RUNTIME_request_t *request;
CHAMELEON_Complex64_t *A, *row, pivot;
tileA = cti_interface_get( descr[0] );
tileU = cti_interface_get( descr[1] );
starpu_codelet_unpack_args( cl_arg, &m, &n, &k, &iinfo, &sequence, &request );
A = tileA->mat;
lda = tileA->ld;
row = tileU->mat;
/* Shift to the diagonal element */
A += k * (lda + 1);
/* Extract row into buffer */
cblas_zcopy( n-k, A, lda, row, 1 );
/* Perform update on current diagonal block directly here */
if ( *row == 0. ) {
if ( sequence->status == CHAMELEON_SUCCESS ) {
RUNTIME_sequence_flush( NULL, sequence, request, iinfo+k+1 );
return;
pivot = 1. / *row;
cblas_zscal( m-k-1, CBLAS_SADDR( pivot ), A + 1, 1 );
CORE_zgemm( ChamNoTrans, ChamNoTrans,
m-k-1, n-k-1, 1,
mzone, A + 1, lda,
row + 1, 1,
zone, A + 1 + lda, lda );
#endif /* !defined(CHAMELEON_SIMULATION) */
* Codelet definition
CODELETS_CPU( zgetrf_panel_nopiv_percol_diag, cl_zgetrf_panel_nopiv_percol_diag_cpu_func );
int iinfo )
struct starpu_codelet *codelet = &cl_zgetrf_panel_nopiv_percol_diag;
// void (*callback)(void*) = options->profiling ? cl_zgetrf_panel_nopiv_percol_diag_callback : NULL;
void (*callback)(void*) = NULL;
CHAMELEON_BEGIN_ACCESS_DECLARATION;
CHAMELEON_ACCESS_RW( A, Am, An );
CHAMELEON_ACCESS_W( U, Um, Un );
CHAMELEON_END_ACCESS_DECLARATION;
rt_starpu_insert_task(
codelet,
STARPU_VALUE, &m, sizeof(int),
STARPU_VALUE, &n, sizeof(int),
STARPU_VALUE, &k, sizeof(int),
STARPU_RW, RTBLKADDR(A, CHAMELEON_Complex64_t, Am, An),
STARPU_W, RTBLKADDR(U, CHAMELEON_Complex64_t, Um, Un),
STARPU_VALUE, &iinfo, sizeof(int),
STARPU_VALUE, &(options->sequence), sizeof(RUNTIME_sequence_t*),
STARPU_VALUE, &(options->request), sizeof(RUNTIME_request_t*),
STARPU_PRIORITY, options->priority,
STARPU_CALLBACK, callback,
STARPU_EXECUTE_ON_WORKER, options->workerid,
#if defined(CHAMELEON_CODELETS_HAVE_NAME)
STARPU_NAME, "zgetrf_panel_nopiv_percol_diag",
#endif
0);
* Update column blocs
static void cl_zgetrf_panel_nopiv_percol_trsm_cpu_func( void *descr[], void *cl_arg )
int m, n, k, lda;
starpu_codelet_unpack_args( cl_arg, &m, &n, &k );
A = tileA->mat;
lda = tileA->ld;
row = tileU->mat;
/* Shift to the right column */
A += k * lda;
pivot = 1. / *row;
cblas_zscal( m, CBLAS_SADDR( pivot ), A, 1 );
/* Update trailing matrix from k+1 to n */
m, n-k-1, 1,
mzone, A, lda,
row + 1, 1,
zone, A + lda, lda );
CODELETS_CPU( zgetrf_panel_nopiv_percol_trsm, cl_zgetrf_panel_nopiv_percol_trsm_cpu_func );
struct starpu_codelet *codelet = &cl_zgetrf_panel_nopiv_percol_trsm;
// void (*callback)(void*) = options->profiling ? cl_zgetrf_panel_nopiv_percol_trsm_callback : NULL;
CHAMELEON_ACCESS_RW(A, Am, An);
CHAMELEON_ACCESS_R(U, Um, Un);
codelet,
STARPU_R, RTBLKADDR(U, CHAMELEON_Complex64_t, Um, Un),
STARPU_NAME, "zgetrf_panel_nopiv_percol_trsm",
#endif
0);
