Commit 1b7263f1 authored by LISITO Alycia's avatar LISITO Alycia
starpu/codelet: Add new task submit to codelet_zipiv_allreduce.c
parent 19b7a5b7
1 merge request!523Restructuration of the codelets getrf and getrf_nopiv
......@@ -20,7 +20,7 @@
#include "runtime_codelet_z.h"
#if defined(CHAMELEON_USE_MPI)
struct cl_redux_args_t {
struct cl_redux_args_s {
int h;
int n;
......@@ -65,7 +65,7 @@ zipiv_allreduce_cpu_func( cppi_interface_t *cppi_me,
static void
cl_zipiv_allreduce_cpu_func( void *descr[], void *cl_arg )
struct cl_redux_args_t *clargs = (struct cl_redux_args_t *) cl_arg;
struct cl_redux_args_s *clargs = (struct cl_redux_args_s *) cl_arg;
cppi_interface_t *cppi_me = ((cppi_interface_t *) descr[0]);
cppi_interface_t *cppi_src = ((cppi_interface_t *) descr[1]);
zipiv_allreduce_cpu_func( cppi_me, cppi_src, clargs->h, clargs->n );
......@@ -73,6 +73,8 @@ cl_zipiv_allreduce_cpu_func( void *descr[], void *cl_arg )
CODELETS_CPU( zipiv_allreduce, cl_zipiv_allreduce_cpu_func )
#if defined(CHAMELEON_STARPU_USE_INSERT) /* defined(CHAMELEON_STARPU_USE_INSERT) */
static void
INSERT_TASK_zipiv_allreduce_send( const RUNTIME_option_t *options,
CHAM_ipiv_t *ipiv,
......@@ -98,14 +100,14 @@ INSERT_TASK_zipiv_allreduce_recv( const RUNTIME_option_t *options,
int h,
int n )
struct cl_redux_args_t *clargs;
clargs = malloc( sizeof( struct cl_redux_args_t ) );
struct cl_redux_args_s *clargs;
clargs = malloc( sizeof( struct cl_redux_args_s ) );
clargs->h = h;
clargs->n = n;
rt_starpu_insert_task(
&cl_zipiv_allreduce,
STARPU_CL_ARGS, clargs, sizeof(struct cl_redux_args_t),
STARPU_CL_ARGS, clargs, sizeof(struct cl_redux_args_s),
STARPU_RW, RUNTIME_pivot_getaddr( ipiv, me, k, h ),
STARPU_R, RUNTIME_pivot_getaddr( ipiv, src, k, h ),
STARPU_EXECUTE_ON_NODE, me,
......@@ -115,6 +117,83 @@ INSERT_TASK_zipiv_allreduce_recv( const RUNTIME_option_t *options,
starpu_mpi_cache_flush( options->sequence->comm, RUNTIME_pivot_getaddr( ipiv, src, k, h ) );
#else /* defined(CHAMELEON_STARPU_USE_INSERT) */
static void
CHAM_ipiv_t *ipiv,
int me,
int dst,
int k,
int h )
INSERT_TASK_COMMON_PARAMETERS_CLNULL( zipiv_allreduce_send, 1 )
starpu_cham_exchange_init_params( options, &params, dst );
starpu_cham_exchange_handle_before_execution( options, &params, &nbdata, descrs,
STARPU_R );
starpu_cham_task_exchange_data_after_execution( options, params, nbdata, descrs );
(void)cl;
(void)cl_name;
static void
CHAM_ipiv_t *ipiv,
int me,
int src,
int k,
int h,
int n )
int ret;
struct starpu_task *task;
INSERT_TASK_COMMON_PARAMETERS_EXTENDED( zipiv_allreduce_recv, zipiv_allreduce, redux, 2 )
starpu_cham_exchange_init_params( options, &params, me );
STARPU_RW );
STARPU_R );
task = starpu_task_create();
task->cl = cl;
/* Set codelet parameters */
clargs->h = h;
clargs->n = n;
task->cl_arg = clargs;
task->cl_arg_size = sizeof( struct cl_redux_args_s );
task->cl_arg_free = 1;
/* Set common parameters */
starpu_cham_task_set_options( options, task, nbdata, descrs, NULL );
/* Flops */
task->flops = 0.;
/* Refine name */
task->name = cl_name;
ret = starpu_task_submit( task );
if ( ret == -ENODEV ) {
task->destroy = 0;
starpu_task_destroy( task );
chameleon_error( "INSERT_TASK_zipiv_allreduce", "Failed to submit the task to StarPU" );
return;
#endif /* defined(CHAMELEON_STARPU_USE_INSERT) */
static void
zipiv_allreduce_chameleon_starpu_task( const RUNTIME_option_t *options,
CHAM_desc_t *A,
